    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • H
      Heaps
      It even works with circular arrays - just type in the angle in degrees
      • brodieB
        brodie
        Found a cool one today.
        Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
        What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
        However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
        -Brodie
        • broomstickB
          broomstick
          -Brodie
          This, sir, just made my day!
          • Bob JamesB
            Bob James
            • jgbJ
              jgb
              Found a cool one today. ๐Ÿ˜’
              -Brodie
              I just wish you found this last week, when I needed it. ๐Ÿ˜†
              jgb
                d12dozr
                -Brodie
                I learned that just a couple months ago from Dave R at a local meetup ๐Ÿ‘
                http://goo.gl/f7ooYh
                • aarondietzenA
                  aarondietzen
                  Shift + Eraser to smooth...
                  I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                  Ah... feels good to share my stupidity!
                  "Imagination is more important than knowledge..."
                  - Albert Einstein
                  • massimoM
                    massimo Moderator
                    Ctrl+ eraser is to smooth. Shift+eraser is to hide. ๐Ÿ˜‰
                    • aarondietzenA
                      aarondietzen
                      Stupidity x2! ๐Ÿ˜†
                      - Albert Einstein
                        Ctrl+Erase = Soft+Smooth
                        Shift+Erase = Hide
                        Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                          Shift+Erase = Hide
                          Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                          • aarondietzenA
                            aarondietzen
                            @tig said:
                            Shift+Erase = Hide
                            "Learn something new everyday!"
                            In this case... several new things.
                            - Albert Einstein
                              However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                              -Brodie
                              Duh!
                              That is sweet!
                              The manual doesn't even mention this!
                              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                              Seems that is more missing here ๐Ÿ˜‰
                              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                              • emerald15E
                                emerald15
                                You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                  Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
                                  To 'divide' the copies use /2...
                                  You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...
                                  Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [ยฐ] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
                                  • jgbJ
                                    jgb
                                    This is also a question, based on the above.
                                    Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
                                    OK, my question, How do I set scale to a dimensional value?
                                    ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
                                    jgb
                                      Just scale roughly first - then use the VCB to adjust with accuracy afterwards - typing in the length.
                                        Just draw a 13 inch segment from a vertex from your object and Scale your object by the line! ๐Ÿ˜‰
                                        Alas this just work only with "cubic" objects! ๐Ÿค“
                                        If you have inclined faces you must don't use the native Scale tool!!!
                                          Pull out to approximate size [using any modifier keys you desire], then immediately type in the required size, before selecting another tool.
                                          The length has to have a 'units suffix'.
                                          Type 13 will make it 13x bigger ! but 13" makes it exactly 13 inches, or 330mm which makes it exactly that size in mm, this is done irrespective of the model's current-unit settings...
                                          • jgbJ
                                            jgb
                                            Post by Pilou on Wed, 15 Aug 2012 10:57 am
                                            Yeah, I do that, thanks. ๐Ÿ‘
                                            Post by thomthom on Wed, 15 Aug 2012 10:59 am
                                            Can't seem to make it work. I type the value but when I type the " (inch) it erases the value. ๐Ÿ˜ข
                                            I noticed that when I press the SHIFT key, the VCB shows me the ratios of each axis, which is handy. ๐Ÿ˜ฎ
                                            You can then adjust the ratios of each axis in the VCB using a comma to separate the % values in the same order as the axis ref to its left. โ˜€
                                            AND you can post adjust the size to a dimension but only in FEET, not inches. ๐Ÿ˜
                                            jgb
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
