    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
    • renderizaR
      renderiza
      Not as easy as using the center of face.bounds.center is it. πŸ˜•
      If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        I sure don't call the code below a success but its definitely interesting...
        http://s13.postimg.org/yerdljl8n/eee.jpg
        model = Sketchup.active_model
        ents = model.active_entities
        sel = model.selection
        faces = sel.grep(Sketchup;;Face)
        model.start_operation('csplit')
          faces.each do |face|
            vertices = face.vertices
            edges = face.edges
            bbox = face.bounds
            cpoint = bbox.center
           edges.each do |e|
              e1 = e.start.position
              e2 = e.end.position
              x = (e2.x + e1.x) / 2
              y = (e2.y + e1.y) / 2
              z = (e2.z + e1.z) / 2
              vertices.each do |vertex|
                p1 = [x, y, z]
                p2 = vertex
                line = ents.add_line p1,p2
          sel.clear
        model.commit_operation
        Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
        • renderizaR
          renderiza
          If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
          http://s15.postimg.org/3zyfm7ayz/pp1.jpg
          • JQLJ
            JQL
            Renderiza,
            That's not success, that's brilliance!
            I'll start designing tiles right away...
            JQL
            www.casca.pt
            Visit us on facebook!
            • renderizaR
              renderiza
              Wish you success or better yet brilliance in your designs! πŸ’š
                you make big progress and be near the success! β˜€
                Why not take the image of the first post as "pseudo code" ?
                • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                  (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                • draw 3 lines from this point to the 3 vertices
                Tig has finalized his "triangulate" method!
                Medians stay in race! πŸ˜„
                Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                • renderizaR
                  renderiza
                  Thanks guys! Will definitely study your suggestions. πŸ‘
                  • jolranJ
                    jolran
                    I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                    Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                    I just ripped it out from a plugin I'm working on..
                    # Arguments need 3 point3D objects from triangle.
                    def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                    	#Init Vectors for calculation.
                    	vec1  = p1.vector_to(p2)
                    	vec2  = p1.vector_to(p3)
                    	fakeZ = vec1.cross(vec2) #cross Plane...
                    	#midpoints
                    	mp1 = p1.offset(vec1, vec1.length/2)
                    	mp2 = p1.offset(vec2, vec2.length/2)
                    	#cross vectors..
                    	vec1 = vec1.cross(fakeZ)
                    	vec2 = vec2.cross(fakeZ)
                    	#lines
                    	line1 = [mp1, vec1]
                    	line2 = [mp2, vec2]
                    	return c = Geom.intersect_line_line(line1, line2) #point3D
                    edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                    • renderizaR
                      renderiza
                      It works! 😍
                      http://s9.postimg.org/3oou2krkf/yay.jpg
                      Here is the code...
                          v = face.vertices
                          cx = v[0].position.x + v[1].position.x + v[2].position.x
                          cy = v[0].position.y + v[1].position.y + v[2].position.y
                          cz = v[0].position.z + v[1].position.z + v[2].position.z
                          px = cx / 3
                          py = cy / 3
                          pz = cz / 3
                          v.each do |vertex|
                            p1 = [px, py, pz]
                            p2 = vertex
                        sel.clear
                      Note: At the moment the above code works with triangles only.
                      For squares we can use the code bellow...
                          v = face.vertices
                          cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                          cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                          cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                          px = cx / 4
                          py = cy / 4
                          pz = cz / 4
                          v.each do |vertex|
                            p1 = [px, py, pz]
                            p2 = vertex
                        sel.clear
                      • renderizaR
                        renderiza
                        The following code will work on all geometry types like triangle, square, ect...
                        @addx = []
                        @addy = []
                        @addz = []
                            @addx.clear
                            @addy.clear
                            @addz.clear
                            v = face.vertices
                            num = v.length
                            v.each_with_index {|vert,i|
                              @addx << " + v[#{i}].position.x"
                              @addy << " + v[#{i}].position.y"
                              @addz << " + v[#{i}].position.z"
                            ax = @addx * ","
                            sumx = ax.delete ","
                            ay = @addy * ","
                            sumy = ay.delete ","
                            az = @addz * ","
                            sumz = az.delete ","
                            cx = eval("#{sumx}")
                            cy = eval("#{sumy}")
                            cz = eval("#{sumz}")
                            px = cx / num
                            py = cy / num
                            pz = cz / num
                            v.each do |vertex|
                              p1 = [px, py, pz]
                              p2 = vertex
                          sel.clear
                        Note: To test code above you can copy & paste it to one of this ruby consoles...
                        http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                        • renderizaR
                          renderiza
                          With the help of Dan Rathbun the code was improved! Because string manipulation in Ruby can be slow he figured a way to do it without strings.
                          Here is the new code...
                            def csplit()
                                  sum = Geom;;Point3d.new(0,0,0)
                                  verts = face.vertices
                                  n = verts.size.to_f
                                  # use API Geom;;Point3d.+ instance method;
                                  verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                                  avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                                  verts.each {|v| ents.add_line( avg, v ) }
                                end # each face
                            rescue => e
                              puts "Error <#{e.class.name}; #{e.message} >"
                              puts e.backtrace if $VERBOSE
                              model.abort_operation
                            else # when no errors;
                              sel.clear
                            end # csplit()
                            csplit()
                          If you have the time make sure to thank Dan...Cheers!
                            Seems very cool! πŸ‘
                            Waiting the definitive little plugin more easy than a copy past inside the ruby console! πŸ˜‰
                            And you will your name in the index Plugin automatic list by Jim! 😎
                            • renderizaR
                              renderiza
                              Ok I will start working on that ASAP!!!
                              By the way you like the name "FaceSplit"?
                                "Bermuda's Triangles' Gravity" will be also funny! πŸ˜‰
                                https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQVDrKcLEC7T4VaspbQcQc_3tRmnEFfnCvFR7lAKksR_Dcd6PSkIQ
                                • renderizaR
                                  renderiza
                                  I am glad you liked "FaceSplit"! 🀣
                                  • renderizaR
                                    renderiza
                                    Here is the logo...
                                    Big:
                                    http://s8.postimg.org/f4mis2579/Face_Split.png
                                    Small:
                                    http://s14.postimg.org/4n72xxfrh/Face_Split54.png
                                    • renderizaR
                                      renderiza
                                      Here is the plugin main page... http://sketchucation.com/forums/viewtopic.php?p=495689#p495689
                                      I used FaceSplit as name but if you guys come up with better name that is short & catchy then it will be easy to change.'
                                      Cheers! πŸ‘
                                        Bravo!
                                        Seems fabulous after this studious working weekend! 😎
                                        • 2 / 3
