    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.7k Views 15 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @Mike Amos
      Hey @Mike-Amos,
      Could you provide a screenshot? Here's what I see when hiding the assets panel. As you can see I still have a progress bar, so I think we are talking about different things:
      • pixelcruncherP
        @Krass
        Thanks for the report, I can confirm the error with GPU rendering. Would you mind sending me the scene so I can try to reproduce the error?
        Thanks,
        Thomas
        KrassK 1 Reply Last reply
        • pixelcruncherP
          pixelcruncher Extension Creator @gabrielaher
          Hi @gabrielaher ,
          You can buy a Rayscaper license here (if you are logged in): https://sketchucation.com/purchase-smart.php?plugin=rayscaper
          To manage a license you already have, you can do that here: https://sketchucation.com/webshop/my-licences.php
          Let us know if you need more help.
          Regards,
          Thomas
          • KrassK
            Krass @pixelcruncher
            @pixelcruncher said:
            @Krass
            Thanks,
            Thomas
            Hello, it's done, I sent you the file
            Krass
            • pixelcruncherP
              Hey, Rayscaper users!
              Rayscaper 0.9.94 Beta is available. You can get it via:
              • The SketchUcation store.
              • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
              I recommend upgrading to the latest version.
              What Changed?
              • Fix occasional skewed or corrupted textures in renders.
              • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
              Full release notes: rayscaper.com/manual/release-notes
              Help Me Build the Community 👍
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
              and helps me showcase its capabilities to new users.
              Follow me on X.
              Happy Rendering!
              Thomas
              • pixelcruncherP
                Rayscaper 0.9.95 Beta is available. You can get it via:
                • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
                What Changed?
                • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
                • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
                • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
                Follow me on X.
                Happy Rendering!
                Thomas
                • KrassK
                  @pixelcruncher
                  Hello Thomas,
                  An exercise using a previous client project with version 0.9.95.
                  A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
                  Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
                  Followed by compositing the characters back onto my original Rayscaper render.
                  I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
                  raw RS 1080p render:
                  alt text
                  with characters:
                  alt text
                  Krass
                  Reply Quote 2
                  • pixelcruncherP
                    That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
                    • KrassK
                      Krass
                      I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
                      Krass
                      • KrassK
                        Krass
                        And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
                        Krass
                        • KrassK
                          Krass
                          hello Pixelcruncher,
                          I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
                          Krass
                          • pixelcruncherP
                            @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
                            As a workaround, try reloading this material to see if it works.
                            I will have a fix in the next release, which will land shortly.
                            Regards,
                            Thomas
                            • KrassK
                              Krass
                              yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
                              Krass
                              • KrassK
                                Krass
                                One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
                                Krass
                                • KrassK
                                  Krass
                                  the Hide assets function is great !
                                  Krass
                                  • KrassK
                                    Krass
                                    I set the HDRI map resolution to the maximum, but it's quite blurry.
                                    Krass
                                    • KrassK
                                      Krass
                                      I reloaded the HDRI from Polyhaven. Here are some views with the latest version of Rayscaper. For a bird's eye view chat GPT only produced the context, the background.
                                      Krass
                                      • pixelcruncherP
                                        Rayscaper 0.9.96 Beta is available. You can get it via:
                                        • Direct download: Rayscaper_Win_0.9.96_Beta.rbz.
                                        I recommend upgrading to the latest version. This release is all about water and light 🌊💡
                                        New: Water Material
                                        Rayscaper now has a dedicated Water material for pools, ponds, lakes and spas. Assign it to a single face or a closed box, pick a preset, and you're done.
                                        • Realistic waves: layered swell and fine ripples, with direction, size and strength controls.
                                        • Depth you can see: water gets darker and more tinted as it gets deeper, so a pool's deep end actually looks deep.
                                        • Controllable reflections: from crisp mirror-like water at sunset to soft, choppy reflections.
                                        Clarity controls how far you can see into the water:
                                        It ships with presets to get you started, including the new Tropical, Reflecting Pool and Spa.
                                        New: IES Light Profiles for Spotlights
                                        Spotlights can now use IES profiles for realistic, architectural light patterns: batwing, wall wash, narrow and medium spot, wide flood and elliptical beam. The light editor shows a preview of each distribution so you can see what you're picking.
                                        Other Improvements
                                        • Add procedural material previews, so material thumbnails render faster and no longer hang.
                                        • Select newly placed lights automatically and show the active light tool in the toolbar.
                                        • Refresh the user interface with a consistent set of toolbar icons, sharper icon scaling, clearer list selection, and a tidier settings layout.
                                        Fixes
                                        • Fix textures rendering cyan after editing a texture image in an external editor, saving, and reopening the model.
                                        • Fix vignette falloff at high strength.
                                        Follow me on X.
                                        Happy Rendering!
                                        Thomas
                                        • KrassK
                                          Krass
                                          Great, thanks Thomas. I needed water materials this morning and you granted my wish tonight...!
                                          Krass
                                          • pixelcruncherP
                                            @Krass I will be waiting for those awesome renders!
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 39
                                            • 40
                                            • 24 / 40
