    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • KrassK
      Krass
      hello, I'm trying this new version but I get a bugg, It doens't want to render anymore. I get this error message
      I will send you my log file
      Krass
      • ntxdaveN
        ntxdave @Rich O Brien
        @Rich-O-Brien said:
        @ntxdave said:
        Is there a way within Rayscaper to update to the latest version? If not, is this something you could add to the ui?
        If you install extensions using Sketchucation Tools then it will prompt you to update. It has been that way for years.
        I agree @rich-o-brien but when I went there yesterday it said it said all my extensions were up to date. I will look again today. That is what prompted my post.
        Press F1...thank me later
          There was an issue where the posted version of Rayscaper was incorrect, it had .92 as the latest. If you try again you will get .93 as the uploaded file has been corrected.
          I can certify to this as I have now got the updated .93 installed.
            Rich O Brien Moderator @ntxdave
            If you installed extensions manually. That is you grab the RBZ off the site and install it via Extensions > Extension Manager then don't expect Sketchucation Tools to flag an update.
            If you install extensions via Sketchucation Tools dialog then we prompt you to install future updates
            • ntxdaveN
              ntxdave
              Not sure now how I originally installed the extension, but I feel pretty confident I have updated it before via SketchUcation Tools. When I go to the SketchUp Extension manager, it says I have 0.9.92. I would like to update to the 0.9.93 version. Does this mean I need to download the new version and install if "from scratch" or is there some way I can do it via SketchUcation Tools?
              • KrassK
                Krass
                I should point out that I initially succeeded with a project in version 93. Then this problem occurred.
                Krass
                  Open Extensions > Sketchucation > ExtensionStore
                  Search for Rayscaper and click install.
                  ntxdaveN 1 Reply Last reply
                  • ntxdaveN
                    @Rich-O-Brien OK, got the latest version installed now.
                    I should have known this myself. DUH!
                    • G
                      gabrielaher Newcomers
                      How its takes to give the license via email???
                      • pixelcruncherP
                        pixelcruncher Extension Creator @Mike Amos
                        Hey @Mike-Amos,
                        Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
                        • pixelcruncherP
                          @Krass
                          Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
                          Thanks,
                          Thomas
                          KrassK 1 Reply Last reply
                          • pixelcruncherP
                            pixelcruncher Extension Creator @gabrielaher
                            Hi @gabrielaher ,
                            You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
                            To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
                            Let us know if you need more help.
                            Regards,
                            Thomas
                            • KrassK
                              Krass @pixelcruncher
                              @pixelcruncher said:
                              @Krass
                              Thanks,
                              Thomas
                              Hello, it's done, I sent you the file
                              Krass
                              • pixelcruncherP
                                Hey, Rayscaper users!
                                Rayscaper 0.9.94 Beta is available. You can get it via:
                                • The SketchUcation store.
                                • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
                                I recommend upgrading to the latest version.
                                What Changed?
                                • Fix occasional skewed or corrupted textures in renders.
                                • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
                                Full release notes: rayscaper.com/manual/release-notes
                                Help Me Build the Community 👍
                                If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                                and helps me showcase its capabilities to new users.
                                Follow me on X.
                                Happy Rendering!
                                Thomas
                                • pixelcruncherP
                                  Rayscaper 0.9.95 Beta is available. You can get it via:
                                  • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
                                  What Changed?
                                  • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
                                  • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
                                  • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
                                  Follow me on X.
                                  Happy Rendering!
                                  Thomas
                                  • KrassK
                                    @pixelcruncher
                                    Hello Thomas,
                                    An exercise using a previous client project with version 0.9.95.
                                    A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
                                    Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
                                    Followed by compositing the characters back onto my original Rayscaper render.
                                    I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
                                    raw RS 1080p render:
                                    alt text
                                    with characters:
                                    alt text
                                    Krass
                                    Reply Quote 2
                                    • pixelcruncherP
                                      That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
                                      • KrassK
                                        Krass
                                        I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
                                        Krass
                                        • KrassK
                                          Krass
                                          And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
                                          Krass
                                          • KrassK
                                            Krass
                                            hello Pixelcruncher,
                                            I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
                                            Krass
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 37
                                            • 38
                                            • 23 / 38
