    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 158.8k Views 54 Watching
    • simon le bonS
      simon le bon
      Hi TIG,
      I've just tried what you were recommending
      @tig said:
      Perhaps the line
      @camera = @view.camera
      could be followed by
      @camera.fov = 50.0
      or whatever fov-angle you'd like ?
      Resulting to this change, the camera is set to 50° as soon as I activate CameraKeyMaker tool . But when my Alt+Q camera shots are done and I clic "Enter" to call the SET UP SCENES and "OK" , created scenes are still cropped back to camera 30°.
      I have made a search on "30°" into the ruby txt, but the specified string was not found. 😞
      Do you have any other idea?
      😕 simon
        The screen size [width/height etc] is set in code later on - perhaps this is cropping the image ?
        I don't use this tool so I am winging it here 😕
        view.camera.set(eye, target, up)
        if @save_image
                keys = {
                 ;filename => @fileName,
                 ;width => 320,
                 ;height => 240,
                 ;antialias => true,
                 ;compression => 0.9,
                ;transparent => true }
                view.write_image keys
        have you tried changing those ?
        Trying changing the width/height proportions...
        Also perhaps add view.camera.fov=50.0 before 'keys' ???
        Also ' newCamera' is set perhaps you need to set newCamera.fov=50.0 too ?
        • simon le bonS
          simon le bon
          Hi TIG,
          "crop" is probably a wrong word I have used. I tell this way to express that the 30° telephoto produces like a zooming into the field. (oups my english 😳 )
          @tig said:
          try changing those
          They both don't change the 30° scenes output
          first try:
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_220506.jpg
          second try:
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_215157.jpg
          I believe in the second one because:
               generate_scene = true
                if generate_scene
          is the place where I'm searching to change the camera opening field. Is the way I have add the line is good?
          😕 s
            driven
            hi,
            Your output image dims ratio is 1.333, if the window isn't a same ratio it causes problems on mac's...
            or you could try running Martin's camera Stats, might show you what's happening.http://forums.sketchucation.com/viewtopic.php?t=27835
            • simon le bonS
              simon le bon
              Hi John,
              Thank you for your cent.
              Y
              I have tried a 16/9 format (ratio: 1.66 ) but I don't notice any different result ❓
               if @save_image
                      keys = {
                       ;width => 1000,
                       ;height => 602,
              I have downloaded and used [Plugin] Camera Stats by MartinRinehart : it confirms my fields of view
              Cheers,
              simon
              PS: I just have sent a PM to macgile . wait and see. 😒
                RichardU
                I see there is a preview recently posted on YouTube for version 2.0 of this tool.
                • N
                  numerobis
                  Great plugin! very nice! 😎
                  but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
                  • PixeroP
                    Pixero
                    Can you post a link? I can´t find it.
                      RichardU
                      • N
                        numerobis
                        • L
                          LivioE
                          fantastic, thanks very much
                          • L
                            LivioE
                            ..bute are you sure it runs also within su8 ?
                              It should work.
                              Incompatibility is usually 'backwards' to earlier versions, that don't have all of the newer version's tools.
                              Why not just install it and try it out.
                              The worst that can happen is it doesn't work !
                              Check that you have indeed installed it as directed [a common pitfall] !!
                              If so then uninstall the few files you have installed.
                              • OxerO
                                Oxer
                                This plugin for me is very useful but I work on Mac and it didn't work because de keys codes and pathname are different between Pc and Mac.
                                I have done changes in camera_key_maker.rb and the plugin works on Mac now.
                                I use Apple Extended Keyboard.
