The "Duh!" thread (aka the Doh! thread)
01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
It wasn't... but
0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
I think I got geek all over me
100001 11000 1110 100011 1100 10001 100100 11110
Found a cool one today.
Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
-Brodie
Duh!
That is sweet!
The manual doesn't even mention this!
http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863 -
It even works with circular arrays - just type in the angle in degrees
However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
-Brodie
-Brodie
This, sir, just made my day!
+1
-Brodie
I just wish you found this last week, when I needed it.
-Brodie
I learned that just a couple months ago from Dave R at a local meetup
Shift + Eraser to smooth...
I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
Ah... feels good to share my stupidity!
Ctrl+ eraser is to smooth. Shift+eraser is to hide.
Ctrl+Erase = Soft+Smooth
Shift+Erase = Hide
Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!) -
Shift+Erase = Hide
Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']... -
@tig said:
Shift+Erase = Hide
Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']..."Learn something new everyday!"
In this case... several new things.
-Brodie
Duh!
That is sweet!
http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863Seems that is more missing here
http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic -
You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
To 'divide' the copies use /2...
You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [°] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
