    Triangulate triangles ?
    41 Posts 8 Posters 11.3k Views 8 Watching
      Beat me to it πŸ˜‰
      You might want to change the
      faces = ents.grep(Sketchup::Face)
      to
      faces = **sel**.grep(Sketchup::Face)
      So then the user changes only selected faces ?
      OR perhaps
      faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
      so it works on a selection OR everything if there is no selection...
      Also you want to make it undoable, so add
      **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
      πŸ€“
      • renderizaR
        renderiza
        Hahaha!
        TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. πŸ‘
        I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! πŸ’š
        By the way thanks for the suggestion! πŸ‘
        Here is updated code...
        model = Sketchup.active_model
        ents = model.active_entities
        sel = model.selection
        faces = sel.grep(Sketchup;;Face)
        model.start_operation('csplit')
          faces.each do |face|
            vertices = face.vertices
            bbox = face.bounds
            cpoint = bbox.center
            vertices.each do |vertex|
              p1 = cpoint
              p2 = vertex
              line = ents.add_line p1,p2
          sel.clear
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          OK
          I'll make a simple script and publish it shortly...
          • renderizaR
            renderiza
            Thank you TIG! πŸ‘
              anar
              Thanks Pilou !
              You convinced TIG...
              And Thanks TIG, I think it's a must have !
              http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                TriangulateAllFaces...
                • cottyC
                  cotty
                  I think the triangulation is not the same...
                  my SketchUp gallery
                  • renderizaR
                    renderiza
                    Both of these are very useful so maybe add an option to choose between the two.
                    http://s23.postimg.org/sp0h6r557/e_1.png
                      To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
                      πŸ˜•
                      • renderizaR
                        renderiza
                        Not as easy as using the center of face.bounds.center is it. πŸ˜•
                        If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
                        • renderizaR
                          renderiza
                          I sure don't call the code below a success but its definitely interesting...
                          http://s13.postimg.org/yerdljl8n/eee.jpg
                              edges = face.edges
                              bbox = face.bounds
                             edges.each do |e|
                                e1 = e.start.position
                                e2 = e.end.position
                                x = (e2.x + e1.x) / 2
                                y = (e2.y + e1.y) / 2
                                z = (e2.z + e1.z) / 2
                                  p1 = [x, y, z]
                                  p2 = vertex
                            sel.clear
                          Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                          • renderizaR
                            renderiza
                            If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
                            http://s15.postimg.org/3zyfm7ayz/pp1.jpg
                            • JQLJ
                              JQL
                              Renderiza,
                              That's not success, that's brilliance!
                              I'll start designing tiles right away...
                              JQL
                              www.casca.pt
                              Visit us on facebook!
                              • renderizaR
                                renderiza
                                Wish you success or better yet brilliance in your designs! πŸ’š
                                  you make big progress and be near the success! β˜€
                                  Why not take the image of the first post as "pseudo code" ?
                                  • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                                    (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                                  • draw 3 lines from this point to the 3 vertices
                                  Tig has finalized his "triangulate" method!
                                  Medians stay in race! πŸ˜„
                                  Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                                  • renderizaR
                                    renderiza
                                    Thanks guys! Will definitely study your suggestions. πŸ‘
                                    • jolranJ
                                      jolran
                                      I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                                      Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                                      I just ripped it out from a plugin I'm working on..
                                      # Arguments need 3 point3D objects from triangle.
                                      def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                                      	#Init Vectors for calculation.
                                      	vec1  = p1.vector_to(p2)
                                      	vec2  = p1.vector_to(p3)
                                      	fakeZ = vec1.cross(vec2) #cross Plane...
                                      	#midpoints
                                      	mp1 = p1.offset(vec1, vec1.length/2)
                                      	mp2 = p1.offset(vec2, vec2.length/2)
                                      	#cross vectors..
                                      	vec1 = vec1.cross(fakeZ)
                                      	vec2 = vec2.cross(fakeZ)
                                      	#lines
                                      	line1 = [mp1, vec1]
                                      	line2 = [mp2, vec2]
                                      	return c = Geom.intersect_line_line(line1, line2) #point3D
                                      edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                                      • renderizaR
                                        renderiza
                                        It works! 😍
                                        http://s9.postimg.org/3oou2krkf/yay.jpg
                                        Here is the code...
                                            v = face.vertices
                                            cx = v[0].position.x + v[1].position.x + v[2].position.x
                                            cy = v[0].position.y + v[1].position.y + v[2].position.y
                                            cz = v[0].position.z + v[1].position.z + v[2].position.z
                                            px = cx / 3
                                            py = cy / 3
                                            pz = cz / 3
                                            v.each do |vertex|
                                              p1 = [px, py, pz]
                                              p2 = vertex
                                          sel.clear
                                        Note: At the moment the above code works with triangles only.
                                        For squares we can use the code bellow...
                                            v = face.vertices
                                            cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                                            cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                                            cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                                            px = cx / 4
                                            py = cy / 4
                                            pz = cz / 4
                                            v.each do |vertex|
                                              p1 = [px, py, pz]
                                              p2 = vertex
                                          sel.clear
                                        • renderizaR
                                          renderiza
                                          The following code will work on all geometry types like triangle, square, ect...
                                          @addx = []
                                          @addy = []
                                          @addz = []
                                              @addx.clear
                                              @addy.clear
                                              @addz.clear
                                              v = face.vertices
                                              num = v.length
                                              v.each_with_index {|vert,i|
                                                @addx << " + v[#{i}].position.x"
                                                @addy << " + v[#{i}].position.y"
                                                @addz << " + v[#{i}].position.z"
                                              ax = @addx * ","
                                              sumx = ax.delete ","
                                              ay = @addy * ","
                                              sumy = ay.delete ","
                                              az = @addz * ","
                                              sumz = az.delete ","
                                              cx = eval("#{sumx}")
                                              cy = eval("#{sumy}")
                                              cz = eval("#{sumz}")
                                              px = cx / num
                                              py = cy / num
                                              pz = cz / num
                                              v.each do |vertex|
                                                p1 = [px, py, pz]
                                                p2 = vertex
                                            sel.clear
                                          Note: To test code above you can copy & paste it to one of this ruby consoles...
                                          http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                                          • renderizaR
                                            renderiza
                                            With the help of Dan Rathbun the code was improved! Because string manipulation in Ruby can be slow he figured a way to do it without strings.
                                            Here is the new code...
                                              def csplit()
                                                    sum = Geom;;Point3d.new(0,0,0)
                                                    verts = face.vertices
                                                    n = verts.size.to_f
                                                    # use API Geom;;Point3d.+ instance method;
                                                    verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                                                    avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                                                    verts.each {|v| ents.add_line( avg, v ) }
                                                  end # each face
                                              rescue => e
                                                puts "Error <#{e.class.name}; #{e.message} >"
                                                puts e.backtrace if $VERBOSE
                                                model.abort_operation
                                              else # when no errors;
                                                sel.clear
                                              end # csplit()
                                              csplit()
                                            If you have the time make sure to thank Dan...Cheers!
                                            • 2 / 3
