    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • KrassK
      Krass
      Hello, pixelcruncher,
      I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
      Krass
      • KrassK
        Krass
        Hello,
        Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
        Krass
        • KrassK
          Krass
          I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
          Krass
          • KrassK
            Krass
            ok, that's good, by purging sketchup, I can add sphere lights again
            Krass
            • pixelcruncherP
              @Krass said in Rayscaper New Releases:
              Great to hear!
              Hello,
              The lights take the names of the light components. Maybe I can add the option to rename the lights in Rayscaper itself?
              This feels like a bug, do you have a way to reproduce this?
              Cheers,
              Thomas
              • KrassK
                Krass
                Hello pixelcruncher, I will try later tips for renaming the lights component. Now, i'm rendering an image, I'm stucked
                Krass
                KrassK 1 Reply Last reply
                • KrassK
                  Krass @Krass
                  in this scene, a series of bulbs of the same type and two others for the individual lamps. And I end up with the list of numbers if I want to adjust the intensity... it would be necessary to have noted the number of each light that we add...
                  Krass
                  Reply Quote 2
                  • KrassK
                    Krass
                    Krass
                      OK, with the replacement of mats, some issues have been resolved. I have lightened this image to demonstrate what I think it a problem/issue. The cabinet doors here have a texture to them they have not had selected by me. Is this part of the ai changes? If it is, I am not a fan.
                      4 1000s 2081 x 1160  912945 tri 1m 07s GPU  Post pro increased exposure to 1.75.png
                      Rich O BrienR pixelcruncherP 2 Replies Last reply
                      • KrassK
                        Krass
                        hello,
                        yes, and under the hood and above the stove, the noise is too present (by the way, I like your rendering.) this noise problem on certain dark parts is recurrent with Rayscaper. But can you show a screenshot of the original texture that you applied to the kitchen furniture?Perhaps you could use a stronger emissive material for your light that illuminates the work surfaces, rather than a spotlight or sphere light?
                        Krass
                        • L
                          Looks like rayscaper is maturing well πŸ‘
                            @Mike-Amos said in Rayscaper New Releases:
                            Can you add more exact info like the number of passes?
                            That to me is not a texture. Looks like that area of the model is dark and RS is struggling to resolve fully.
                            Mike AmosM 1 Reply Last reply
                            • KrassK
                              Krass
                              an old project, rendered with Rayscaper photoshop retouching and AI upscale
                              Krass
                              Reply Quote 2
                              • KrassK
                                Krass
                                new project with last rayscaper version and light upscale
                                Krass
                                  Mike Amos @Rich O Brien
                                  @Rich-O-Brien
                                  Sorry, missed this, I go for the standard setting of 1,000 passes.
                                  • pixelcruncherP
                                    pixelcruncher Extension Creator @Mike Amos
                                    @Mike-Amos
                                    Are you talking about the black splotches in the area I annotated below? They are not different textures, just artifacts.
                                    Rich already mentioned it, but I think what's happening is that you still have a really noisy render, and then the denoiser will generate these black splotches. You can confirm that by disabling the denoiser and looking at the original image:
                                    Rayscaper is a path tracer and needs to find a path to the light sources. In case it's challenging to find the light source (for example, because they are blocked or can only reach secondary light sources), you would see a lot of noise in the render. As Rich mentioned, Raysaper might be struggling with the glass in the windows and finding it hard to find good light paths to your HDRI image, which is providing the ambient light for your scene.
                                    Check that the windows are made of a glass material that has the transparent option checked. This will ensure that the rays that are looking for lights don't see the glass at all. It's as if you don't have any glass for light rays. Of course, you would still see the reflections in the glass when you look at it directly. It's the best of both worlds, although not physically correct.
                                    You can also increase the number of samples/px, which will increase the render time.
                                    Let me know if this helps. I know it's a bit technical, so I'm happy to clarify.
                                    All the best,
                                    Thomas
                                    • pixelcruncherP
                                      @Krass
                                      Good to see you are getting great results with Rayscaper!
                                      • pixelcruncherP
                                        @Krass Fantastic, a good showcase for Rayscaper!
                                        I hope you don't mind, but I shared them on my X account.
                                        Rayscaper (@Rayscaper3d) on X
                                        Fantastic Rayscaper renders by Julien Fischel (https://t.co/07i1jaNiU6)!
                                        X (formerly Twitter) (x.com)
                                        Regards,
                                        Thomas
                                        • KrassK
                                          Krass
                                          With pleasure.
                                          Yes, @Mike-Amos, I also check "transparent shadows" on Pixel cruncher's advice. But I do indeed go up to 35,000 SPP with a 2K resolution. I don't activate denoiser, and if your graphics card is sufficient, it's still fast. Probably 20 or 30 minutes of rendering time.
                                          Krass
                                          • pixelcruncherP
                                            @Krass - I'm not sure if you've already noticed, but the denoiser is no longer destructive. You can disable/enable it in the viewport without having to restart the render. So you can actually check if the image looks good without having to go all the way to 35,000 samples/px:
                                            • 37
                                            • 38
                                            • 7 / 38
