    Triangulate triangles ?
    41 Posts 8 Posters 11.3k Views 8 Watching
    • renderizaR
      renderiza
      Here is an example code for achieving what you want Pilou...
      model = Sketchup.active_model
      ents = model.active_entities
      sel = model.selection
      faces = ents.grep(Sketchup;;Face)
      faces.each do |face|
        vertices = face.vertices
        bbox = face.bounds
        cpoint = bbox.center
        vertices.each do |vertex|
          p1 = cpoint
          p2 = vertex
          line = ents.add_line p1,p2
      Note: Some very pretty geometry start appearing when you keep splitting! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        I will do that! πŸ‘
          Beat me to it πŸ˜‰
          You might want to change the
          faces = ents.grep(Sketchup::Face)
          to
          faces = **sel**.grep(Sketchup::Face)
          So then the user changes only selected faces ?
          OR perhaps
          faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
          so it works on a selection OR everything if there is no selection...
          Also you want to make it undoable, so add
          **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
          πŸ€“
          • renderizaR
            renderiza
            Hahaha!
            TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. πŸ‘
            I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! πŸ’š
            By the way thanks for the suggestion! πŸ‘
            Here is updated code...
            faces = sel.grep(Sketchup;;Face)
            model.start_operation('csplit')
                bbox = face.bounds
                  p1 = cpoint
                  p2 = vertex
              sel.clear
              OK
              I'll make a simple script and publish it shortly...
              • renderizaR
                renderiza
                Thank you TIG! πŸ‘
                  anar
                  Thanks Pilou !
                  You convinced TIG...
                  And Thanks TIG, I think it's a must have !
                  http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                    Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                    TriangulateAllFaces...
                    • cottyC
                      cotty
                      I think the triangulation is not the same...
                      my SketchUp gallery
                      • renderizaR
                        renderiza
                        Both of these are very useful so maybe add an option to choose between the two.
                        http://s23.postimg.org/sp0h6r557/e_1.png
                          To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
                          πŸ˜•
                          • renderizaR
                            renderiza
                            Not as easy as using the center of face.bounds.center is it. πŸ˜•
                            If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
                            • renderizaR
                              renderiza
                              I sure don't call the code below a success but its definitely interesting...
                              http://s13.postimg.org/yerdljl8n/eee.jpg
                                  edges = face.edges
                                  bbox = face.bounds
                                 edges.each do |e|
                                    e1 = e.start.position
                                    e2 = e.end.position
                                    x = (e2.x + e1.x) / 2
                                    y = (e2.y + e1.y) / 2
                                    z = (e2.z + e1.z) / 2
                                      p1 = [x, y, z]
                                      p2 = vertex
                                sel.clear
                              Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                              • renderizaR
                                renderiza
                                If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
                                http://s15.postimg.org/3zyfm7ayz/pp1.jpg
                                • JQLJ
                                  JQL
                                  Renderiza,
                                  That's not success, that's brilliance!
                                  I'll start designing tiles right away...
                                  JQL
                                  www.casca.pt
                                  Visit us on facebook!
                                  • renderizaR
                                    renderiza
                                    Wish you success or better yet brilliance in your designs! πŸ’š
                                      you make big progress and be near the success! β˜€
                                      Why not take the image of the first post as "pseudo code" ?
                                      • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                                        (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                                      • draw 3 lines from this point to the 3 vertices
                                      Tig has finalized his "triangulate" method!
                                      Medians stay in race! πŸ˜„
                                      Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                                      • renderizaR
                                        renderiza
                                        Thanks guys! Will definitely study your suggestions. πŸ‘
                                        • jolranJ
                                          jolran
                                          I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                                          Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                                          I just ripped it out from a plugin I'm working on..
                                          # Arguments need 3 point3D objects from triangle.
                                          def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                                          	#Init Vectors for calculation.
                                          	vec1  = p1.vector_to(p2)
                                          	vec2  = p1.vector_to(p3)
                                          	fakeZ = vec1.cross(vec2) #cross Plane...
                                          	#midpoints
                                          	mp1 = p1.offset(vec1, vec1.length/2)
                                          	mp2 = p1.offset(vec2, vec2.length/2)
                                          	#cross vectors..
                                          	vec1 = vec1.cross(fakeZ)
                                          	vec2 = vec2.cross(fakeZ)
                                          	#lines
                                          	line1 = [mp1, vec1]
                                          	line2 = [mp2, vec2]
                                          	return c = Geom.intersect_line_line(line1, line2) #point3D
                                          edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                                          • renderizaR
                                            renderiza
                                            It works! 😍
                                            http://s9.postimg.org/3oou2krkf/yay.jpg
                                            Here is the code...
                                                v = face.vertices
                                                cx = v[0].position.x + v[1].position.x + v[2].position.x
                                                cy = v[0].position.y + v[1].position.y + v[2].position.y
                                                cz = v[0].position.z + v[1].position.z + v[2].position.z
                                                px = cx / 3
                                                py = cy / 3
                                                pz = cz / 3
                                                v.each do |vertex|
                                                  p1 = [px, py, pz]
                                                  p2 = vertex
                                              sel.clear
                                            Note: At the moment the above code works with triangles only.
                                            For squares we can use the code bellow...
                                                v = face.vertices
                                                cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                                                cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                                                cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                                                px = cx / 4
                                                py = cy / 4
                                                pz = cz / 4
                                                v.each do |vertex|
                                                  p1 = [px, py, pz]
                                                  p2 = vertex
                                              sel.clear
                                            • 2 / 3
