    Triangulate triangles ?
    41 Posts 8 Posters 8.5k Views 8 Watching
    • cottyC Offline
      cotty
      I think the triangulation is not the same...
      my SketchUp gallery
      • renderizaR Offline
        renderiza
        Both of these are very useful so maybe add an option to choose between the two.
        http://s23.postimg.org/sp0h6r557/e_1.png
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
          πŸ˜•
            renderiza
            Not as easy as using the center of face.bounds.center is it. πŸ˜•
            If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
              renderiza
              I sure don't call the code below a success but its definitely interesting...
              http://s13.postimg.org/yerdljl8n/eee.jpg
              model = Sketchup.active_model
              ents = model.active_entities
              sel = model.selection
              faces = sel.grep(Sketchup;;Face)
              model.start_operation('csplit')
                faces.each do |face|
                  vertices = face.vertices
                  edges = face.edges
                  bbox = face.bounds
                  cpoint = bbox.center
                 edges.each do |e|
                    e1 = e.start.position
                    e2 = e.end.position
                    x = (e2.x + e1.x) / 2
                    y = (e2.y + e1.y) / 2
                    z = (e2.z + e1.z) / 2
                    vertices.each do |vertex|
                      p1 = [x, y, z]
                      p2 = vertex
                      line = ents.add_line p1,p2
                sel.clear
              model.commit_operation
              Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                renderiza
                If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
                http://s15.postimg.org/3zyfm7ayz/pp1.jpg
                • JQLJ Offline
                  JQL
                  Renderiza,
                  That's not success, that's brilliance!
                  I'll start designing tiles right away...
                  Thanks!
                  JQL
                  www.casca.pt
                  Visit us on facebook!
                    renderiza
                    Wish you success or better yet brilliance in your designs! πŸ’š
                      you make big progress and be near the success! β˜€
                      Why not take the image of the first post as "pseudo code" ?
                      • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                        (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                      • draw 3 lines from this point to the 3 vertices
                      Tig has finalized his "triangulate" method!
                      Medians stay in race! πŸ˜„
                      Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                        renderiza
                        Thanks guys! Will definitely study your suggestions. πŸ‘
                        • jolranJ Offline
                          jolran
                          I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                          Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                          I just ripped it out from a plugin I'm working on..
                          # Arguments need 3 point3D objects from triangle.
                          def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                          	#Init Vectors for calculation.
                          	vec1  = p1.vector_to(p2)
                          	vec2  = p1.vector_to(p3)
                          	fakeZ = vec1.cross(vec2) #cross Plane...
                          	#midpoints
                          	mp1 = p1.offset(vec1, vec1.length/2)
                          	mp2 = p1.offset(vec2, vec2.length/2)
                          	#cross vectors..
                          	vec1 = vec1.cross(fakeZ)
                          	vec2 = vec2.cross(fakeZ)
                          	#lines
                          	line1 = [mp1, vec1]
                          	line2 = [mp2, vec2]
                          	return c = Geom.intersect_line_line(line1, line2) #point3D
                          edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                            renderiza
                            It works! 😍
                            http://s9.postimg.org/3oou2krkf/yay.jpg
                            Here is the code...
                                v = face.vertices
                                cx = v[0].position.x + v[1].position.x + v[2].position.x
                                cy = v[0].position.y + v[1].position.y + v[2].position.y
                                cz = v[0].position.z + v[1].position.z + v[2].position.z
                                px = cx / 3
                                py = cy / 3
                                pz = cz / 3
                                v.each do |vertex|
                                  p1 = [px, py, pz]
                                  p2 = vertex
                              sel.clear
                            Note: At the moment the above code works with triangles only.
                            For squares we can use the code bellow...
                                v = face.vertices
                                cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                                cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                                cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                                px = cx / 4
                                py = cy / 4
                                pz = cz / 4
                                v.each do |vertex|
                                  p1 = [px, py, pz]
                                  p2 = vertex
                              sel.clear
                              renderiza
                              The following code will work on all geometry types like triangle, square, ect...
                              @addx = []
                              @addy = []
                              @addz = []
                                  @addx.clear
                                  @addy.clear
                                  @addz.clear
                                  v = face.vertices
                                  num = v.length
                                  v.each_with_index {|vert,i|
                                    @addx << " + v[#{i}].position.x"
                                    @addy << " + v[#{i}].position.y"
                                    @addz << " + v[#{i}].position.z"
                                  ax = @addx * ","
                                  sumx = ax.delete ","
                                  ay = @addy * ","
                                  sumy = ay.delete ","
                                  az = @addz * ","
                                  sumz = az.delete ","
                                  cx = eval("#{sumx}")
                                  cy = eval("#{sumy}")
                                  cz = eval("#{sumz}")
                                  px = cx / num
                                  py = cy / num
                                  pz = cz / num
                                  v.each do |vertex|
                                    p1 = [px, py, pz]
                                    p2 = vertex
                                sel.clear
                              Note: To test code above you can copy & paste it to one of this ruby consoles...
                              http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                                renderiza
                                With the help of Dan Rathbun the code was improved! Because string manipulation in Ruby can be slow he figured a way to do it without strings.
                                Here is the new code...
                                  def csplit()
                                        sum = Geom;;Point3d.new(0,0,0)
                                        verts = face.vertices
                                        n = verts.size.to_f
                                        # use API Geom;;Point3d.+ instance method;
                                        verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                                        avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                                        verts.each {|v| ents.add_line( avg, v ) }
                                      end # each face
                                  rescue => e
                                    puts "Error <#{e.class.name}; #{e.message} >"
                                    puts e.backtrace if $VERBOSE
                                    model.abort_operation
                                  else # when no errors;
                                    sel.clear
                                  end # csplit()
                                  csplit()
                                If you have the time make sure to thank Dan...Cheers!
                                  Seems very cool! πŸ‘
                                  Waiting the definitive little plugin more easy than a copy past inside the ruby console! πŸ˜‰
                                  And you will your name in the index Plugin automatic list by Jim! 😎
                                    renderiza
                                    Ok I will start working on that ASAP!!!
                                    By the way you like the name "FaceSplit"?
                                      "Bermuda's Triangles' Gravity" will be also funny! πŸ˜‰
                                      https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQVDrKcLEC7T4VaspbQcQc_3tRmnEFfnCvFR7lAKksR_Dcd6PSkIQ
                                        renderiza
                                        I am glad you liked "FaceSplit"! 🀣
                                          renderiza
                                          Here is the logo...
                                          Big:
                                          http://s8.postimg.org/f4mis2579/Face_Split.png
                                          Small:
                                          http://s14.postimg.org/4n72xxfrh/Face_Split54.png
                                            renderiza
                                            Here is the plugin main page... http://sketchucation.com/forums/viewtopic.php?p=495689#p495689
                                            I used FaceSplit as name but if you guys come up with better name that is short & catchy then it will be easy to change.'
                                            Cheers! πŸ‘
                                            • 2 / 3
