    WIP: European Back Alley
    46 Posts 14 Posters 5.5k Views 14 Watching
    • artysmediaA Offline
      artysmedia
      I would like to be able to make something similar to this someday...
      I want to see more! πŸ‘
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        smokinbakin
        Here is part of the model I have textured, I rendered it in V-Ray attempting a evening look. I have included the visopt settings at the bottom, renamed as a ruby script.
        Evening shot
        Evening render settings
        "Set your goals low, and hope you don't get lower"
        • marked001M Offline
          marked001
          looking awesome so far...
          http://www.revision21vis.com
          instagram: revi21on
            artysmedia
            Good job with light and textures... waiting for more more more πŸ‘
            Blog: Artysmedia
              smokinbakin
              Thanks for the comments! Here is another render, I tried to make it a bit brighter.
              • olisheaO Offline
                olishea
                it looks real, nice texturing. I enjoy looking at this post. although I would reduce the opacity of your vignette layer πŸ˜‰
                oli
                • brodieB Offline
                  brodie
                  I agree, it's looking really promising! Fun thread to follow along with as more comes out πŸ˜„
                  I'm with olishea on the rendering but then again I hate it when people start nitpicking my WIP so I won't say anything about that πŸ˜„
                  -Brodie
                    cadmunkey
                    nice model, I look forward to more progress.
                    • massimoM Offline
                      massimo Moderator
                      Very nice model so far. But comparing your model with the real photo i can say:
                      1. The proportion between the width of the alley and the height of the buildings is wrong and very improbable in a medieval city. The right side building has to be higher and the alley tighter;
                      2. You have a strange, and quite impossible, floor join in the right side building: the backline of the door-window of the first floor is under the top edge of the door on the ground floor;
                      3. The left side building has, in the reference photo, a crooked front that ideally converge towards the arch. The same for the building of the right side: his front is aligned with the arch;
                      4. The real alley has no sidewalks.
                        I understand that your model in not intended to be β€œreal”, but when you design a street or a square, proportions and relationships between the open spaces and buildings are really important to represent a place, even an imaginary one.
                        Sorry, i know, i’m a boring european architect πŸ˜‰
                        smokinbakin
                        I appreciate the help, but I am not trying to exactly model the photo, It was just use as a basis for my model. As for the impossible floor join, I am hoping one in a thousand people will actually notice it. But thanks for the help πŸ‘
                        • EdsonE Offline
                          Edson
                          @solo said:
                          It's free:
                          An Ivy Generator
                          (graphics.uni-konstanz.de)
                          have you played with that? i wonder how sketchup would deal with the polys involved in those ivies.
                          http://www.mahfuz.arq.br
                          • soloS Offline
                            Edson, I certainly have and really like it, but I do not import the final .obj into SU as SU cannot handle the polys, I export my model and Ivy into a 3rd party render app instead.
                            • EdsonE Offline
                              Edson
                              i imagined that. thanks for the info.
                                smokinbakin
                                Update, this render is very experimental as you can tell from the lighting,( I probably need to add more photons) comments on textures and modeling welcome.
                                BTW- Does anyone know how to un smooth something after it has already been smoothed? I want to fix the infamous impossible arch. πŸ˜„
                                • olisheaO Offline
                                  olishea
                                  can't you triple click the arch/stones and then open the soften edges window and turn the soft edges off? or have u subsmoothed it?
                                  looking awesome. the texturing looks fantastic. all u need now is a bit more dirt on the road/paving. I can imagine getting mugged in this back alley!
                                  oli
                                    smokinbakin
                                    Oli: That is what I tried, but it is grayed out.
                                      smokinbakin
                                      With Picasa tint
                                      Indigo with Picasa
                                        smokinbakin
                                        After a long break from this project, finally found some time to texture, also started in Indigo. I gave up on Indigo a while ago, but checking back proved to be a good choice as the new versions are a ton better, and if you have not tried them, you really need to.
                                        Note: I will post a bigger version tomorrow.
                                        Indigo
                                          smokinbakin
                                          Bigger Version
                                          • 2 / 3
