    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 157.3k Views 54 Watching
    • majidM
      majid
      😞 I can't run it at all!!!! any conflict with other plugs?
      where I must seek it? plugin menu? tools menu?
      how can I activate it's toolbar (ui) please?
      edit: thanks ... wow this is wonderful, thank you, I was seeking it in false place. 👍 👍
      I just wondering how can I edit the path?
      • T
        theVonZipper
        Trying out CameraKeyMaker on a winXP. Doesn't behave like the video tutorial. (BTW, is there supposed to be audio with that video?)
        Although Alt-Q does add a key frame, I cannot use the orbit tool to reposition the camera. The CameraKeyMaker feedback onscreen disappears & as far as I can tell the script ends.
        What is available is a dotted sphere to mark position. I clicked on that & circled a cube. Hitting enter did send the key frames to scenes. But the scenes created this way do not orbit the cube.
        Is there a new version available yet? (The version I am trying out does not iclude the 1.0 designation anywhere in its name or files).
        If I could get it to work it would be a great feature.
        Thanks,
        -=Zip
        • simon le bonS
          simon le bon
          Hi macgile,
          I'm using/learning your tool since few days. After a hard start, I now begin to tame it pretty well. I understand now how I can manage the bezier camera path. It is a cool tool 👍 😄 and the exported animations are nicely fluid 👍 👍
          I begin to see some requests to ask for.
          But the main thing I'm confronted in is a problem of angle of camera.
          I just have finished a complex camera path with a complex model and have launched CameraMaker scenes maker. I realize something I hadn't noticed in my trainings: is that animation uses a fixed camera angle of 30° !! This is too short!
          Standard angle in sketchup is 35° , I for my part have made the all camera path with a wider angle of 50°. Now my animation is to much cropped. 😒
          I have tried to update the scenes one by one (the firsts of my 69 scenes!) with this 50° angle but it seems that some geometry don't display satisfactorily.
          Do you think it is possible to do something ? or it is a big update of the code!
          Cheers,
          Simon.
            Perhaps the line
            @camera = @view.camera
            could be followed by
            @camera.fov = 50.0
            or whatever fov-angle you'd like ?
            • simon le bonS
              simon le bon
              Hi Tig, 😄
              Thanks for the advice. I shall try this tomorrow.
                  • simon
              • simon le bonS
                simon le bon
                Hi TIG,
                I've just tried what you were recommending
                @tig said:
                Perhaps the line
                @camera.fov = 50.0
                Resulting to this change, the camera is set to 50° as soon as I activate CameraKeyMaker tool . But when my Alt+Q camera shots are done and I clic "Enter" to call the SET UP SCENES and "OK" , created scenes are still cropped back to camera 30°.
                I have made a search on "30°" into the ruby txt, but the specified string was not found. 😞
                Do you have any other idea?
                😕 simon
                  The screen size [width/height etc] is set in code later on - perhaps this is cropping the image ?
                  I don't use this tool so I am winging it here 😕
                  view.camera.set(eye, target, up)
                  if @save_image
                          keys = {
                           ;filename => @fileName,
                           ;width => 320,
                           ;height => 240,
                           ;antialias => true,
                           ;compression => 0.9,
                          ;transparent => true }
                          view.write_image keys
                  have you tried changing those ?
                  Trying changing the width/height proportions...
                  Also perhaps add view.camera.fov=50.0 before 'keys' ???
                  Also ' newCamera' is set perhaps you need to set newCamera.fov=50.0 too ?
                  • simon le bonS
                    simon le bon
                    Hi TIG,
                    "crop" is probably a wrong word I have used. I tell this way to express that the 30° telephoto produces like a zooming into the field. (oups my english 😳 )
                    @tig said:
                    try changing those
                    They both don't change the 30° scenes output
                    first try:
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_220506.jpg
                    second try:
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2012-01-08_215157.jpg
                    I believe in the second one because:
                         generate_scene = true
                          if generate_scene
                    is the place where I'm searching to change the camera opening field. Is the way I have add the line is good?
                    😕 s
                      driven
                      hi,
                      Your output image dims ratio is 1.333, if the window isn't a same ratio it causes problems on mac's...
                      or you could try running Martin's camera Stats, might show you what's happening.http://forums.sketchucation.com/viewtopic.php?t=27835
                      • simon le bonS
                        simon le bon
                        Hi John,
                        Thank you for your cent.
