    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • pixelcruncherP
      To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
      You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
        Rich O Brien Moderator @pixelcruncher
        @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
        Interior render using Rayscaper for SketchUp no denoising
        Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
        Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
        Interior render using Rayscaper for SketchUp with denoising
        majidM 1 Reply Last reply
        Reply Quote 6
          I think he is doing a great job tbh. No complaints.
          Reply Quote 2
          • pixelcruncherP
            The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
            • pixelcruncherP
              Hey, Rayscaper users!
              Another release with some bug fixes. Thanks for reporting all those bugs!
              Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
              always, I recommend upgrading to the latest version.
              What Changed?
              • Fix weird artifacts in the interactive render viewport.
              • Fix the upside-down images when saving.
              • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
              • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
              • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
              • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
              Help Me Build the Community ๐Ÿ‘
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesnโ€™t matter)! This is motivating
              and helps me showcase its capabilities to new users.
              Follow me on Twitter.
              Happy Rendering!
              Reply Quote 2
                Yay! Great update Thomas
                  sashapepperspray
                  thank you for the new release.
                  I noticed two bugs with this release
                  1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
                  2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
                    [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
                  • pixelcruncherP
                    pixelcruncher Extension Creator @sashapepperspray
                    Hey @sashapepperspray
                    Okay, that's a bug. It should inherit the material of its parent component or group.
                    Also a regression, this was reported by other users as well. I will make an update ASAP.
                    This is definitely on my list. I don't want to commit to a hard date.
                    Regards,
                    Thomas
                    S 1 Reply Last reply
                      sashapepperspray
                      thank you very much
                      • majidM
                        majid @Rich O Brien
                        @Rich-O-Brien, These renders are jaw-dropping!
                        • N
                          nickchun
                          I've just been trying out Rayscaper, albeit on an underpowered machine with no dedicated GPU.
                          I have to say, its been a long time since I've used such an intuitive piece of software, without really needing to refer to the manual. Very much enjoyed using it and will be keeping an eye on it's development. The startup screen humour is genius as well, helps put you in the right frame of mind when starting work.
                          Well done
                          Reply Quote 3
                          • pixelcruncherP
                            pixelcruncher Extension Creator @nickchun
                            @nickchun Thanks for the kind words! That made my day!
                            Cheers,
                            Thomas
                            • KrassK
                              Krass
                              Hello, pixelcruncher,
                              I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
                              Krass
                              • KrassK
                                Krass
                                Hello,
                                Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
                                Krass
                                • KrassK
                                  Krass
                                  I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
                                  Krass
                                  • KrassK
                                    Krass
                                    ok, that's good, by purging sketchup, I can add sphere lights again
                                    Krass
                                    • pixelcruncherP
                                      @Krass said in Rayscaper New Releases:
                                      Great to hear!
                                      Hello,
                                      The lights take the names of the light components. Maybe I can add the option to rename the lights in Rayscaper itself?
                                      This feels like a bug, do you have a way to reproduce this?
                                      Cheers,
                                      Thomas
                                      • KrassK
                                        Krass
                                        Hello pixelcruncher, I will try later tips for renaming the lights component. Now, i'm rendering an image, I'm stucked
                                        Krass
                                        KrassK 1 Reply Last reply
                                        • KrassK
                                          Krass @Krass
                                          in this scene, a series of bulbs of the same type and two others for the individual lamps. And I end up with the list of numbers if I want to adjust the intensity... it would be necessary to have noted the number of each light that we add...
                                          Krass
                                          Reply Quote 2
                                          • KrassK
                                            Krass
                                            Krass
                                            • 37
                                            • 38
                                            • 7 / 38
