    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 155.3k Views 54 Watching
      driven
      @jcohen71 said:
      If there's a simple fix for this I'd love to hear about it,
      in camera_key_maker.rb
      I changed line 387 to read
      if key == 81 and $preview == false
      I then did a search and replace for the word Alt and replaced it with Shift,
      so Shift+ Q works on my mac...
        I do not know this tool in any detail... but in passing... I see that there are $ global variables like '$preview' these are dangerous - especially if they have simplistic names [like 'preview'] as other authors might have used them [ill-advisedly] too, as globals works across all scripts in that session - better to use '@preview' as an instance variable, or '@@preview' as a class variable, to hold your data specifically for your own tool so such potential clashes are avoided... 🤓
          macgile
          Yes TIG
          when I developed this plugin I had only one months experience the ruby language and API sketchup.
          certainly you will find other errors of this type in the source, but I perfecting every day.
          in the next release several beginner mistakes are corrected but it will remain.
          best regard 😄
          • V Offline
            vtrdo
            hi guys
            i have here a bit strange behavior of the plug ..
            I have set up simple fly-around with 10 camera Keys - previews look perfect , smooth and going exactly as we want... ... camera follows busier curve ...till this moment everything is nice and easy
            problems are: ➡
            1/after i press the ENTER even if i change the number for Frames between each key I always get 19 scenes .. is this correct?
            2/ ❗ bigger one scenes which were produced change the Field of View and positions now it is in position is same as the key ...
            What can i do to get result same as Preview ... or do i have to set up properly the Keys and forget what the preview is showing??
            many thanks!!!!
            • majidM Offline
              majid
              😞 I can't run it at all!!!! any conflict with other plugs?
              where I must seek it? plugin menu? tools menu?
              how can I activate it's toolbar (ui) please?
              edit: thanks ... wow this is wonderful, thank you, I was seeking it in false place. 👍 👍
              I just wondering how can I edit the path?
                theVonZipper
                Trying out CameraKeyMaker on a winXP. Doesn't behave like the video tutorial. (BTW, is there supposed to be audio with that video?)
                Although Alt-Q does add a key frame, I cannot use the orbit tool to reposition the camera. The CameraKeyMaker feedback onscreen disappears & as far as I can tell the script ends.
                What is available is a dotted sphere to mark position. I clicked on that & circled a cube. Hitting enter did send the key frames to scenes. But the scenes created this way do not orbit the cube.
                Is there a new version available yet? (The version I am trying out does not iclude the 1.0 designation anywhere in its name or files).
                If I could get it to work it would be a great feature.
                Thanks,
                -=Zip
                • simon le bonS Offline
                  simon le bon
                  Hi macgile,
                  I'm using/learning your tool since few days. After a hard start, I now begin to tame it pretty well. I understand now how I can manage the bezier camera path. It is a cool tool 👍 😄 and the exported animations are nicely fluid 👍 👍
                  I begin to see some requests to ask for.
                  But the main thing I'm confronted in is a problem of angle of camera.
                  I just have finished a complex camera path with a complex model and have launched CameraMaker scenes maker. I realize something I hadn't noticed in my trainings: is that animation uses a fixed camera angle of 30° !! This is too short!
                  Standard angle in sketchup is 35° , I for my part have made the all camera path with a wider angle of 50°. Now my animation is to much cropped. 😒
                  I have tried to update the scenes one by one (the firsts of my 69 scenes!) with this 50° angle but it seems that some geometry don't display satisfactorily.
                  Do you think it is possible to do something ? or it is a big update of the code!
                  Cheers,
                  Simon.
                    Perhaps the line
                    @camera = @view.camera
                    could be followed by
                    @camera.fov = 50.0
                    or whatever fov-angle you'd like ?
                      simon le bon
                      Hi Tig, 😄
                      Thanks for the advice. I shall try this tomorrow.
                          • simon
                        simon le bon
                        Hi TIG,
                        I've just tried what you were recommending
                        @tig said:
                        Perhaps the line
                        @camera.fov = 50.0
                        Resulting to this change, the camera is set to 50° as soon as I activate CameraKeyMaker tool . But when my Alt+Q camera shots are done and I clic "Enter" to call the SET UP SCENES and "OK" , created scenes are still cropped back to camera 30°.
                        I have made a search on "30°" into the ruby txt, but the specified string was not found. 😞
                        Do you have any other idea?
                        😕 simon
                          The screen size [width/height etc] is set in code later on - perhaps this is cropping the image ?
                          I don't use this tool so I am winging it here 😕
                          view.camera.set(eye, target, up)
                          if @save_image
                                  keys = {
                                   ;filename => @fileName,
                                   ;width => 320,
                                   ;height => 240,
                                   ;antialias => true,
                                   ;compression => 0.9,
                                  ;transparent => true }
                                  view.write_image keys
                          have you tried changing those ?
                          Trying changing the width/height proportions...
                          Also perhaps add view.camera.fov=50.0 before 'keys' ???
                          Also ' newCamera' is set perhaps you need to set newCamera.fov=50.0 too ?
                            simon le bon
                            Hi TIG,
                            "crop" is probably a wrong word I have used. I tell this way to express that the 30° telephoto produces like a zooming into the field. (oups my english 😳 )
                            @tig said:
                            try changing those
                            They both don't change the 30° scenes output
                            first try:
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_220506.jpg
                            second try:
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_215157.jpg
                            I believe in the second one because:
                                 generate_scene = true
                                  if generate_scene
                            is the place where I'm searching to change the camera opening field. Is the way I have add the line is good?
                            😕 s
                              driven
                              hi,
                              Your output image dims ratio is 1.333, if the window isn't a same ratio it causes problems on mac's...
                              or you could try running Martin's camera Stats, might show you what's happening.http://forums.sketchucation.com/viewtopic.php?t=27835
                                simon le bon
                                Hi John,
                                Thank you for your cent.
                                Y
                                I have tried a 16/9 format (ratio: 1.66 ) but I don't notice any different result ❓
                                 if @save_image
                                        keys = {
                                         ;width => 1000,
                                         ;height => 602,
                                I have downloaded and used [Plugin] Camera Stats by MartinRinehart : it confirms my fields of view
                                Cheers,
                                simon
                                PS: I just have sent a PM to macgile . wait and see. 😒
                                  RichardU
                                  I see there is a preview recently posted on YouTube for version 2.0 of this tool.
                                  • N Offline
                                    numerobis
                                    Great plugin! very nice! 😎
                                    but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
                                    • PixeroP Offline
                                      Pixero
                                      Can you post a link? I can´t find it.
                                        RichardU
                                        • N Offline
                                          numerobis
                                            LivioE
                                            fantastic, thanks very much
                                            • 4 / 6
