    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.7k Views 15 Watching
    • KrassK
      Krass @pixelcruncher
      @pixelcruncher
      Hello Thomas,
      An exercise using a previous client project with version 0.9.95.
      A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
      Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
      Followed by compositing the characters back onto my original Rayscaper render.
      I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
      raw RS 1080p render:
      alt text
      with characters:
      alt text
      Krass
      Reply Quote 2
      • pixelcruncherP
        That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
        • KrassK
          Krass
          I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
          Krass
          • KrassK
            Krass
            And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
            Krass
            • KrassK
              Krass
              hello Pixelcruncher,
              I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
              Krass
              • pixelcruncherP
                @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
                As a workaround, try reloading this material to see if it works.
                I will have a fix in the next release, which will land shortly.
                Regards,
                Thomas
                • KrassK
                  Krass
                  yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
                  Krass
                  • KrassK
                    Krass
                    One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
                    Krass
                    • KrassK
                      Krass
                      the Hide assets function is great !
                      Krass
                      • KrassK
                        Krass
                        I set the HDRI map resolution to the maximum, but it's quite blurry.
                        Krass
                        • KrassK
                          Krass
                          I reloaded the HDRI from Polyhaven. Here are some views with the latest version of Rayscaper. For a bird's eye view chat GPT only produced the context, the background.
                          Krass
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Rayscaper 0.9.96 Beta is available. You can get it via:
                            • The SketchUcation store.
                            • Direct download: Rayscaper_Win_0.9.96_Beta.rbz.
                            I recommend upgrading to the latest version. This release is all about water and light 🌊💡
                            New: Water Material
                            Rayscaper now has a dedicated Water material for pools, ponds, lakes and spas. Assign it to a single face or a closed box, pick a preset, and you're done.
                            • Realistic waves: layered swell and fine ripples, with direction, size and strength controls.
                            • Depth you can see: water gets darker and more tinted as it gets deeper, so a pool's deep end actually looks deep.
                            • Controllable reflections: from crisp mirror-like water at sunset to soft, choppy reflections.
                            Clarity controls how far you can see into the water:
                            It ships with presets to get you started, including the new Tropical, Reflecting Pool and Spa.
                            New: IES Light Profiles for Spotlights
                            Spotlights can now use IES profiles for realistic, architectural light patterns: batwing, wall wash, narrow and medium spot, wide flood and elliptical beam. The light editor shows a preview of each distribution so you can see what you're picking.
                            Other Improvements
                            • Add procedural material previews, so material thumbnails render faster and no longer hang.
                            • Select newly placed lights automatically and show the active light tool in the toolbar.
                            • Refresh the user interface with a consistent set of toolbar icons, sharper icon scaling, clearer list selection, and a tidier settings layout.
                            Fixes
                            • Fix textures rendering cyan after editing a texture image in an external editor, saving, and reopening the model.
                            • Fix vignette falloff at high strength.
                            Full release notes: rayscaper.com/manual/release-notes
                            Help Me Build the Community 👍
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                            and helps me showcase its capabilities to new users.
                            Follow me on X.
                            Happy Rendering!
                            Thomas
                            • KrassK
                              Krass
                              Great, thanks Thomas. I needed water materials this morning and you granted my wish tonight...!
                              Krass
                              • pixelcruncherP
                                @Krass I will be waiting for those awesome renders!
                                • KrassK
                                  Krass
                                  rayscayper pool with water material
                                  Krass
                                  • pixelcruncherP
                                    @Krass Nice!
                                    • KrassK
                                      Krass
                                      I really like the two buttons for hiding the settings and assets—you can quickly switch to a large-scale view of the render—and the minimalist icon design.
                                      And this time, it successfully loaded the HDRI map at full resolution
                                      for this render, which features actual waves in the geometry.
                                      Krass
                                        Sharp, I am missing the splash where my ex jumped in to create the waves though.......
                                        • KrassK
                                          Krass
                                          yes, but 3D splash is very hy skill !
                                          The pool on the screen is an "infinity pool"; I wouldn't have the patience right now to model that in SketchUp... then again, maybe I would? But AI does it in a couple of quick moves.
                                          And if you send me a photo of your ex, she (he) will be in the image!
                                          Krass
                                            I tried but the camera broke, or I had a tree in the way. Not sure which.
                                            Either way fangs for the memories is about as far as I go these days. It is a fine Mr Kipling image tho'.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 37
                                            • 38
                                            • 24 / 38
