    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
    • renderizaR
      renderiza
      Both of these are very useful so maybe add an option to choose between the two.
      http://s23.postimg.org/sp0h6r557/e_1.png
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
        πŸ˜•
        • renderizaR
          renderiza
          Not as easy as using the center of face.bounds.center is it. πŸ˜•
          If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
          • renderizaR
            renderiza
            I sure don't call the code below a success but its definitely interesting...
            http://s13.postimg.org/yerdljl8n/eee.jpg
            model = Sketchup.active_model
            ents = model.active_entities
            sel = model.selection
            faces = sel.grep(Sketchup;;Face)
            model.start_operation('csplit')
              faces.each do |face|
                vertices = face.vertices
                edges = face.edges
                bbox = face.bounds
                cpoint = bbox.center
               edges.each do |e|
                  e1 = e.start.position
                  e2 = e.end.position
                  x = (e2.x + e1.x) / 2
                  y = (e2.y + e1.y) / 2
                  z = (e2.z + e1.z) / 2
                  vertices.each do |vertex|
                    p1 = [x, y, z]
                    p2 = vertex
                    line = ents.add_line p1,p2
              sel.clear
            model.commit_operation
            Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
            • renderizaR
              renderiza
              If the second time you apply script you do each face individually inside a group, then you get very pretty geometry. πŸ˜›
              http://s15.postimg.org/3zyfm7ayz/pp1.jpg
              • JQLJ
                JQL
                Renderiza,
                That's not success, that's brilliance!
                I'll start designing tiles right away...
                JQL
                www.casca.pt
                Visit us on facebook!
                • renderizaR
                  renderiza
                  Wish you success or better yet brilliance in your designs! πŸ’š
                    you make big progress and be near the success! β˜€
                    Why not take the image of the first post as "pseudo code" ?
                    • Calculate the point x,y,z crossing of 2 lines from 2 vertices to their middle opposite edge
                      (point can be also the calculate center of gravity of 3 points! πŸ˜‰
                    • draw 3 lines from this point to the 3 vertices
                    Tig has finalized his "triangulate" method!
                    Medians stay in race! πŸ˜„
                    Triangulate all faces by Tig (function was repeated for a sort of fractal system - only 3 triangles at start)
                    • renderizaR
                      renderiza
                      Thanks guys! Will definitely study your suggestions. πŸ‘
                      • jolranJ
                        jolran
                        I Think you could use the circumcentre as well, for skewed triangles.. Maybe that's what Pilou is trying to Point out.
                        Here's some code I'm using for that. You might have to rewrite it to fit your needs..
                        I just ripped it out from a plugin I'm working on..
                        # Arguments need 3 point3D objects from triangle.
                        def points3_circumC(p1,p2,p3) #(Only 2 lines is actually needed for calculation)
                        	#Init Vectors for calculation.
                        	vec1  = p1.vector_to(p2)
                        	vec2  = p1.vector_to(p3)
                        	fakeZ = vec1.cross(vec2) #cross Plane...
                        	#midpoints
                        	mp1 = p1.offset(vec1, vec1.length/2)
                        	mp2 = p1.offset(vec2, vec2.length/2)
                        	#cross vectors..
                        	vec1 = vec1.cross(fakeZ)
                        	vec2 = vec2.cross(fakeZ)
                        	#lines
                        	line1 = [mp1, vec1]
                        	line2 = [mp2, vec2]
                        	return c = Geom.intersect_line_line(line1, line2) #point3D
                        edit: Ehh.. looks like TIG already bashed out a working plugin for this.
                        • renderizaR
                          renderiza
                          It works! 😍
                          http://s9.postimg.org/3oou2krkf/yay.jpg
                          Here is the code...
                              v = face.vertices
                              cx = v[0].position.x + v[1].position.x + v[2].position.x
                              cy = v[0].position.y + v[1].position.y + v[2].position.y
                              cz = v[0].position.z + v[1].position.z + v[2].position.z
                              px = cx / 3
                              py = cy / 3
                              pz = cz / 3
                              v.each do |vertex|
                                p1 = [px, py, pz]
                                p2 = vertex
                            sel.clear
                          Note: At the moment the above code works with triangles only.
