    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 158.8k Views 54 Watching
    • N
      numerobis
      Great plugin! very nice! 😎
      but... any news on this fov problem?!? with a camera always jumping to 30° fov it's pretty useless for me... 😢
      • PixeroP
        Pixero
        @richardu said:
        I see there is a preview recently posted on YouTube for version 2.0 of this tool.
        Can you post a link? I can´t find it.
          RichardU
          • N
            numerobis
            • L
              LivioE
              fantastic, thanks very much
              • L
                LivioE
                ..bute are you sure it runs also within su8 ?
                  It should work.
                  Incompatibility is usually 'backwards' to earlier versions, that don't have all of the newer version's tools.
                  Why not just install it and try it out.
                  The worst that can happen is it doesn't work !
                  Check that you have indeed installed it as directed [a common pitfall] !!
                  If so then uninstall the few files you have installed.
                  • OxerO
                    Oxer
                    This plugin for me is very useful but I work on Mac and it didn't work because de keys codes and pathname are different between Pc and Mac.
                    I have done changes in camera_key_maker.rb and the plugin works on Mac now.
                    I use Apple Extended Keyboard.
                    CHANGES KEYS CODE lines 295 to 360
                    ONKEYDOWN (CAMERA MANUAL ANIMATION)
                    def onKeyDown(key, x, y, view)
                    # 63234 LEFT, 63235 RIGHT, 63232 UP, 63233 DOWN
                    if  @points_eye.size > 0
                     size = (@points_eye.size) -1
                     #previous/next Key   <--[--1] || [++1]-->
                      **%(#BF0000)[if key == 63234 or key == 63235]**
                      **%(#BF0000)[if key == 63234 # LEFT <--]**
                       if @index && @index > 0
                        @index -= 1
                        eye    = @points_eye.at(@index)
                        target = @points_target.at(@index)
                       else
                        @index = size
                        eye    = @points_eye.at(size)
                        target = @points_target.at(size)
                      else # RIGHT -->
                       if @index && @index < size
                        @index += 1
                       else
                        @index = 0
                        eye    = @points_eye.at(0)
                        target = @points_target.at(0)
                      end # key 63234
                      @camera.set eye, target,  @up.clone
                      Sketchup::set_status_text("Llave de Cámara: #{@index+1}", SB_PROMPT)
                      view.animation = nil
                      @edit_cam    =  false
                      @draw        =  true
                      view.invalidate
                     end # key 63234/63235
                     # PLAY PREVIEW
                    **%(#BF0000)[if key == 63232 # UP]**
                      @edit_cam = false
                      if @points_eye and @points_eye.size > 1
                       $preview  = true
                       view.animation = CameraAnimation.new(@points_eye, @points_target)
                       #view.animation = cam_anim
                       #place to last camera key
                       @index    = (@points_eye.size) -1
                      #Animation stopped"
                     end # 63232
                     # EDIT current position camera key
                     %(#BF0000)[**if key == 63233 # DOWN**]
                      @edit_cam = true
                      Sketchup::set_status_text("Editar Llave de Cámara: #{@index+1} , Editar curva manualmente solo Vistas [Arriba-Abajo-Izquierda-Derecha]", SB_PROMPT)
                     end # key 63233
                    end # @points_eye.size > 0
                    @draw = true
                    view.invalidate
                    end #onKeyDown
                    CHANGES PATHNAME
                    line 637: pathname = Sketchup.find_support_file "camera_path.html" ,"Plugins/CameraKeyMaker"
                      richyrich33
                      Just installed this plugin through sketchucation tools, works fine though when I press enter nothing happens, must be missing something here....?
                      • emerald15E
                        emerald15
                        macgile -Something else caught my eye... in the '8.0th SketchUp' parody animation you have a clever treatment for the beam of the spotlights. I'm assuming this piece is still native sketchup...? so I'm guessing you used tubes of semi-transparent white material & hid all the edges? Or is there more to it - please share, I'd love to know.
