    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
      Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
      TriangulateAllFaces...
      • cottyC
        cotty
        I think the triangulation is not the same...
        my SketchUp gallery
        • renderizaR
          renderiza
          Both of these are very useful so maybe add an option to choose between the two.
          http://s23.postimg.org/sp0h6r557/e_1.png
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
            πŸ˜•
            • renderizaR
              renderiza
              Not as easy as using the center of face.bounds.center is it. πŸ˜•
              If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
              • renderizaR
                renderiza
                I sure don't call the code below a success but its definitely interesting...
                http://s13.postimg.org/yerdljl8n/eee.jpg
                model = Sketchup.active_model
                ents = model.active_entities
                sel = model.selection
                faces = sel.grep(Sketchup;;Face)
                model.start_operation('csplit')
                  faces.each do |face|
                    vertices = face.vertices
                    edges = face.edges
                    bbox = face.bounds
                    cpoint = bbox.center
                   edges.each do |e|
                      e1 = e.start.position
                      e2 = e.end.position
                      x = (e2.x + e1.x) / 2
                      y = (e2.y + e1.y) / 2
                      z = (e2.z + e1.z) / 2
                      vertices.each do |vertex|
                        p1 = [x, y, z]
                        p2 = vertex
                        line = ents.add_line p1,p2
                  sel.clear
                model.commit_operation
                Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                • renderizaR
                  renderiza
                  If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
                  http://s15.postimg.org/3zyfm7ayz/pp1.jpg
                  • JQLJ
                    JQL
                    Renderiza,
                    That's not success, that's brilliance!
                    I'll start designing tiles right away...
                    JQL
                    www.casca.pt
                    Visit us on facebook!
                    • renderizaR
                      renderiza
                      Wish you success or better yet brilliance in your designs! πŸ’š
                        you make big progress and be near the success! β˜€
                        Why not take the image of the first post as "pseudo code" ?
                        • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                          (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                        • draw 3 lines from this point to the 3 vertices
                        Tig has finalized his "triangulate" method!
                        Medians stay in race! πŸ˜„
                        Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                        • renderizaR
                          renderiza
                          Thanks guys! Will definitely study your suggestions. πŸ‘
                          • jolranJ
                            jolran
                            I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                            Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                            I just ripped it out from a plugin I'm working on..
                            # Arguments need 3 point3D objects from triangle.
                            def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                            	#Init Vectors for calculation.
                            	vec1  = p1.vector_to(p2)
                            	vec2  = p1.vector_to(p3)
                            	fakeZ = vec1.cross(vec2) #cross Plane...
                            	#midpoints
                            	mp1 = p1.offset(vec1, vec1.length/2)
                            	mp2 = p1.offset(vec2, vec2.length/2)
                            	#cross vectors..
                            	vec1 = vec1.cross(fakeZ)
                            	vec2 = vec2.cross(fakeZ)
                            	#lines
                            	line1 = [mp1, vec1]
                            	line2 = [mp2, vec2]
                            	return c = Geom.intersect_line_line(line1, line2) #point3D
                            edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                            • renderizaR
                              renderiza
                              It works! 😍
                              http://s9.postimg.org/3oou2krkf/yay.jpg
                              Here is the code...
                                  v = face.vertices
                                  cx = v[0].position.x + v[1].position.x + v[2].position.x
                                  cy = v[0].position.y + v[1].position.y + v[2].position.y
                                  cz = v[0].position.z + v[1].position.z + v[2].position.z
                                  px = cx / 3
                                  py = cy / 3
                                  pz = cz / 3
                                  v.each do |vertex|
                                    p1 = [px, py, pz]
                                    p2 = vertex
                                sel.clear
                              Note: At the moment the above code works with triangles only.
                              For squares we can use the code bellow...
                                  v = face.vertices
                                  cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                                  cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                                  cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                                  px = cx / 4
                                  py = cy / 4
                                  pz = cz / 4
                                  v.each do |vertex|
                                    p1 = [px, py, pz]
                                    p2 = vertex
                                sel.clear
                              • renderizaR
                                renderiza
                                The following code will work on all geometry types like triangle, square, ect...
                                @addx = []
                                @addy = []
                                @addz = []
                                    @addx.clear
                                    @addy.clear
                                    @addz.clear
                                    v = face.vertices
                                    num = v.length
                                    v.each_with_index {|vert,i|
                                      @addx << " + v[#{i}].position.x"
                                      @addy << " + v[#{i}].position.y"
                                      @addz << " + v[#{i}].position.z"
                                    ax = @addx * ","
                                    sumx = ax.delete ","
                                    ay = @addy * ","
                                    sumy = ay.delete ","
                                    az = @addz * ","
                                    sumz = az.delete ","
                                    cx = eval("#{sumx}")
                                    cy = eval("#{sumy}")
                                    cz = eval("#{sumz}")
                                    px = cx / num
                                    py = cy / num
                                    pz = cz / num
                                    v.each do |vertex|
                                      p1 = [px, py, pz]
                                      p2 = vertex
                                  sel.clear
                                Note: To test code above you can copy & paste it to one of this ruby consoles...
                                http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                                • renderizaR
                                  renderiza
                                  With the help of Dan Rathbun the code was improved! Because string manipulation in Ruby can be slow he figured a way to do it without strings.
                                  Here is the new code...
                                    def csplit()
                                          sum = Geom;;Point3d.new(0,0,0)
                                          verts = face.vertices
                                          n = verts.size.to_f
                                          # use API Geom;;Point3d.+ instance method;
                                          verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                                          avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                                          verts.each {|v| ents.add_line( avg, v ) }
                                        end # each face
                                    rescue => e
                                      puts "Error <#{e.class.name}; #{e.message} >"
                                      puts e.backtrace if $VERBOSE
                                      model.abort_operation
                                    else # when no errors;
                                      sel.clear
                                    end # csplit()
                                    csplit()
                                  If you have the time make sure to thank Dan...Cheers!
                                    Seems very cool! πŸ‘
                                    Waiting the definitive little plugin more easy than a copy past inside the ruby console! πŸ˜‰
                                    And you will your name in the index Plugin automatic list by Jim! 😎
                                    • renderizaR
                                      renderiza
                                      Ok I will start working on that ASAP!!!
                                      By the way you like the name "FaceSplit"?
                                        "Bermuda's Triangles' Gravity" will be also funny! πŸ˜‰
                                        https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQVDrKcLEC7T4VaspbQcQc_3tRmnEFfnCvFR7lAKksR_Dcd6PSkIQ
                                        • renderizaR
                                          renderiza
                                          I am glad you liked "FaceSplit"! 🀣
                                          • renderizaR
                                            renderiza
                                            Here is the logo...
                                            Big:
                                            http://s8.postimg.org/f4mis2579/Face_Split.png
                                            Small:
                                            http://s14.postimg.org/4n72xxfrh/Face_Split54.png
                                            • 2 / 3
