    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
      It wasn't... but
      0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
        mrossk
        I think I got geek all over me πŸ˜‰
        https://www.mkaplanfinefurniture.com/
          πŸ’š
          	100001
          	11000
          	1110
          	100011
          	1100
          	10001
          	100100
          	11110
            Found a cool one today.
            Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
            What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
            However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
            -Brodie
            Duh!
            That is sweet!
            The manual doesn't even mention this!
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
            • H
              Heaps
              It even works with circular arrays - just type in the angle in degrees
              • brodieB
                brodie
                However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                -Brodie
                • broomstickB
                  broomstick
                  -Brodie
                  This, sir, just made my day!
                  • Bob JamesB
                    Bob James
                    • jgbJ
                      jgb
                      Found a cool one today. πŸ˜’
                      -Brodie
                      I just wish you found this last week, when I needed it. πŸ˜†
                      jgb
                        d12dozr
                        -Brodie
                        I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                        http://goo.gl/f7ooYh
                        • aarondietzenA
                          aarondietzen
                          Shift + Eraser to smooth...
                          I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                          Ah... feels good to share my stupidity!
                          "Imagination is more important than knowledge..."
                          - Albert Einstein
                          • massimoM
                            massimo Moderator
                            Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                            • aarondietzenA
                              aarondietzen
                              Stupidity x2! πŸ˜†
                              - Albert Einstein
                                Ctrl+Erase = Soft+Smooth
                                Shift+Erase = Hide
                                Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                                  Shift+Erase = Hide
                                  Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                  • aarondietzenA
                                    aarondietzen
                                    @tig said:
                                    Shift+Erase = Hide
                                    "Learn something new everyday!"
                                    In this case... several new things.
                                    - Albert Einstein
                                      -Brodie
                                      Duh!
                                      That is sweet!
                                      Seems that is more missing here πŸ˜‰
                                      http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                                      • emerald15E
                                        emerald15
                                        You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                          Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
                                          To 'divide' the copies use /2...
                                          You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...
                                          Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [Β°] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
                                          • jgbJ
                                            jgb
                                            This is also a question, based on the above.
                                            Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
                                            OK, my question, How do I set scale to a dimensional value?
                                            ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
                                            jgb
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
