    Rayscaper New Releases
    rayscaperrender
    475 Posts 12 Posters 217.5k Views 13 Watching
      The new build is good, when hiding the 'assets' panel the progress bar is also lost. Not a major issue as when it comes to labelling the render, unhiding the assets is doable.
      It would be useful when progress is slow as a stalled render is not so obvious when the progress bar is hidden.
      P 1 Reply Last reply
      • ntxdaveN
        ntxdave @pixelcruncher
        @pixelcruncher said:
        Rayscaper users, a heads up: I accidentally uploaded the previous 0.9.92 version to the SketchUcation Extension Store. If you installed Rayscaper in the last 4 days, you may have reinstalled the previous version. (@mike-amos Thanks for the heads up!).
        I’ve uploaded the latest 0.9.93 version now. If you download and install the extension again, it should install version 0.9.93 correctly.
        Apologies for the hassle.
        Happy Rendering!
        Thomas
        Is there a way within Rayscaper to update to the latest version? If not, is this something you could add to the ui?
        Press F1...thank me later
          On a few occasions I have downloaded the latest build and used the sketchup extension manager. This it what I have used for rollback to last version to check behaviour.
            Rich O Brien Moderator @ntxdave
            If you install extensions using Sketchucation Tools then it will prompt you to update. It has been that way for years.
            ntxdaveN 1 Reply Last reply
            • KrassK
              Krass
              hello, I'm trying this new version but I get a bugg, It doens't want to render anymore. I get this error message
              I will send you my log file
              Krass
              • ntxdaveN
                ntxdave @Rich O Brien
                I agree @rich-o-brien but when I went there yesterday it said it said all my extensions were up to date. I will look again today. That is what prompted my post.
                  There was an issue where the posted version of Rayscaper was incorrect, it had .92 as the latest. If you try again you will get .93 as the uploaded file has been corrected.
                  I can certify to this as I have now got the updated .93 installed.
                    If you installed extensions manually. That is you grab the RBZ off the site and install it via Extensions > Extension Manager then don't expect Sketchucation Tools to flag an update.
                    If you install extensions via Sketchucation Tools dialog then we prompt you to install future updates
                    • ntxdaveN
                      ntxdave
                      Not sure now how I originally installed the extension, but I feel pretty confident I have updated it before via SketchUcation Tools. When I go to the SketchUp Extension manager, it says I have 0.9.92. I would like to update to the 0.9.93 version. Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
                      • KrassK
                        Krass
                        I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
                        Krass
                          Open Extensions > Sketchucation > ExtensionStore
                          Search for Rayscaper and click install.
                          • ntxdaveN
                            @Rich-O-Brien OK, got the latest version installed now.
                            I should have known this myself. DUH!
                            • G
                              gabrielaher Newcomers
                              How its takes to give the license via email???
                              • P
                                pixelcruncher Extension Creator @Mike Amos
                                Hey @Mike-Amos,
                                Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
                                • P
                                  @Krass
                                  Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                                  Thanks,
                                  Thomas
                                  KrassK 1 Reply Last reply
                                  • P
                                    pixelcruncher Extension Creator @gabrielaher
                                    Hi @gabrielaher ,
                                    You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                                    To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                                    Let us know if you need more help.
                                    Regards,
                                    Thomas
                                    • KrassK
                                      Krass @pixelcruncher
                                      @Krass
                                      Thanks,
                                      Thomas
                                      Hello, it's done, I sent you the file
                                      Krass
                                      • P
                                        Hey, Rayscaper users!
                                        Rayscaper 0.9.94 Beta is available. You can get it via:
                                        • The SketchUcation store.
                                        • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
                                        I recommend upgrading to the latest version.
                                        What Changed?
                                        • Fix occasional skewed or corrupted textures in renders.
                                        • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
                                        Full release notes: rayscaper.com/manual/release-notes
                                        Help Me Build the Community 👍
                                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                                        and helps me showcase its capabilities to new users.
                                        Follow me on X.
                                        Happy Rendering!
                                        Thomas
                                        • P
                                          Rayscaper 0.9.95 Beta is available. You can get it via:
                                          • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
                                          What Changed?
                                          • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
                                          • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
                                          • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
                                          Follow me on X.
                                          Happy Rendering!
                                          Thomas
                                          • KrassK
                                            @pixelcruncher
                                            Hello Thomas,
                                            An exercise using a previous client project with version 0.9.95.
                                            A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
                                            Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
                                            Followed by compositing the characters back onto my original Rayscaper render.
                                            I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
                                            raw RS 1080p render:
                                            alt text
                                            with characters:
                                            alt text
                                            Krass
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 23 / 24
