    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
    • renderizaR
      renderiza
      I will do that! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Beat me to it πŸ˜‰
        You might want to change the
        faces = ents.grep(Sketchup::Face)
        to
        faces = **sel**.grep(Sketchup::Face)
        So then the user changes only selected faces ?
        OR perhaps
        faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
        so it works on a selection OR everything if there is no selection...
        Also you want to make it undoable, so add
        **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
        πŸ€“
        • renderizaR
          renderiza
          Hahaha!
          TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. πŸ‘
          I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! πŸ’š
          By the way thanks for the suggestion! πŸ‘
          Here is updated code...
          model = Sketchup.active_model
          ents = model.active_entities
          sel = model.selection
          faces = sel.grep(Sketchup;;Face)
          model.start_operation('csplit')
            faces.each do |face|
              vertices = face.vertices
              bbox = face.bounds
              cpoint = bbox.center
              vertices.each do |vertex|
                p1 = cpoint
                p2 = vertex
                line = ents.add_line p1,p2
            sel.clear
            OK
            I'll make a simple script and publish it shortly...
            • renderizaR
              renderiza
              Thank you TIG! πŸ‘
                anar
                Thanks Pilou !
                You convinced TIG...
                And Thanks TIG, I think it's a must have !
                http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                  Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                  TriangulateAllFaces...
                  • cottyC
                    cotty
                    I think the triangulation is not the same...
                    my SketchUp gallery
                    • renderizaR
                      renderiza
                      Both of these are very useful so maybe add an option to choose between the two.
                      http://s23.postimg.org/sp0h6r557/e_1.png
                        To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
                        πŸ˜•
                        • renderizaR
                          renderiza
                          Not as easy as using the center of face.bounds.center is it. πŸ˜•
                          If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
                          • renderizaR
                            renderiza
                            I sure don't call the code below a success but its definitely interesting...
                            http://s13.postimg.org/yerdljl8n/eee.jpg
                                edges = face.edges
                                bbox = face.bounds
                               edges.each do |e|
                                  e1 = e.start.position
                                  e2 = e.end.position
                                  x = (e2.x + e1.x) / 2
                                  y = (e2.y + e1.y) / 2
                                  z = (e2.z + e1.z) / 2
                                    p1 = [x, y, z]
                                    p2 = vertex
                              sel.clear
                            Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                            • renderizaR
                              renderiza
                              If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
                              http://s15.postimg.org/3zyfm7ayz/pp1.jpg
                              • JQLJ
                                JQL
                                Renderiza,
                                That's not success, that's brilliance!
                                I'll start designing tiles right away...
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                • renderizaR
                                  renderiza
                                  Wish you success or better yet brilliance in your designs! πŸ’š
                                    you make big progress and be near the success! β˜€
                                    Why not take the image of the first post as "pseudo code" ?
                                    • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                                      (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                                    • draw 3 lines from this point to the 3 vertices
                                    Tig has finalized his "triangulate" method!
                                    Medians stay in race! πŸ˜„
                                    Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                                    • renderizaR
                                      renderiza
                                      Thanks guys! Will definitely study your suggestions. πŸ‘
                                      • jolranJ
                                        jolran
                                        I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                                        Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                                        I just ripped it out from a plugin I'm working on..
                                        # Arguments need 3 point3D objects from triangle.
                                        def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                                        	#Init Vectors for calculation.
                                        	vec1  = p1.vector_to(p2)
                                        	vec2  = p1.vector_to(p3)
                                        	fakeZ = vec1.cross(vec2) #cross Plane...
                                        	#midpoints
                                        	mp1 = p1.offset(vec1, vec1.length/2)
                                        	mp2 = p1.offset(vec2, vec2.length/2)
                                        	#cross vectors..
                                        	vec1 = vec1.cross(fakeZ)
                                        	vec2 = vec2.cross(fakeZ)
                                        	#lines
                                        	line1 = [mp1, vec1]
                                        	line2 = [mp2, vec2]
                                        	return c = Geom.intersect_line_line(line1, line2) #point3D
                                        edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                                        • renderizaR
                                          renderiza
                                          It works! 😍
                                          http://s9.postimg.org/3oou2krkf/yay.jpg
                                          Here is the code...
                                              v = face.vertices
                                              cx = v[0].position.x + v[1].position.x + v[2].position.x
                                              cy = v[0].position.y + v[1].position.y + v[2].position.y
                                              cz = v[0].position.z + v[1].position.z + v[2].position.z
                                              px = cx / 3
                                              py = cy / 3
                                              pz = cz / 3
                                              v.each do |vertex|
                                                p1 = [px, py, pz]
                                                p2 = vertex
                                            sel.clear
                                          Note: At the moment the above code works with triangles only.
                                          For squares we can use the code bellow...
                                              v = face.vertices
                                              cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                                              cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                                              cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                                              px = cx / 4
                                              py = cy / 4
                                              pz = cz / 4
                                              v.each do |vertex|
                                                p1 = [px, py, pz]
                                                p2 = vertex
                                            sel.clear
                                          • renderizaR
                                            renderiza
                                            The following code will work on all geometry types like triangle, square, ect...
                                            @addx = []
                                            @addy = []
                                            @addz = []
                                                @addx.clear
                                                @addy.clear
                                                @addz.clear
                                                v = face.vertices
                                                num = v.length
                                                v.each_with_index {|vert,i|
                                                  @addx << " + v[#{i}].position.x"
                                                  @addy << " + v[#{i}].position.y"
                                                  @addz << " + v[#{i}].position.z"
                                                ax = @addx * ","
                                                sumx = ax.delete ","
                                                ay = @addy * ","
                                                sumy = ay.delete ","
                                                az = @addz * ","
                                                sumz = az.delete ","
                                                cx = eval("#{sumx}")
                                                cy = eval("#{sumy}")
                                                cz = eval("#{sumz}")
                                                px = cx / num
                                                py = cy / num
                                                pz = cz / num
                                                v.each do |vertex|
                                                  p1 = [px, py, pz]
                                                  p2 = vertex
                                              sel.clear
                                            Note: To test code above you can copy & paste it to one of this ruby consoles...
                                            http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                                            • 2 / 3