                          For squares we can use the code bellow...
                              v = face.vertices
                              cx = v[0].position.x + v[1].position.x + v[2].position.x + v[3].position.x
                              cy = v[0].position.y + v[1].position.y + v[2].position.y + v[3].position.y
                              cz = v[0].position.z + v[1].position.z + v[2].position.z + v[3].position.z
                              px = cx / 4
                              py = cy / 4
                              pz = cz / 4
                              v.each do |vertex|
                                p1 = [px, py, pz]
                                p2 = vertex
                            sel.clear
                          • renderizaR
                            renderiza
                            The following code will work on all geometry types like triangle, square, ect...
                            @addx = []
                            @addy = []
                            @addz = []
                                @addx.clear
                                @addy.clear
                                @addz.clear
                                v = face.vertices
                                num = v.length
                                v.each_with_index {|vert,i|
                                  @addx << " + v[#{i}].position.x"
                                  @addy << " + v[#{i}].position.y"
                                  @addz << " + v[#{i}].position.z"
                                ax = @addx * ","
                                sumx = ax.delete ","
                                ay = @addy * ","
                                sumy = ay.delete ","
                                az = @addz * ","
                                sumz = az.delete ","
                                cx = eval("#{sumx}")
                                cy = eval("#{sumy}")
                                cz = eval("#{sumz}")
                                px = cx / num
                                py = cy / num
                                pz = cz / num
                                v.each do |vertex|
                                  p1 = [px, py, pz]
                                  p2 = vertex
                              sel.clear
                            Note: To test code above you can copy & paste it to one of this ruby consoles...
                            http://renderizastudio.blogspot.com/2013/06/top-ruby-consoles-for-sketchup.html
                            • renderizaR
                              renderiza
                              With the help of Dan Rathbun the code was improved! Because string manipulation in Ruby can be slow he figured a way to do it without strings.
                              Here is the new code...
                                def csplit()
                                      sum = Geom;;Point3d.new(0,0,0)
                                      verts = face.vertices
                                      n = verts.size.to_f
                                      # use API Geom;;Point3d.+ instance method;
                                      verts.each {|v| sum += ORIGIN.vector_to(v.position) }
                                      avg = Geom;;Point3d.new( sum.x/n, sum.y/n, sum.z/n )
                                      verts.each {|v| ents.add_line( avg, v ) }
                                    end # each face
                                rescue => e
                                  puts "Error <#{e.class.name}; #{e.message} >"
                                  puts e.backtrace if $VERBOSE
                                  model.abort_operation
                                else # when no errors;
                                  sel.clear
                                end # csplit()
                                csplit()
                              If you have the time make sure to thank Dan...Cheers!
                                Seems very cool! πŸ‘
                                Waiting the definitive little plugin more easy than a copy past inside the ruby console! πŸ˜‰
                                And you will your name in the index Plugin automatic list by Jim! 😎
                                • renderizaR
                                  renderiza
                                  Ok I will start working on that ASAP!!!
                                  By the way you like the name "FaceSplit"?
                                    "Bermuda's Triangles' Gravity" will be also funny! πŸ˜‰
                                    https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQVDrKcLEC7T4VaspbQcQc_3tRmnEFfnCvFR7lAKksR_Dcd6PSkIQ
                                    • renderizaR
                                      renderiza
                                      I am glad you liked "FaceSplit"! 🀣
                                      • renderizaR
                                        renderiza
                                        Here is the logo...
                                        Big:
                                        http://s8.postimg.org/f4mis2579/Face_Split.png
                                        Small:
                                        http://s14.postimg.org/4n72xxfrh/Face_Split54.png
                                        • renderizaR
                                          renderiza
                                          Here is the plugin main page... http://sketchucation.com/forums/viewtopic.php?p=495689#p495689
                                          I used FaceSplit as name but if you guys come up with better name that is short & catchy then it will be easy to change.'
                                          Cheers! πŸ‘
                                            Bravo!
                                            Seems fabulous after this studious working weekend! 😎
                                            • 2 / 3
