    WIP: European Back Alley
    46 Posts 14 Posters 4.7k Views 14 Watching
      smokinbakin
      @sepo said:
      The size of the stones at near top of the arch look way small. It looks like it could fall any minute.
      Thanks for the help I will fix that shortly.
      @sir said:
      its not symmetrical
      That was intentional to give it a worn down old appearance.
      "Set your goals low, and hope you don't get lower"
        Sir
        yes but in the olden days they build them properly or they didnt stand up at all! and i think your would have collapsed a long time ago...
        but hey, thats what artistic license is for πŸ˜‰
          smokinbakin
          Here is and update, including a reference photo which a am mostly modeling after, but I will change a few things to my liking.
          In Sketchup
          V-ray render
          Reference photo
            sepo
            Exactly...arch is same thickness all around, otherwise it would collapse.
              smokinbakin
              I think I will just make all the little stones near the top bigger, and just ignore the fact that my arch would collapse in real life πŸ˜„
                sepo
                Part of believeable render is that it resembles real and correct. If your arch does not read correct it will always poke you in the eye...πŸ˜‰
                  smokinbakin
                  Well I will do what I can to fix the problem, If you want to have a go fixing the problem, here is the Arch.
                  the arch
                  • artysmediaA Offline
                    artysmedia
                    I would like to be able to make something similar to this someday...
                    I want to see more! πŸ‘
                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                    Blog: Artysmedia
                      smokinbakin
                      Here is part of the model I have textured, I rendered it in V-Ray attempting a evening look. I have included the visopt settings at the bottom, renamed as a ruby script.
                      Evening shot
                      Evening render settings
                      • marked001M Offline
                        marked001
                        looking awesome so far...
                        http://www.revision21vis.com
                        instagram: revi21on
                          artysmedia
                          Good job with light and textures... waiting for more more more πŸ‘
                          Blog: Artysmedia
                            smokinbakin
                            Thanks for the comments! Here is another render, I tried to make it a bit brighter.
                            • olisheaO Offline
                              olishea
                              it looks real, nice texturing. I enjoy looking at this post. although I would reduce the opacity of your vignette layer πŸ˜‰
                              oli
                              • brodieB Offline
                                brodie
                                I agree, it's looking really promising! Fun thread to follow along with as more comes out πŸ˜„
                                I'm with olishea on the rendering but then again I hate it when people start nitpicking my WIP so I won't say anything about that πŸ˜„
                                -Brodie
                                  cadmunkey
                                  nice model, I look forward to more progress.
                                  • massimoM Offline
                                    massimo Moderator
                                    Very nice model so far. But comparing your model with the real photo i can say:
                                    1. The proportion between the width of the alley and the height of the buildings is wrong and very improbable in a medieval city. The right side building has to be higher and the alley tighter;
                                    2. You have a strange, and quite impossible, floor join in the right side building: the backline of the door-window of the first floor is under the top edge of the door on the ground floor;
                                    3. The left side building has, in the reference photo, a crooked front that ideally converge towards the arch. The same for the building of the right side: his front is aligned with the arch;
                                    4. The real alley has no sidewalks.
                                      I understand that your model in not intended to be β€œreal”, but when you design a street or a square, proportions and relationships between the open spaces and buildings are really important to represent a place, even an imaginary one.
                                      Sorry, i know, i’m a boring european architect πŸ˜‰
                                      smokinbakin
                                      I appreciate the help, but I am not trying to exactly model the photo, It was just use as a basis for my model. As for the impossible floor join, I am hoping one in a thousand people will actually notice it. But thanks for the help πŸ‘
                                      • EdsonE Offline
                                        Edson
                                        @solo said:
                                        It's free:
                                        An Ivy Generator
                                        (graphics.uni-konstanz.de)
                                        have you played with that? i wonder how sketchup would deal with the polys involved in those ivies.
                                        http://www.mahfuz.arq.br
                                        • soloS Offline
                                          solo
                                          Edson, I certainly have and really like it, but I do not import the final .obj into SU as SU cannot handle the polys, I export my model and Ivy into a 3rd party render app instead.
                                          http://www.solos-art.com
                                          • EdsonE Offline
                                            Edson
                                            i imagined that. thanks for the info.
                                            • 2 / 3
