    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 207.0k Views 13 Watching
      Yay! Great update Thomas
        sashapepperspray
        thank you for the new release.
        I noticed two bugs with this release
        1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
        2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
          [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
        • P Online
          pixelcruncher Extension Creator @sashapepperspray
          Hey @sashapepperspray
          Okay, that's a bug. It should inherit the material of its parent component or group.
          Also a regression, this was reported by other users as well. I will make an update ASAP.
          This is definitely on my list. I don't want to commit to a hard date.
          Regards,
          Thomas
          S 1 Reply Last reply Reply Quote 0
            sashapepperspray
            thank you very much
            • majidM Offline
              majid @Rich O Brien
              @Rich-O-Brien, These renders are jaw-dropping!
              • N Offline
                nickchun
                I've just been trying out Rayscaper, albeit on an underpowered machine with no dedicated GPU.
                I have to say, its been a long time since I've used such an intuitive piece of software, without really needing to refer to the manual. Very much enjoyed using it and will be keeping an eye on it's development. The startup screen humour is genius as well, helps put you in the right frame of mind when starting work.
                Well done
                P 1 Reply Last reply Reply Quote 3
                • P Online
                  pixelcruncher Extension Creator @nickchun
                  @nickchun Thanks for the kind words! That made my day!
                  Cheers,
                  Thomas
                  • KrassK Offline
                    Krass
                    Hello, pixelcruncher,
                    I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
                    Krass
                    P 1 Reply Last reply Reply Quote 1
                    • KrassK Offline
                      Krass
                      Hello,
                      Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
                      Krass
                      • KrassK Offline
                        Krass
                        I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
                        Krass
                        • KrassK Offline
                          Krass
                          ok, that's good, by purging sketchup, I can add sphere lights again
                          Krass
                          • P Online
                            @Krass said in Rayscaper New Releases:
                            Great to hear!
                            Hello,
                            The lights take the names of the light components. Maybe I can add the option to rename the lights in Rayscaper itself?
                            This feels like a bug, do you have a way to reproduce this?
                            Cheers,
                            Thomas
                            • KrassK Offline
                              Krass
                              Hello pixelcruncher, I will try later tips for renaming the lights component. Now, i'm rendering an image, I'm stucked
                              Krass
                              KrassK 1 Reply Last reply Reply Quote 0
                              • KrassK Offline
                                Krass @Krass
                                in this scene, a series of bulbs of the same type and two others for the individual lamps. And I end up with the list of numbers if I want to adjust the intensity... it would be necessary to have noted the number of each light that we add...
                                Krass
                                • KrassK Offline
                                  Krass
                                  Krass
                                    OK, with the replacement of mats, some issues have been resolved. I have lightened this image to demonstrate what I think it a problem/issue. The cabinet doors here have a texture to them they have not had selected by me. Is this part of the ai changes? If it is, I am not a fan.
                                    4 1000s 2081 x 1160  912945 tri 1m 07s GPU  Post pro increased exposure to 1.75.png
                                    Rich O BrienR P 2 Replies Last reply Reply Quote 1
                                    • KrassK Offline
                                      Krass
                                      hello,
                                      yes, and under the hood and above the stove, the noise is too present (by the way, I like your rendering.) this noise problem on certain dark parts is recurrent with Rayscaper. But can you show a screenshot of the original texture that you applied to the kitchen furniture?Perhaps you could use a stronger emissive material for your light that illuminates the work surfaces, rather than a spotlight or sphere light?
                                      Krass
                                        Looks like rayscaper is maturing well πŸ‘
                                          @Mike-Amos said in Rayscaper New Releases:
                                          Can you add more exact info like the number of passes?
                                          That to me is not a texture. Looks like that area of the model is dark and RS is struggling to resolve fully.
                                          • KrassK Offline
                                            Krass
                                            an old project, rendered with Rayscaper photoshop retouching and AI upscale
                                            Krass
                                            P 1 Reply Last reply Reply Quote 2
                                            • 23
                                            • 24
                                            • 7 / 24
