    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
      sashapepperspray
      thank you for the new release.
      I noticed two bugs with this release
      1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
      2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
        [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
      • pixelcruncherP
        pixelcruncher Extension Creator @sashapepperspray
        Hey @sashapepperspray
        Okay, that's a bug. It should inherit the material of its parent component or group.
        Also a regression, this was reported by other users as well. I will make an update ASAP.
        This is definitely on my list. I don't want to commit to a hard date.
        Regards,
        Thomas
        S 1 Reply Last reply
          sashapepperspray
          thank you very much
          • majidM
            majid @Rich O Brien
            @Rich-O-Brien, These renders are jaw-dropping!
            • N
              nickchun
              I've just been trying out Rayscaper, albeit on an underpowered machine with no dedicated GPU.
              I have to say, its been a long time since I've used such an intuitive piece of software, without really needing to refer to the manual. Very much enjoyed using it and will be keeping an eye on it's development. The startup screen humour is genius as well, helps put you in the right frame of mind when starting work.
              Well done
              Reply Quote 3
              • pixelcruncherP
                pixelcruncher Extension Creator @nickchun
                @nickchun Thanks for the kind words! That made my day!
                Cheers,
                Thomas
                • KrassK
                  Krass
                  Hello, pixelcruncher,
                  I wasn't aware of this new version and am very happy to return to Rayscaper for new renderings!
                  Krass
                  • KrassK
                    Krass
                    Hello,
                    Is there a way to rename the lights? I'm lost, I can't adjust the intensity of a new bulb because they are numbers and I have to activate or deactivate each light to locate them.... thank you
                    Krass
                    • KrassK
                      Krass
                      I renamed the light sphere component and that's not the right solution, it disabled them all. And now I can't add any more light spheres, only the spotlights work...
                      Krass
                      • KrassK
                        Krass
                        ok, that's good, by purging sketchup, I can add sphere lights again
                        Krass
                        • pixelcruncherP
                          @Krass said in Rayscaper New Releases:
                          Great to hear!
                          Hello,
                          The lights take the names of the light components. Maybe I can add the option to rename the lights in Rayscaper itself?
                          This feels like a bug, do you have a way to reproduce this?
                          Cheers,
                          Thomas
                          • KrassK
                            Krass
                            Hello pixelcruncher, I will try later tips for renaming the lights component. Now, i'm rendering an image, I'm stucked
                            Krass
                            KrassK 1 Reply Last reply
                            • KrassK
                              Krass @Krass
                              in this scene, a series of bulbs of the same type and two others for the individual lamps. And I end up with the list of numbers if I want to adjust the intensity... it would be necessary to have noted the number of each light that we add...
                              Krass
                              Reply Quote 2
                              • KrassK
                                Krass
                                Krass
                                  OK, with the replacement of mats, some issues have been resolved. I have lightened this image to demonstrate what I think it a problem/issue. The cabinet doors here have a texture to them they have not had selected by me. Is this part of the ai changes? If it is, I am not a fan.
                                  4 1000s 2081 x 1160  912945 tri 1m 07s GPU  Post pro increased exposure to 1.75.png
                                  Rich O BrienR pixelcruncherP 2 Replies Last reply
                                  • KrassK
                                    Krass
                                    hello,
                                    yes, and under the hood and above the stove, the noise is too present (by the way, I like your rendering.) this noise problem on certain dark parts is recurrent with Rayscaper. But can you show a screenshot of the original texture that you applied to the kitchen furniture?Perhaps you could use a stronger emissive material for your light that illuminates the work surfaces, rather than a spotlight or sphere light?
                                    Krass
                                    • L
                                      Looks like rayscaper is maturing well πŸ‘
                                        @Mike-Amos said in Rayscaper New Releases:
                                        Can you add more exact info like the number of passes?
                                        That to me is not a texture. Looks like that area of the model is dark and RS is struggling to resolve fully.
                                        Mike AmosM 1 Reply Last reply
                                        • KrassK
                                          Krass
                                          an old project, rendered with Rayscaper photoshop retouching and AI upscale
                                          Krass
                                          Reply Quote 2
                                          • KrassK
                                            Krass
                                            new project with last rayscaper version and light upscale
                                            Krass
                                            • 37
                                            • 38
                                            • 7 / 38
