    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
      Found a cool one today.
      Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
      What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
      However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
      -Brodie
      Duh!
      That is sweet!
      The manual doesn't even mention this!
      http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
      • H
        Heaps
        It even works with circular arrays - just type in the angle in degrees
        • brodieB
          brodie
          However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
          -Brodie
          • broomstickB
            broomstick
            -Brodie
            This, sir, just made my day!
            • Bob JamesB
              Bob James
              • jgbJ
                jgb
                Found a cool one today. πŸ˜’
                -Brodie
                I just wish you found this last week, when I needed it. πŸ˜†
                jgb
                  d12dozr
                  -Brodie
                  I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                  http://goo.gl/f7ooYh
                  • aarondietzenA
                    aarondietzen
                    Shift + Eraser to smooth...
                    I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                    Ah... feels good to share my stupidity!
                    "Imagination is more important than knowledge..."
                    - Albert Einstein
                    • massimoM
                      massimo Moderator
                      Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                      • aarondietzenA
                        aarondietzen
                        Stupidity x2! πŸ˜†
                        - Albert Einstein
                          Ctrl+Erase = Soft+Smooth
                          Shift+Erase = Hide
                          Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                            Shift+Erase = Hide
                            Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                            • aarondietzenA
                              aarondietzen
                              @tig said:
                              Shift+Erase = Hide
                              "Learn something new everyday!"
                              In this case... several new things.
                              - Albert Einstein
                                -Brodie
                                Duh!
                                That is sweet!
                                Seems that is more missing here πŸ˜‰
                                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                                • emerald15E
                                  emerald15
                                  You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                    Typing an 'x' or '*' is the same - so you can type x2, *2 , 2x etc for 'times'.
                                    To 'divide' the copies use /2...
                                    You never need to use a 'degree' symbol with Rotate, any typed in +ve or -ve numbers that don't contain an x, * or / are taken as degrees anyway... In Move [and tools like Line] it's taken as 'current units', unless you add a units suffix, so typing 1000 while using mm Moves the object 1000mm, but to move it a specific distance in feet+inches can be done even while the model's current-units is mm - e.g. typing 3'4" will Move that exact amount [1016mm] etc...
                                    Incidentally, if you want to type 'special characters' in Sketchup Text - like degrees [Β°] - there are OS specific key-strokes, on a PC it's Alt0176, on a MAC I think it's OptionShift8. There are lots, so if you use some regularly have a crib sheet handy...
                                    • jgbJ
                                      jgb
                                      This is also a question, based on the above.
                                      Using SCALE, you can just type a percentage value in the VCB. This is handy to set a specific scale factor like 92%. It is also handy to set a scale factor that is between SCALE's preset snap tolerance of .1% so just type 90.15 in the VCB where SCALE snaps only to 90.1% or 90.2% and you need the precision.
                                      OK, my question, How do I set scale to a dimensional value?
                                      ie: my object is 12 inches, and I want it to be 13 inches, without doing the percentage math. AND I am holding the CTRL and SHIFT keys down to scale all and from the center. When I release the mouse button to type, my position is lost.
                                      jgb
                                        Just scale roughly first - then use the VCB to adjust with accuracy afterwards - typing in the length.
                                          Just draw a 13 inch segment from a vertex from your object and Scale your object by the line! πŸ˜‰
                                          Alas this just work only with "cubic" objects! πŸ€“
                                          If you have inclined faces you must don't use the native Scale tool!!!
                                            Pull out to approximate size [using any modifier keys you desire], then immediately type in the required size, before selecting another tool.
                                            The length has to have a 'units suffix'.
                                            Type 13 will make it 13x bigger ! but 13" makes it exactly 13 inches, or 330mm which makes it exactly that size in mm, this is done irrespective of the model's current-unit settings...
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
