    Rayscaper New Releases
    rayscaperrender
    462 Posts 12 Posters 169.1k Views 13 Watching
      Back from a holiday, but whatever Rich says makes sense πŸ™‚
      • KrassK Offline
        Krass
        hello,
        I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
        Krass
          Mike Amos @Krass
          @Krass
          Not heard that and frankly it is nonsensical.
          Rayscaper is being developed by one very hard working human being in his off work hours.
          You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
            To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
            You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
              Rich O Brien Moderator @pixelcruncher
              @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
              Interior render using Rayscaper for SketchUp no denoising
              Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
              Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
              Interior render using Rayscaper for SketchUp with denoising
              majidM 1 Reply Last reply Reply Quote 6
                I think he is doing a great job tbh. No complaints.
                  The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                    Hey, Rayscaper users!
                    Another release with some bug fixes. Thanks for reporting all those bugs!
                    Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                    always, I recommend upgrading to the latest version.
                    What Changed?
                    • Fix weird artifacts in the interactive render viewport.
                    • Fix the upside-down images when saving.
                    • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                    • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
                    • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                    • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                    Help Me Build the Community πŸ‘
                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                    and helps me showcase its capabilities to new users.
                    Follow me on Twitter.
                    Happy Rendering!
                      Yay! Great update Thomas
                        sashapepperspray
                        thank you for the new release.
                        I noticed two bugs with this release
                        1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
                        2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
                          [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
                          pixelcruncher Extension Creator @sashapepperspray
                          Hey @sashapepperspray
                          Okay, that's a bug. It should inherit the material of its parent component or group.
                          Also a regression, this was reported by other users as well. I will make an update ASAP.
                          This is definitely on my list. I don't want to commit to a hard date.
                          Regards,
                          Thomas
                          S 1 Reply Last reply Reply Quote 0
                            sashapepperspray
                            thank you very much
                            • majidM Offline
                              majid @Rich O Brien
                              @Rich-O-Brien, These renders are jaw-dropping!
                              • N Offline
                                nickchun
                                I've just been trying out Rayscaper, albeit on an underpowered machine with no dedicated GPU.
                                I have to say, its been a long time since I've used such an intuitive piece of software, without really needing to refer to the manual. Very much enjoyed using it and will be keeping an eye on it's development. The startup screen humour is genius as well, helps put you in the right frame of mind when starting work.
                                Well done
                                P 1 Reply Last reply Reply Quote 3
                                  pixelcruncher Extension Creator @nickchun
                                  @nickchun Thanks for the kind words! That made my day!
                                  Cheers,
                                  Thomas
                                  • KrassK Offline
                                    Krass
                                    Hello, pixelcruncher,
                                    I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
                                    Krass
                                    P 1 Reply Last reply Reply Quote 1
                                    • KrassK Offline
                                      Krass
                                      Hello,
                                      Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
                                      Krass
                                      • KrassK Offline
                                        Krass
                                        I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
                                        Krass
                                        • KrassK Offline
                                          Krass
                                          ok, that's good, by purging sketchup, I can add sphere lights again
                                          Krass
                                            @Krass said in Rayscaper New Releases:
                                            Great to hear!
                                            Hello,
                                            The lights take the names of the light components. Maybe I can add the option to rename the lights in Rayscaper itself?
                                            This feels like a bug, do you have a way to reproduce this?
                                            Cheers,
                                            Thomas
                                            • 23
                                            • 24
                                            • 6 / 24
