    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 157.3k Views 54 Watching
    • V
      Viztecture
      Ok I used scene transitions.rb and it works a treat now. New problem now lol. The animation is not smooth, im still getting jumps as the camera slows towards the next scene. Its fine on the preview however... any suggestions?
      http://www.viztecture.mfbiz.com
      • V
        Viztecture
        Ok think I got it, in preferences, SU scene transitions need to be longer than the actual keymaker transitions, i.e max 100 secs. This seems to smooth over the animation and stops SU taking over. Im still confused why i have to workaround this, guess im doing something wrong
        *EDIT . actually that hasn't worked 😒
        • jcohen71J
          jcohen71
          I tried to use CameraKeyMaker on a Mac running Sketchup 8, but ran in to the same problem others have mentioned: I cannot seem to find an equivilant key combination to Alt-Q used on Windows, and so I can't place any camera keys. (neither Opt-Q or Ctrl-Q work for me)
          If there's a simple fix for this I'd love to hear about it, otherwise I'll eagerly wait for the next version. This seems like a great tool that we could use on many projects.
          Best Regards,
          Joshua Cohen
          Fat Pencil Studio
          +1.503.465.4533
          info@fatpencilstudio.com
            driven
            in camera_key_maker.rb
            I changed line 387 to read
            if key == 81 and $preview == false
            I then did a search and replace for the word Alt and replaced it with Shift,
            so Shift+ Q works on my mac...
              I do not know this tool in any detail... but in passing... I see that there are $ global variables like '$preview' these are dangerous - especially if they have simplistic names [like 'preview'] as other authors might have used them [ill-advisedly] too, as globals works across all scripts in that session - better to use '@preview' as an instance variable, or '@@preview' as a class variable, to hold your data specifically for your own tool so such potential clashes are avoided... 🤓
                macgile
                Yes TIG
                when I developed this plugin I had only one months experience the ruby language and API sketchup.
                certainly you will find other errors of this type in the source, but I perfecting every day.
                in the next release several beginner mistakes are corrected but it will remain.
                best regard 😄
                • V
                  vtrdo
                  hi guys
                  i have here a bit strange behavior of the plug ..
                  I have set up simple fly-around with 10 camera Keys - previews look perfect , smooth and going exactly as we want... ... camera follows busier curve ...till this moment everything is nice and easy
                  problems are: ➡
                  1/after i press the ENTER even if i change the number for Frames between each key I always get 19 scenes .. is this correct?
                  2/ ❗ bigger one scenes which were produced change the Field of View and positions now it is in position is same as the key ...
                  What can i do to get result same as Preview ... or do i have to set up properly the Keys and forget what the preview is showing??
                  many thanks!!!!
                  • majidM
                    majid
                    😞 I can't run it at all!!!! any conflict with other plugs?
                    where I must seek it? plugin menu? tools menu?
                    how can I activate it's toolbar (ui) please?
                    edit: thanks ... wow this is wonderful, thank you, I was seeking it in false place. 👍 👍
                    I just wondering how can I edit the path?
                    • T
                      theVonZipper
                      Trying out CameraKeyMaker on a winXP. Doesn't behave like the video tutorial. (BTW, is there supposed to be audio with that video?)
                      Although Alt-Q does add a key frame, I cannot use the orbit tool to reposition the camera. The CameraKeyMaker feedback onscreen disappears & as far as I can tell the script ends.
                      What is available is a dotted sphere to mark position. I clicked on that & circled a cube. Hitting enter did send the key frames to scenes. But the scenes created this way do not orbit the cube.
                      Is there a new version available yet? (The version I am trying out does not iclude the 1.0 designation anywhere in its name or files).
                      If I could get it to work it would be a great feature.
                      Thanks,
                      -=Zip
                      • simon le bonS
                        simon le bon
                        Hi macgile,
                        I'm using/learning your tool since few days. After a hard start, I now begin to tame it pretty well. I understand now how I can manage the bezier camera path. It is a cool tool 👍 😄 and the exported animations are nicely fluid 👍 👍
                        I begin to see some requests to ask for.
