    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 155.3k Views 54 Watching
    • simon le bonS Offline
      simon le bon
      Hi TIG,
      "crop" is probably a wrong word I have used. I tell this way to express that the 30° telephoto produces like a zooming into the field. (oups my english 😳 )
      @tig said:
      try changing those
      Also perhaps add view.camera.fov=50.0 before 'keys' ???
      Also ' newCamera' is set perhaps you need to set newCamera.fov=50.0 too ?
      They both don't change the 30° scenes output
      first try:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_220506.jpg
      second try:
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_215157.jpg
      I believe in the second one because:
           generate_scene = true
            if generate_scene
      is the place where I'm searching to change the camera opening field. Is the way I have add the line is good?
      😕 s
        driven
        hi,
        Your output image dims ratio is 1.333, if the window isn't a same ratio it causes problems on mac's...
        or you could try running Martin's camera Stats, might show you what's happening.http://forums.sketchucation.com/viewtopic.php?t=27835
          simon le bon
          Hi John,
          Thank you for your cent.
          Y
          I have tried a 16/9 format (ratio: 1.66 ) but I don't notice any different result ❓
           if @save_image
                  keys = {
                   ;filename => @fileName,
                   ;width => 1000,
                   ;height => 602,
          I have downloaded and used [Plugin] Camera Stats by MartinRinehart : it confirms my fields of view
          Cheers,
          simon
          PS: I just have sent a PM to macgile . wait and see. 😒
            RichardU
            I see there is a preview recently posted on YouTube for version 2.0 of this tool.
            • N Offline
              numerobis
              Great plugin! very nice! 😎
              but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
              • PixeroP Offline
                Pixero
                Can you post a link? I can´t find it.
                  RichardU
                  • N Offline
                    numerobis
                      LivioE
                      fantastic, thanks very much
                        LivioE
                        ..bute are you sure it runs also within su8 ?
                          It should work.
                          Incompatibility is usually 'backwards' to earlier versions, that don't have all of the newer version's tools.
                          Why not just install it and try it out.
                          The worst that can happen is it doesn't work !
                          Check that you have indeed installed it as directed [a common pitfall] !!
                          If so then uninstall the few files you have installed.
                          • OxerO Offline
                            Oxer
                            This plugin for me is very useful but I work on Mac and it didn't work because de keys codes and pathname are different between Pc and Mac.
                            I have done changes in camera_key_maker.rb and the plugin works on Mac now.
                            I use Apple Extended Keyboard.
                            CHANGES KEYS CODE lines 295 to 360
                            ONKEYDOWN (CAMERA MANUAL ANIMATION)
                            def onKeyDown(key, x, y, view)
                            # 63234 LEFT, 63235 RIGHT, 63232 UP, 63233 DOWN
                            if  @points_eye.size > 0
                             size = (@points_eye.size) -1
                             #previous/next Key   <--[--1] || [++1]-->
                              **%(#BF0000)[if key == 63234 or key == 63235]**
                              **%(#BF0000)[if key == 63234 # LEFT <--]**
                               if @index && @index > 0
                                @index -= 1
                                eye    = @points_eye.at(@index)
                                target = @points_target.at(@index)
                               else
                                @index = size
                                eye    = @points_eye.at(size)
                                target = @points_target.at(size)
                              else # RIGHT -->
                               if @index && @index < size
                                @index += 1
                               else
                                @index = 0
                                eye    = @points_eye.at(0)
                                target = @points_target.at(0)
                              end # key 63234
                              @camera.set eye, target,  @up.clone
                              Sketchup::set_status_text("Llave de Cámara: #{@index+1}", SB_PROMPT)
                              view.animation = nil
                              @edit_cam    =  false
                              @draw        =  true
                              view.invalidate
                             end # key 63234/63235
                             # PLAY PREVIEW
                            **%(#BF0000)[if key == 63232 # UP]**
                              @edit_cam = false
                              if @points_eye and @points_eye.size > 1
                               $preview  = true
                               view.animation = CameraAnimation.new(@points_eye, @points_target)
                               #view.animation = cam_anim
                               #place to last camera key
                               @index    = (@points_eye.size) -1
                              #Animation stopped"
                             end # 63232
                             # EDIT current position camera key
                             %(#BF0000)[**if key == 63233 # DOWN**]
                              @edit_cam = true
                              Sketchup::set_status_text("Editar Llave de Cámara: #{@index+1} , Editar curva manualmente solo Vistas [Arriba-Abajo-Izquierda-Derecha]", SB_PROMPT)
                             end # key 63233
                            end # @points_eye.size > 0
                            @draw = true
                            view.invalidate
                            end #onKeyDown
                            CHANGES PATHNAME
                            line 637: pathname = Sketchup.find_support_file "camera_path.html" ,"Plugins/CameraKeyMaker"
                              richyrich33
                              Just installed this plugin through sketchucation tools, works fine though when I press enter nothing happens, must be missing something here....?
                              • emerald15E Offline
                                emerald15
                                macgile -Something else caught my eye... in the '8.0th SketchUp' parody animation you have a clever treatment for the beam of the spotlights. I'm assuming this piece is still native sketchup...? so I'm guessing you used tubes of semi-transparent white material & hid all the edges? Or is there more to it - please share, I'd love to know.
                                • O Offline
                                  Obroni1973
                                  Hi from Germany.
                                  Would like to install your Sketchup Tool CameraKeyMaker, but the download links seem not to work well...
                                  Would really like to use ur tool, looks really good. Pls help me.......
                                  Thank you
                                  Matthias
                                  • duanekempD Offline
                                    duanekemp
                                    I know I'm coming in late in the game, but I have read this post from it's beginning until the May 16th post above. Yet, I cannot learn more about this plugin for SU 2013 or why it's not in the current extension warehouse. Has there been any further development on this plugin and has it yet been able to be confirmed to be used by exterior render engines such as Shaderlight and Vray?
                                    Duane Kemp
                                    Kemp Productions
                                    Puidoux, Switzerland
                                    Gallery:
                                    https://duanekemp.artstation.com/
                                      tomaszdrgas
                                      Is it possible to set different Field of View, Shadows, Fog, group viseabilety etc. along the keypath? Like I can do it in standard sKetchup views and than sKetchup automaticly smoothly changes to next sceen?
                                        sarkarshomit
                                        Will this work with Sketchup 2015 or 2016 version? i remember it worked with earler versions....
                                        I just loved this plugin but nowadays dont seem to get it to work using Su15 or Su16...please any help.
                                        • F Offline
                                          faust07
                                          Have today, after a long period of non-use, the plugin installed in SketchUp Make 2016.
                                          It is important not to forget to copy the script "bezier.rb" into the plugin folder. The plugin then works for my purpose to get paths of camera and target.
                                            dungnh
                                            I have an trouble with this plugin. Any advise ?
                                            • My system : Windows 10 / SketchUp Pro 2017
                                              I was install both of Camera Key Maker and Bezier Line but this plugin doesn't working with me.
                                              I already saw Camera Key Maker in Tab " Camera " but when i click on that nothing was happen.
                                              Anybody have the solutions for my situation ? Thanks all and I am sorry if my English not good enough to explain in detail.
                                            • 4 / 6
