    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
      @gaieus said:
      I was reading a topic and realized that I did not understand a word.
      Then looked up and also realized I was in the Developers Forum. πŸ˜’
      0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
        Didn't you mean
        010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
        πŸ˜• πŸ˜‰
          01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
            It wasn't... but
            0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
              mrossk
              I think I got geek all over me πŸ˜‰
              https://www.mkaplanfinefurniture.com/
                πŸ’š
                	100001
                	11000
                	1110
                	100011
                	1100
                	10001
                	100100
                	11110
                  Found a cool one today.
                  Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                  What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                  However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                  -Brodie
                  Duh!
                  That is sweet!
                  The manual doesn't even mention this!
                  http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                  • H
                    Heaps
                    It even works with circular arrays - just type in the angle in degrees
                    • brodieB
                      brodie
                      However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                      -Brodie
                      • broomstickB
                        broomstick
                        -Brodie
                        This, sir, just made my day!
                        • Bob JamesB
                          Bob James
                          • jgbJ
                            jgb
                            Found a cool one today. πŸ˜’
                            -Brodie
                            I just wish you found this last week, when I needed it. πŸ˜†
                            jgb
                              d12dozr
                              -Brodie
                              I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                              http://goo.gl/f7ooYh
                              • aarondietzenA
                                aarondietzen
                                Shift + Eraser to smooth...
                                I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                                Ah... feels good to share my stupidity!
                                "Imagination is more important than knowledge..."
                                - Albert Einstein
                                • massimoM
                                  massimo Moderator
                                  Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                                  • aarondietzenA
                                    aarondietzen
                                    Stupidity x2! πŸ˜†
                                    - Albert Einstein
                                      Ctrl+Erase = Soft+Smooth
                                      Shift+Erase = Hide
                                      Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                                        Shift+Erase = Hide
                                        Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                        • aarondietzenA
                                          aarondietzen
                                          @tig said:
                                          Shift+Erase = Hide
                                          "Learn something new everyday!"
                                          In this case... several new things.
                                          - Albert Einstein
                                            -Brodie
                                            Duh!
                                            That is sweet!
                                            Seems that is more missing here πŸ˜‰
                                            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
