    Rayscaper New Releases
    rayscaperrender
    791 Posts 14 Posters 369.4k Views 15 Watching
    • pixelcruncherP
      @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
      To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
      Cheers,
      Thomas
      • KrassK
        Krass
        Helo Thomas,
        Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
        https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
        Krass
        • KrassK
          Krass
          Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
          https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
          Krass
          • pixelcruncherP
            Hey, Rayscaper users!
            Another release!
            Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
            What Changed?
            • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
              shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
              in indoor scenes.
            • Add extra logging to help diagnose failed installations.
            • Cyrillic glyph support: The user interface now supports Cyrillic characters.
            • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
            • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
            Help me build the community πŸ‘
            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
            Happy Rendering!
            majidM 1 Reply Last reply
            • majidM
              majid
              Those renders are lovely!
              • KrassK
                Krass
                Great!
                Thank you!
                Krass
                • majidM
                  majid @pixelcruncher
                  @pixelcruncher I DMed you, do you mind checking it please?
                  • KrassK
                    Krass
                    I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
                    Krass
                    • pixelcruncherP
                      @Krass Great to hear that! Still more good stuff coming.
                      • majidM
                        majid
                        How may I share a "carpaint" material pack?
                        If it is easier to make it in another app and share (online or locally) or use the RS?
                        How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                          @majid
                          If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
                          If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
                          Reply Quote 2
                          • pixelcruncherP
                            Back from a holiday, but whatever Rich says makes sense πŸ™‚
                            • KrassK
                              Krass
                              hello,
                              I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
                              Krass
                              Mike AmosM 1 Reply Last reply
                                Mike Amos @Krass
                                @Krass
                                Not heard that and frankly it is nonsensical.
                                Rayscaper is being developed by one very hard working human being in his off work hours.
                                You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
                                • pixelcruncherP
                                  To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
                                  You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
                                    Rich O Brien Moderator @pixelcruncher
                                    @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
                                    Interior render using Rayscaper for SketchUp no denoising
                                    Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
                                    Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
                                    Interior render using Rayscaper for SketchUp with denoising
                                    Reply Quote 6
                                      I think he is doing a great job tbh. No complaints.
                                      Reply Quote 2
                                      • pixelcruncherP
                                        The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                                        • pixelcruncherP
                                          Another release with some bug fixes. Thanks for reporting all those bugs!
                                          Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                                          What Changed?
                                          • Fix weird artifacts in the interactive render viewport.
                                          • Fix the upside-down images when saving.
                                          • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                                          • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
                                          • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                                          • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                                          Help Me Build the Community πŸ‘
                                          If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                                          and helps me showcase its capabilities to new users.
                                          Follow me on Twitter.
                                          Happy Rendering!
                                          Reply Quote 2
                                            Yay! Great update Thomas
                                            • 39
                                            • 40
                                            • 6 / 40