                                CHANGES KEYS CODE lines 295 to 360
                                ONKEYDOWN (CAMERA MANUAL ANIMATION)
                                def onKeyDown(key, x, y, view)
                                # 63234 LEFT, 63235 RIGHT, 63232 UP, 63233 DOWN
                                if  @points_eye.size > 0
                                 size = (@points_eye.size) -1
                                 #previous/next Key   <--[--1] || [++1]-->
                                  **%(#BF0000)[if key == 63234 or key == 63235]**
                                  **%(#BF0000)[if key == 63234 # LEFT <--]**
                                   if @index && @index > 0
                                    @index -= 1
                                    eye    = @points_eye.at(@index)
                                    target = @points_target.at(@index)
                                   else
                                    @index = size
                                    eye    = @points_eye.at(size)
                                    target = @points_target.at(size)
                                  else # RIGHT -->
                                   if @index && @index < size
                                    @index += 1
                                   else
                                    @index = 0
                                    eye    = @points_eye.at(0)
                                    target = @points_target.at(0)
                                  end # key 63234
                                  @camera.set eye, target,  @up.clone
                                  Sketchup::set_status_text("Llave de Cámara: #{@index+1}", SB_PROMPT)
                                  view.animation = nil
                                  @edit_cam    =  false
                                  @draw        =  true
                                  view.invalidate
                                 end # key 63234/63235
                                 # PLAY PREVIEW
                                **%(#BF0000)[if key == 63232 # UP]**
                                  @edit_cam = false
                                  if @points_eye and @points_eye.size > 1
                                   $preview  = true
                                   view.animation = CameraAnimation.new(@points_eye, @points_target)
                                   #view.animation = cam_anim
                                   #place to last camera key
                                   @index    = (@points_eye.size) -1
                                  #Animation stopped"
                                 end # 63232
                                 # EDIT current position camera key
                                 %(#BF0000)[**if key == 63233 # DOWN**]
                                  @edit_cam = true
                                  Sketchup::set_status_text("Editar Llave de Cámara: #{@index+1} , Editar curva manualmente solo Vistas [Arriba-Abajo-Izquierda-Derecha]", SB_PROMPT)
                                 end # key 63233
                                end # @points_eye.size > 0
                                @draw = true
                                view.invalidate
                                end #onKeyDown
                                CHANGES PATHNAME
                                line 637: pathname = Sketchup.find_support_file "camera_path.html" ,"Plugins/CameraKeyMaker"
                                  richyrich33
                                  Just installed this plugin through sketchucation tools, works fine though when I press enter nothing happens, must be missing something here....?
                                  • emerald15E
                                    emerald15
                                    macgile -Something else caught my eye... in the '8.0th SketchUp' parody animation you have a clever treatment for the beam of the spotlights. I'm assuming this piece is still native sketchup...? so I'm guessing you used tubes of semi-transparent white material & hid all the edges? Or is there more to it - please share, I'd love to know.
                                    • O
                                      Obroni1973
                                      Hi from Germany.
                                      Would like to install your Sketchup Tool CameraKeyMaker, but the download links seem not to work well...
                                      Would really like to use ur tool, looks really good. Pls help me.......
                                      Thank you
                                      Matthias
                                      • duanekempD
                                        duanekemp
                                        I know I'm coming in late in the game, but I have read this post from it's beginning until the May 16th post above. Yet, I cannot learn more about this plugin for SU 2013 or why it's not in the current extension warehouse. Has there been any further development on this plugin and has it yet been able to be confirmed to be used by exterior render engines such as Shaderlight and Vray?
                                        Duane Kemp
                                        Kemp Productions
                                        Puidoux, Switzerland
                                        Gallery:
                                        https://duanekemp.artstation.com/
                                        • T
                                          tomaszdrgas
                                          Is it possible to set different Field of View, Shadows, Fog, group viseabilety etc. along the keypath? Like I can do it in standard sKetchup views and than sKetchup automaticly smoothly changes to next sceen?
                                            sarkarshomit
                                            Will this work with Sketchup 2015 or 2016 version? i remember it worked with earler versions....
                                            I just loved this plugin but nowadays dont seem to get it to work using Su15 or Su16...please any help.
                                            • 4 / 6
