    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.3k Views 15 Watching
    • majidM
      majid
      How may I share a "carpaint" material pack?
      If it is easier to make it in another app and share (online or locally) or use the RS?
      How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
        @majid
        If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
        If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
        Reply Quote 2
        • pixelcruncherP
          Back from a holiday, but whatever Rich says makes sense πŸ™‚
          • KrassK
            Krass
            hello,
            I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
            Krass
            Mike AmosM 1 Reply Last reply
              Mike Amos @Krass
              @Krass
              Not heard that and frankly it is nonsensical.
              Rayscaper is being developed by one very hard working human being in his off work hours.
              You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
              • pixelcruncherP
                To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
                You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
                  Rich O Brien Moderator @pixelcruncher
                  @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
                  Interior render using Rayscaper for SketchUp no denoising
                  Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
                  Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
                  Interior render using Rayscaper for SketchUp with denoising
                  majidM 1 Reply Last reply
                  Reply Quote 6
                    I think he is doing a great job tbh. No complaints.
                    Reply Quote 2
                    • pixelcruncherP
                      The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                      • pixelcruncherP
                        Hey, Rayscaper users!
                        Another release with some bug fixes. Thanks for reporting all those bugs!
                        Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                        always, I recommend upgrading to the latest version.
                        What Changed?
                        • Fix weird artifacts in the interactive render viewport.
                        • Fix the upside-down images when saving.
                        • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                        • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
                        • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                        • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                        Help Me Build the Community πŸ‘
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                        and helps me showcase its capabilities to new users.
                        Follow me on Twitter.
                        Happy Rendering!
                        Reply Quote 2
                          Yay! Great update Thomas
                            sashapepperspray
                            thank you for the new release.
                            I noticed two bugs with this release
                            1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
                            2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
                              [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
                            • pixelcruncherP
                              pixelcruncher Extension Creator @sashapepperspray
                              Hey @sashapepperspray
                              Okay, that's a bug. It should inherit the material of its parent component or group.
                              Also a regression, this was reported by other users as well. I will make an update ASAP.
                              This is definitely on my list. I don't want to commit to a hard date.
                              Regards,
                              Thomas
                              S 1 Reply Last reply
                                sashapepperspray
                                thank you very much
                                • majidM
                                  majid @Rich O Brien
                                  @Rich-O-Brien, These renders are jaw-dropping!
                                  • N
                                    nickchun
                                    I've just been trying out Rayscaper, albeit on an underpowered machine with no dedicated GPU.
                                    I have to say, its been a long time since I've used such an intuitive piece of software, without really needing to refer to the manual. Very much enjoyed using it and will be keeping an eye on it's development. The startup screen humour is genius as well, helps put you in the right frame of mind when starting work.
                                    Well done
                                    Reply Quote 3
                                    • pixelcruncherP
                                      pixelcruncher Extension Creator @nickchun
                                      @nickchun Thanks for the kind words! That made my day!
                                      Cheers,
                                      Thomas
                                      • KrassK
                                        Krass
                                        Hello, pixelcruncher,
                                        I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
                                        Krass
                                        • KrassK
                                          Krass
                                          Hello,
                                          Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
                                          Krass
                                          • KrassK
                                            Krass
                                            I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
                                            Krass
                                            • 37
                                            • 38
                                            • 6 / 38
