    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • majidM
      majid
      Those renders are lovely!
      • KrassK
        Krass
        Great!
        Thank you!
        Krass
        • majidM
          majid @pixelcruncher
          @pixelcruncher I DMed you, do you mind checking it please?
          • KrassK
            Krass
            I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
            Krass
            • pixelcruncherP
              @Krass Great to hear that! Still more good stuff coming.
              • majidM
                majid
                How may I share a "carpaint" material pack?
                If it is easier to make it in another app and share (online or locally) or use the RS?
                How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                  @majid
                  If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
                  If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
                  Reply Quote 2
                  • pixelcruncherP
                    Back from a holiday, but whatever Rich says makes sense πŸ™‚
                    • KrassK
                      Krass
                      hello,
                      I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
                      Krass
                      Mike AmosM 1 Reply Last reply
                        Mike Amos @Krass
                        @Krass
                        Not heard that and frankly it is nonsensical.
                        Rayscaper is being developed by one very hard working human being in his off work hours.
                        You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
                        • pixelcruncherP
                          To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
                          You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
                            Rich O Brien Moderator @pixelcruncher
                            @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
                            Interior render using Rayscaper for SketchUp no denoising
                            Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
                            Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
                            Interior render using Rayscaper for SketchUp with denoising
                            majidM 1 Reply Last reply
                            Reply Quote 6
                              I think he is doing a great job tbh. No complaints.
                              Reply Quote 2
                              • pixelcruncherP
                                The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                                • pixelcruncherP
                                  Hey, Rayscaper users!
                                  Another release with some bug fixes. Thanks for reporting all those bugs!
                                  Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                                  always, I recommend upgrading to the latest version.
                                  What Changed?
                                  • Fix weird artifacts in the interactive render viewport.
                                  • Fix the upside-down images when saving.
                                  • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                                  • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
                                  • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                                  • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                                  Help Me Build the Community πŸ‘
                                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                                  and helps me showcase its capabilities to new users.
                                  Follow me on Twitter.
                                  Happy Rendering!
                                  Reply Quote 2
                                    Yay! Great update Thomas
                                      sashapepperspray
                                      thank you for the new release.
                                      I noticed two bugs with this release
                                      1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
                                      2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
                                        [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @sashapepperspray
                                        Hey @sashapepperspray
                                        Okay, that's a bug. It should inherit the material of its parent component or group.
                                        Also a regression, this was reported by other users as well. I will make an update ASAP.
                                        This is definitely on my list. I don't want to commit to a hard date.
                                        Regards,
                                        Thomas
                                        S 1 Reply Last reply
                                          sashapepperspray
                                          thank you very much
                                          • majidM
                                            majid @Rich O Brien
                                            @Rich-O-Brien, These renders are jaw-dropping!
                                            • 26
                                            • 27
                                            • 6 / 27