                        Y
                        I have tried a 16/9 format (ratio: 1.66 ) but I don't notice any different result ❓
                         if @save_image
                                keys = {
                                 ;width => 1000,
                                 ;height => 602,
                        I have downloaded and used [Plugin] Camera Stats by MartinRinehart : it confirms my fields of view
                        Cheers,
                        simon
                        PS: I just have sent a PM to macgile . wait and see. 😒
                          RichardU
                          I see there is a preview recently posted on YouTube for version 2.0 of this tool.
                          • N
                            numerobis
                            Great plugin! very nice! 😎
                            but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
                            • PixeroP
                              Pixero
                              Can you post a link? I can´t find it.
                                RichardU
                                • N
                                  numerobis
                                  • L
                                    LivioE
                                    fantastic, thanks very much
                                    • L
                                      LivioE
                                      ..bute are you sure it runs also within su8 ?
                                        It should work.
                                        Incompatibility is usually 'backwards' to earlier versions, that don't have all of the newer version's tools.
                                        Why not just install it and try it out.
                                        The worst that can happen is it doesn't work !
                                        Check that you have indeed installed it as directed [a common pitfall] !!
                                        If so then uninstall the few files you have installed.
                                        • OxerO
                                          Oxer
                                          This plugin for me is very useful but I work on Mac and it didn't work because de keys codes and pathname are different between Pc and Mac.
                                          I have done changes in camera_key_maker.rb and the plugin works on Mac now.
                                          I use Apple Extended Keyboard.
                                          CHANGES KEYS CODE lines 295 to 360
                                          ONKEYDOWN (CAMERA MANUAL ANIMATION)
                                          def onKeyDown(key, x, y, view)
                                          # 63234 LEFT, 63235 RIGHT, 63232 UP, 63233 DOWN
                                          if  @points_eye.size > 0
                                           size = (@points_eye.size) -1
                                           #previous/next Key   <--[--1] || [++1]-->
                                            **%(#BF0000)[if key == 63234 or key == 63235]**
                                            **%(#BF0000)[if key == 63234 # LEFT <--]**
                                             if @index && @index > 0
                                              @index -= 1
                                              eye    = @points_eye.at(@index)
                                              target = @points_target.at(@index)
                                             else
                                              @index = size
                                              eye    = @points_eye.at(size)
                                              target = @points_target.at(size)
                                            else # RIGHT -->
                                             if @index && @index < size
                                              @index += 1
                                             else
                                              @index = 0
                                              eye    = @points_eye.at(0)
                                              target = @points_target.at(0)
                                            end # key 63234
                                            @camera.set eye, target,  @up.clone
                                            Sketchup::set_status_text("Llave de Cámara: #{@index+1}", SB_PROMPT)
                                            view.animation = nil
                                            @edit_cam    =  false
                                            @draw        =  true
                                            view.invalidate
                                           end # key 63234/63235
                                           # PLAY PREVIEW
                                          **%(#BF0000)[if key == 63232 # UP]**
                                            @edit_cam = false
                                            if @points_eye and @points_eye.size > 1
                                             $preview  = true
                                             view.animation = CameraAnimation.new(@points_eye, @points_target)
                                             #view.animation = cam_anim
                                             #place to last camera key
                                             @index    = (@points_eye.size) -1
                                            #Animation stopped"
                                           end # 63232
                                           # EDIT current position camera key
                                           %(#BF0000)[**if key == 63233 # DOWN**]
                                            @edit_cam = true
                                            Sketchup::set_status_text("Editar Llave de Cámara: #{@index+1} , Editar curva manualmente solo Vistas [Arriba-Abajo-Izquierda-Derecha]", SB_PROMPT)
                                           end # key 63233
                                          end # @points_eye.size > 0
                                          @draw = true
                                          view.invalidate
                                          end #onKeyDown
                                          CHANGES PATHNAME
                                          line 637: pathname = Sketchup.find_support_file "camera_path.html" ,"Plugins/CameraKeyMaker"
                                            richyrich33
                                            Just installed this plugin through sketchucation tools, works fine though when I press enter nothing happens, must be missing something here....?
                                            • 4 / 6
