    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.5k Views 135 Watching
      rv1974
      The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
      Clicking it wont change visually its state (stupid bug!). To see it changed one should move
      the cursor off the button.
      • I
        iecovert
        %(#400080)[ALL toolbars can be mounted on the top OR the side! Not just the SU tools.
        I've got an increasing number of toolbars mounted up top since that's the way they first show up when a plugin is installed. The decreasing workspace was becoming an issue. The original SU toolbars mount vertically, so I set out to figure out how I could make the new Ruby and plugin toolbars mount vertically too. That seems to make more sense with a widescreen monitor. Spent several hours searching through the forums, help topics, and eventually digging into various Ruby scripts trying to figure it out over the past two weeks. Then last night I was moving a floating toolbar window and grabbed it a little to close to the edge and... it "stretched" out vertically. 🀣 Finally...]
          Aerilius
          (This belongs probably also into the developers forums:)
          window.onerror = function(errorMsg, url, lineNumber){ return true }
          This catches WebDialog script error popups (should they still sometimes occur after thorough testing)!
          Why didn't I find that before?
          Note: It needs to be assigned directly to %(#000000)[window] and not attached like %(#000000)[$(window).bind("error", function(){})].
          • GaieusG
            Interesting. I do not have that "duh moment" reading this. πŸ˜†
            • jeff hammondJ
              same here… more like an "uhhhhh πŸ˜• moment"
              πŸ˜†
              • kenK
                ken
                I guess I could call this "The Well I'll be Darn Thread". I have used Sketchup since V 4. And I know that the text tool will give me info on geometry. Like length, area, but today, surprise, I used the text tool on the apex of an angle and I got the following, the degrees of the angle in the text box. Never saw that before, and I would have an illustration to show you if I could get the text tool to do it again.
                Ken
                • GaieusG
                  I was reading a topic and realized that I did not understand a word.
                  Then looked up and also realized I was in the Developers Forum. πŸ˜’
                    0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
                      Didn't you mean
                      010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
                      πŸ˜• πŸ˜‰
                        01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
                          It wasn't... but
                          0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
                            mrossk
                            I think I got geek all over me πŸ˜‰
                            https://www.mkaplanfinefurniture.com/
                              πŸ’š
                              	100001
                              	11000
                              	1110
                              	100011
                              	1100
                              	10001
                              	100100
                              	11110
                                Found a cool one today.
                                Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                                What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                                However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                                -Brodie
                                Duh!
                                That is sweet!
                                The manual doesn't even mention this!
                                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                                • H
                                  Heaps
                                  It even works with circular arrays - just type in the angle in degrees
                                  • brodieB
                                    brodie
                                    However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                                    -Brodie
                                    • broomstickB
                                      broomstick
                                      -Brodie
                                      This, sir, just made my day!
                                      • Bob JamesB
                                        Bob James
                                        • jgbJ
                                          jgb
                                          Found a cool one today. πŸ˜’
                                          -Brodie
                                          I just wish you found this last week, when I needed it. πŸ˜†
                                          jgb
                                            d12dozr
                                            -Brodie
                                            I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                                            http://goo.gl/f7ooYh
