    Rayscaper New Releases
    rayscaperrender
    475 Posts 12 Posters 217.5k Views 13 Watching
    • ntxdaveN
      ntxdave
      Not sure now how I originally installed the extension, but I feel pretty confident I have updated it before via SketchUcation Tools. When I go to the SketchUp Extension manager, it says I have 0.9.92. I would like to update to the 0.9.93 version. Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
      Press F1...thank me later
      • KrassK
        Krass
        I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
        Krass
          Rich O Brien Moderator @ntxdave
          Open Extensions > Sketchucation > ExtensionStore
          Search for Rayscaper and click install.
          ntxdaveN 1 Reply Last reply
          • ntxdaveN
            ntxdave @Rich O Brien
            @Rich-O-Brien OK, got the latest version installed now.
            I should have known this myself. DUH!
            • G
              gabrielaher Newcomers
              How its takes to give the license via email???
              P 1 Reply Last reply
              • P
                pixelcruncher Extension Creator @Mike Amos
                Hey @Mike-Amos,
                Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
                • P
                  @Krass
                  Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                  Thanks,
                  Thomas
                  KrassK 1 Reply Last reply
                  • P
                    pixelcruncher Extension Creator @gabrielaher
                    Hi @gabrielaher ,
                    You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                    To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                    Let us know if you need more help.
                    Regards,
                    Thomas
                    • KrassK
                      Krass @pixelcruncher
                      @pixelcruncher said:
                      @Krass
                      Thanks,
                      Thomas
                      Hello, it's done, I sent you the file
                      Krass
                      • P
                        Hey, Rayscaper users!
                        Rayscaper 0.9.94 Beta is available. You can get it via:
                        • The SketchUcation store.
                        • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
                        I recommend upgrading to the latest version.
                        What Changed?
                        • Fix occasional skewed or corrupted textures in renders.
                        • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
                        Full release notes: rayscaper.com/manual/release-notes
                        Help Me Build the Community 👍
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                        and helps me showcase its capabilities to new users.
                        Follow me on X.
                        Happy Rendering!
                        Thomas
                        • P
                          Rayscaper 0.9.95 Beta is available. You can get it via:
                          • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
                          What Changed?
                          • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
                          • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
                          • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
                          Follow me on X.
                          Happy Rendering!
                          Thomas
                          • KrassK
                            @pixelcruncher
                            Hello Thomas,
                            An exercise using a previous client project with version 0.9.95.
                            A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
                            Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
                            Followed by compositing the characters back onto my original Rayscaper render.
                            I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
                            raw RS 1080p render:
                            alt text
                            with characters:
                            alt text
                            Krass
                            • P
                              That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
                              • KrassK
                                Krass
                                I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
                                Krass
                                • KrassK
                                  Krass
                                  And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
                                  Krass
                                  • KrassK
                                    Krass
                                    hello Pixelcruncher,
                                    I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
                                    Krass
                                    • P
                                      @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
                                      As a workaround, try reloading this material to see if it works.
                                      I will have a fix in the next release, which will land shortly.
                                      Regards,
                                      Thomas
                                      • KrassK
                                        Krass
                                        yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
                                        Krass
                                        • KrassK
                                          Krass
                                          One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
                                          Krass
                                          • KrassK
                                            Krass
                                            the Hide assets function is great !
                                            Krass
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 24 / 24