                        • O
                          Obroni1973
                          Hi from Germany.
                          Would like to install your Sketchup Tool CameraKeyMaker, but the download links seem not to work well...
                          Would really like to use ur tool, looks really good. Pls help me.......
                          Thank you
                          Matthias
                          • duanekempD
                            duanekemp
                            I know I'm coming in late in the game, but I have read this post from it's beginning until the May 16th post above. Yet, I cannot learn more about this plugin for SU 2013 or why it's not in the current extension warehouse. Has there been any further development on this plugin and has it yet been able to be confirmed to be used by exterior render engines such as Shaderlight and Vray?
                            Duane Kemp
                            Kemp Productions
                            Puidoux, Switzerland
                            Gallery:
                            https://duanekemp.artstation.com/
                            • T
                              tomaszdrgas
                              Is it possible to set different Field of View, Shadows, Fog, group viseabilety etc. along the keypath? Like I can do it in standard sKetchup views and than sKetchup automaticly smoothly changes to next sceen?
                                sarkarshomit
                                Will this work with Sketchup 2015 or 2016 version? i remember it worked with earler versions....
                                I just loved this plugin but nowadays dont seem to get it to work using Su15 or Su16...please any help.
                                • F
                                  faust07
                                  Have today, after a long period of non-use, the plugin installed in SketchUp Make 2016.
                                  It is important not to forget to copy the script "bezier.rb" into the plugin folder. The plugin then works for my purpose to get paths of camera and target.
                                    dungnh
                                    I have an trouble with this plugin. Any advise ?
                                    • My system : Windows 10 / SketchUp Pro 2017
                                      I was install both of Camera Key Maker and Bezier Line but this plugin doesn't working with me.
                                      I already saw Camera Key Maker in Tab " Camera " but when i click on that nothing was happen.
                                      Anybody have the solutions for my situation ? Thanks all and I am sorry if my English not good enough to explain in detail.
                                    • B
                                      BLAlley
                                      Shame this was abandoned. This is exactly what I need but it doesn't work with SU 2016
                                      • OxerO
                                        Oxer
                                        For me it works fine in SU 2016 & SU2017.
                                        Use:
                                        1. Run the plugin, place the camera where you want and press Shift+Q --> this creates a Camera Key 1
                                        2. Move the camera and press Shift+Q --> this creates a Camera Key 2 and so successively.
                                        3. When you have finished press Enter, appear a popup window with different options, set them like you want.
                                        4. Press OK button to create the scenes.
                                        If you want edit the created curves change the Camera to Parallel Projection and the View to Top, then move the points of the curves.
                                        I hope this can help you.
                                        • E
                                          ehc2000
                                          First, I managed to use Wayback Machine and find and download " bezier.rb "
                                          (here's a link if people are having trouble: https://web.archive.org/web/20130718054436/http://rhin.crai.archi.fr/rld/plugin_details.php?id=33)
                                          Then I made your changes for it to work on OS X, Oxer, thank you, but I still have trouble. I can't get it to work as you describe or as seen in this video: https://www.youtube.com/watch?v=4ZNesZRknQI
                                          Basically, every time I want to move or reposition the camera using the Orbit or Pan tools, the Camera Key Maker on-screen display disappears and I need to go back to the menu and reselect Camera Key Maker to input the subsequent keys. Any thoughts on how to keep Camera Key Maker 'active' while I rotate the view using the Orbit or Pan tools? I can, for instance, keep it active when I zoom by scrolling on the trackpad, but I can't do anything else. I can add a shortcut for Camera Key Maker easily enough but I wonder if I'm missing something or if there's something broken, perhaps?
                                          Would be thrilled if you have any suggestions. Thanks!
                                          Use:
                                          • OxerO
                                            Oxer
                                            I don't know what's your problem, for me works fine on OS X 10.11.6 and SU2017, try with this plugin modified to work on Mac.
                                            Camera Key Maker OS X
                                            Sometimes there is a conflict with another plugin.
                                            • 4 / 6
