    WIP: European Back Alley
    46 Posts 14 Posters 5.8k Views 14 Watching
      smokinbakin
      @sepo said:
      Looks good so far, but that arch looks dodgy πŸ˜‰
      The shape, or the rocks?
      "Set your goals low, and hope you don't get lower"
        Sir
        its not symmetrical
          sepo
          The size of the stones at near top of the arch look way small. It looks like it could fall any minute.
            smokinbakin
            Thanks for the help I will fix that shortly.
            @sir said:
            its not symmetrical
            That was intentional to give it a worn down old appearance.
              Sir
              yes but in the olden days they build them properly or they didnt stand up at all! and i think your would have collapsed a long time ago...
              but hey, thats what artistic license is for πŸ˜‰
                smokinbakin
                Here is and update, including a reference photo which a am mostly modeling after, but I will change a few things to my liking.
                In Sketchup
                V-ray render
                Reference photo
                  sepo
                  Exactly...arch is same thickness all around, otherwise it would collapse.
                    smokinbakin
                    I think I will just make all the little stones near the top bigger, and just ignore the fact that my arch would collapse in real life πŸ˜„
                      sepo
                      Part of believeable render is that it resembles real and correct. If your arch does not read correct it will always poke you in the eye...πŸ˜‰
                        smokinbakin
                        Well I will do what I can to fix the problem, If you want to have a go fixing the problem, here is the Arch.
                        the arch
                        • artysmediaA Offline
                          artysmedia
                          I would like to be able to make something similar to this someday...
                          I want to see more! πŸ‘
                          Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                          Blog: Artysmedia
                            smokinbakin
                            Here is part of the model I have textured, I rendered it in V-Ray attempting a evening look. I have included the visopt settings at the bottom, renamed as a ruby script.
                            Evening shot
                            Evening render settings
                            • marked001M Offline
                              marked001
                              looking awesome so far...
                              http://www.revision21vis.com
                              instagram: revi21on
                                artysmedia
                                Good job with light and textures... waiting for more more more πŸ‘
                                Blog: Artysmedia
                                  smokinbakin
                                  Thanks for the comments! Here is another render, I tried to make it a bit brighter.
                                  • olisheaO Offline
                                    olishea
                                    it looks real, nice texturing. I enjoy looking at this post. although I would reduce the opacity of your vignette layer πŸ˜‰
                                    oli
                                    • brodieB Offline
                                      brodie
                                      I agree, it's looking really promising! Fun thread to follow along with as more comes out πŸ˜„
                                      I'm with olishea on the rendering but then again I hate it when people start nitpicking my WIP so I won't say anything about that πŸ˜„
                                      -Brodie
                                        cadmunkey
                                        nice model, I look forward to more progress.
                                        • massimoM Offline
                                          massimo Moderator
                                          Very nice model so far. But comparing your model with the real photo i can say:
                                          1. The proportion between the width of the alley and the height of the buildings is wrong and very improbable in a medieval city. The right side building has to be higher and the alley tighter;
                                          2. You have a strange, and quite impossible, floor join in the right side building: the backline of the door-window of the first floor is under the top edge of the door on the ground floor;
                                          3. The left side building has, in the reference photo, a crooked front that ideally converge towards the arch. The same for the building of the right side: his front is aligned with the arch;
                                          4. The real alley has no sidewalks.
                                            I understand that your model in not intended to be β€œreal”, but when you design a street or a square, proportions and relationships between the open spaces and buildings are really important to represent a place, even an imaginary one.
                                            Sorry, i know, i’m a boring european architect πŸ˜‰
                                            smokinbakin
                                            I appreciate the help, but I am not trying to exactly model the photo, It was just use as a basis for my model. As for the impossible floor join, I am hoping one in a thousand people will actually notice it. But thanks for the help πŸ‘
                                            • 2 / 3
