    WIP: European Back Alley
    46 Posts 14 Posters 6.6k Views 14 Watching
    • marked001M Offline
      marked001
      looking awesome so far...
      http://www.revision21vis.com
      instagram: revi21on
      • artysmediaA Offline
        artysmedia
        Good job with light and textures... waiting for more more more πŸ‘
        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
        Blog: Artysmedia
          smokinbakin
          Thanks for the comments! Here is another render, I tried to make it a bit brighter.
          "Set your goals low, and hope you don't get lower"
          • olisheaO Offline
            olishea
            it looks real, nice texturing. I enjoy looking at this post. although I would reduce the opacity of your vignette layer πŸ˜‰
            oli
            • brodieB Offline
              brodie
              I agree, it's looking really promising! Fun thread to follow along with as more comes out πŸ˜„
              I'm with olishea on the rendering but then again I hate it when people start nitpicking my WIP so I won't say anything about that πŸ˜„
              -Brodie
                cadmunkey
                nice model, I look forward to more progress.
                • massimoM Offline
                  massimo Moderator
                  Very nice model so far. But comparing your model with the real photo i can say:
                  1. The proportion between the width of the alley and the height of the buildings is wrong and very improbable in a medieval city. The right side building has to be higher and the alley tighter;
                  2. You have a strange, and quite impossible, floor join in the right side building: the backline of the door-window of the first floor is under the top edge of the door on the ground floor;
                  3. The left side building has, in the reference photo, a crooked front that ideally converge towards the arch. The same for the building of the right side: his front is aligned with the arch;
                  4. The real alley has no sidewalks.
                    I understand that your model in not intended to be β€œreal”, but when you design a street or a square, proportions and relationships between the open spaces and buildings are really important to represent a place, even an imaginary one.
                    Sorry, i know, i’m a boring european architect πŸ˜‰
                    smokinbakin
                    I appreciate the help, but I am not trying to exactly model the photo, It was just use as a basis for my model. As for the impossible floor join, I am hoping one in a thousand people will actually notice it. But thanks for the help πŸ‘
                    • EdsonE Offline
                      Edson
                      @solo said:
                      It's free:
                      http://graphics.uni-konstanz.de/~luft/ivy_generator/
                      have you played with that? i wonder how sketchup would deal with the polys involved in those ivies.
                      http://www.mahfuz.arq.br
                      • soloS Offline
                        Edson, I certainly have and really like it, but I do not import the final .obj into SU as SU cannot handle the polys, I export my model and Ivy into a 3rd party render app instead.
                        • EdsonE Offline
                          Edson
                          i imagined that. thanks for the info.
                            smokinbakin
                            Update, this render is very experimental as you can tell from the lighting,( I probably need to add more photons) comments on textures and modeling welcome.
                            BTW- Does anyone know how to un smooth something after it has already been smoothed? I want to fix the infamous impossible arch. πŸ˜„
                            • olisheaO Offline
                              olishea
                              can't you triple click the arch/stones and then open the soften edges window and turn the soft edges off? or have u subsmoothed it?
                              looking awesome. the texturing looks fantastic. all u need now is a bit more dirt on the road/paving. I can imagine getting mugged in this back alley!
                              oli
                                smokinbakin
                                Oli: That is what I tried, but it is grayed out.
                                  smokinbakin
                                  With Picasa tint
                                  Indigo with Picasa
                                    smokinbakin
                                    After a long break from this project, finally found some time to texture, also started in Indigo. I gave up on Indigo a while ago, but checking back proved to be a good choice as the new versions are a ton better, and if you have not tried them, you really need to.
                                    Note: I will post a bigger version tomorrow.
                                    Indigo
                                      smokinbakin
                                      Bigger Version
                                      • 2 / 3
