    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.7k Views 15 Watching
    • KrassK
      Krass
      I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
      Krass
        Rich O Brien Moderator @ntxdave
        @ntxdave said:
        Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
        Open Extensions > Sketchucation > ExtensionStore
        Search for Rayscaper and click install.
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @Rich O Brien
          @Rich-O-Brien OK, got the latest version installed now.
          I should have known this myself. DUH!
          Press F1...thank me later
          • G
            gabrielaher Newcomers
            How its takes to give the license via email???
            • pixelcruncherP
              pixelcruncher Extension Creator @Mike Amos
              Hey @Mike-Amos,
              Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
              • pixelcruncherP
                @Krass
                Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                Thanks,
                Thomas
                KrassK 1 Reply Last reply
                • pixelcruncherP
                  pixelcruncher Extension Creator @gabrielaher
                  Hi @gabrielaher ,
                  You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                  To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                  Let us know if you need more help.
                  Regards,
                  Thomas
                  • KrassK
                    Krass @pixelcruncher
                    @pixelcruncher said:
                    @Krass
                    Thanks,
                    Thomas
                    Hello, it's done, I sent you the file
                    Krass
                    • pixelcruncherP
                      Hey, Rayscaper users!
                      Rayscaper 0.9.94 Beta is available. You can get it via:
                      • The SketchUcation store.
                      • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
                      I recommend upgrading to the latest version.
                      What Changed?
                      • Fix occasional skewed or corrupted textures in renders.
                      • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
                      Full release notes: rayscaper.com/manual/release-notes
                      Help Me Build the Community 👍
                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                      and helps me showcase its capabilities to new users.
                      Follow me on X.
                      Happy Rendering!
                      Thomas
                      • pixelcruncherP
                        Rayscaper 0.9.95 Beta is available. You can get it via:
                        • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
                        What Changed?
                        • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
                        • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
                        • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
                        Follow me on X.
                        Happy Rendering!
                        Thomas
                        • KrassK
                          @pixelcruncher
                          Hello Thomas,
                          An exercise using a previous client project with version 0.9.95.
                          A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
                          Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
                          Followed by compositing the characters back onto my original Rayscaper render.
                          I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
                          raw RS 1080p render:
                          alt text
                          with characters:
                          alt text
                          Krass
                          Reply Quote 2
                          • pixelcruncherP
                            That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
                            • KrassK
                              Krass
                              I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
                              Krass
                              • KrassK
                                Krass
                                And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
                                Krass
                                • KrassK
                                  Krass
                                  hello Pixelcruncher,
                                  I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
                                  Krass
                                  • pixelcruncherP
                                    @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
                                    As a workaround, try reloading this material to see if it works.
                                    I will have a fix in the next release, which will land shortly.
                                    Regards,
                                    Thomas
                                    • KrassK
                                      Krass
                                      yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
                                      Krass
                                      • KrassK
                                        Krass
                                        One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
                                        Krass
                                        • KrassK
                                          Krass
                                          the Hide assets function is great !
                                          Krass
                                          • KrassK
                                            Krass
                                            I set the HDRI map resolution to the maximum, but it's quite blurry.
                                            Krass
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 37
                                            • 38
                                            • 24 / 38