                        But the main thing I'm confronted in is a problem of angle of camera.
                        I just have finished a complex camera path with a complex model and have launched CameraMaker scenes maker. I realize something I hadn't noticed in my trainings: is that animation uses a fixed camera angle of 30° !! This is too short!
                        Standard angle in sketchup is 35° , I for my part have made the all camera path with a wider angle of 50°. Now my animation is to much cropped. 😒
                        I have tried to update the scenes one by one (the firsts of my 69 scenes!) with this 50° angle but it seems that some geometry don't display satisfactorily.
                        Do you think it is possible to do something ? or it is a big update of the code!
                        Cheers,
                        Simon.
                          Perhaps the line
                          @camera = @view.camera
                          could be followed by
                          @camera.fov = 50.0
                          or whatever fov-angle you'd like ?
                          • simon le bonS
                            simon le bon
                            Hi Tig, 😄
                            Thanks for the advice. I shall try this tomorrow.
                                • simon
                            • simon le bonS
                              simon le bon
                              Hi TIG,
                              I've just tried what you were recommending
                              @tig said:
                              Perhaps the line
                              @camera.fov = 50.0
                              Resulting to this change, the camera is set to 50° as soon as I activate CameraKeyMaker tool . But when my Alt+Q camera shots are done and I clic "Enter" to call the SET UP SCENES and "OK" , created scenes are still cropped back to camera 30°.
                              I have made a search on "30°" into the ruby txt, but the specified string was not found. 😞
                              Do you have any other idea?
                              😕 simon
                                The screen size [width/height etc] is set in code later on - perhaps this is cropping the image ?
                                I don't use this tool so I am winging it here 😕
                                view.camera.set(eye, target, up)
                                if @save_image
                                        keys = {
                                         ;filename => @fileName,
                                         ;width => 320,
                                         ;height => 240,
                                         ;antialias => true,
                                         ;compression => 0.9,
                                        ;transparent => true }
                                        view.write_image keys
                                have you tried changing those ?
                                Trying changing the width/height proportions...
                                Also perhaps add view.camera.fov=50.0 before 'keys' ???
                                Also ' newCamera' is set perhaps you need to set newCamera.fov=50.0 too ?
                                • simon le bonS
                                  simon le bon
                                  Hi TIG,
                                  "crop" is probably a wrong word I have used. I tell this way to express that the 30° telephoto produces like a zooming into the field. (oups my english 😳 )
                                  @tig said:
                                  try changing those
                                  They both don't change the 30° scenes output
                                  first try:
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_220506.jpg
                                  second try:
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_215157.jpg
                                  I believe in the second one because:
                                       generate_scene = true
                                        if generate_scene
                                  is the place where I'm searching to change the camera opening field. Is the way I have add the line is good?
                                  😕 s
                                    driven
                                    hi,
                                    Your output image dims ratio is 1.333, if the window isn't a same ratio it causes problems on mac's...
                                    or you could try running Martin's camera Stats, might show you what's happening.http://forums.sketchucation.com/viewtopic.php?t=27835
                                    • simon le bonS
                                      simon le bon
                                      Hi John,
                                      Thank you for your cent.
                                      Y
                                      I have tried a 16/9 format (ratio: 1.66 ) but I don't notice any different result ❓
                                       if @save_image
                                              keys = {
                                               ;width => 1000,
                                               ;height => 602,
                                      I have downloaded and used [Plugin] Camera Stats by MartinRinehart : it confirms my fields of view
                                      Cheers,
                                      simon
                                      PS: I just have sent a PM to macgile . wait and see. 😒
                                        RichardU
                                        I see there is a preview recently posted on YouTube for version 2.0 of this tool.
                                        • N
                                          numerobis
                                          Great plugin! very nice! 😎
                                          but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
                                          • PixeroP
                                            Pixero
                                            Can you post a link? I can´t find it.
                                            • 4 / 6
