    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
      mrossk
      I think I got geek all over me πŸ˜‰
      https://www.mkaplanfinefurniture.com/
        πŸ’š
        	100001
        	11000
        	1110
        	100011
        	1100
        	10001
        	100100
        	11110
          Found a cool one today.
          Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
          What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
          However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
          -Brodie
          Duh!
          That is sweet!
          The manual doesn't even mention this!
          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
          • H
            Heaps
            It even works with circular arrays - just type in the angle in degrees
            • brodieB
              brodie
              However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
              -Brodie
              • broomstickB
                broomstick
                -Brodie
                This, sir, just made my day!
                • Bob JamesB
                  Bob James
                  • jgbJ
                    jgb
                    Found a cool one today. πŸ˜’
                    -Brodie
                    I just wish you found this last week, when I needed it. πŸ˜†
                    jgb
                      d12dozr
                      -Brodie
                      I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                      http://goo.gl/f7ooYh
                      • aarondietzenA
                        aarondietzen
                        Shift + Eraser to smooth...
                        I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                        Ah... feels good to share my stupidity!
                        "Imagination is more important than knowledge..."
                        - Albert Einstein
                        • massimoM
                          massimo Moderator
                          Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                          • aarondietzenA
                            aarondietzen
                            Stupidity x2! πŸ˜†
                            - Albert Einstein
                              Ctrl+Erase = Soft+Smooth
                              Shift+Erase = Hide
                              Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                                Shift+Erase = Hide
                                Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                • aarondietzenA
                                  aarondietzen
                                  @tig said:
                                  Shift+Erase = Hide
                                  "Learn something new everyday!"
                                  In this case... several new things.
                                  - Albert Einstein
                                    -Brodie
                                    Duh!
                                    That is sweet!
                                    Seems that is more missing here πŸ˜‰
                                    http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                                    • emerald15E
                                      emerald15
                                      You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                        Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
                                        To 'divide' the copies use /2...
                                        You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...
                                        Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [Β°] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
                                        • jgbJ
                                          jgb
                                          This is also a question, based on the above.
                                          Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
                                          OK, my question, How do I set scale to a dimensional value?
                                          ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
                                          jgb
                                            Just scale roughly first - then use the VCB to adjust with accuracy afterwards - typing in the length.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
