    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 642.5k Views 151 Watching
      MarcusS @Rich O Brien
      @Rich-O-Brien, yes, that worked. Thanks!
        RASKL
        Hello. I've been using Fredocorner for a number of years but it has recently stopped working.
        I am on SU 25.0.660 64 bit. Windows.
        I hover over the toolbar and i get the label saying "Round corners in 3D" but when i click the buttons nothing happens.
        Please help!
        Dan
          @RASKL
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
            Gent
            Dear Fredo! I thank you for your work. It means a lot to me as an aspiring designer. I bought some of your products and they are great. But I have a question and I do not know where to ask it to get your answer. Situation: I want to stop working on the Windows 10 operating system and upgrade to version 11. Will the licenses for your plugins that I bought be relevant? Will I be able to use them on the new operating system? Thank you.
              Rich O Brien Moderator @Gent
              @Gent
              Yes, they will work. You will need to release seats at https://sketchucation.com/webshop/my-licences.php because if the device is the same but the OS changes then the licensing will see it as a new device.
                Gent
                @Rich-O-Brien Thank you for your quick answer!
                  ArqFigueroa
                  Hi ! Can somebody help me please, Been working with the free version but after pay the license it stop working
                    Rich O Brien Moderator @ArqFigueroa
                    @ArqFigueroa Share the file please
                      ArqFigueroa
                      It happens with any file, even in a new one 😞
                        @ArqFigueroa Please enable this edge setting
                          ArqFigueroa
                          Ooh it works ! Thank you so much !!!
                            @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
                              GraceMien Newcomers
                              Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
                              G 1 Reply Last reply Reply Quote 1
                                Click the edge and type the variable offset in the VCB as either a length/radius or %
                                  GraceMien Newcomers @GraceMien
                                  Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                                  1 Reply Last reply πŸ‘ Reply Quote 1
                                    talegend
                                    this license has a different name , when I click on activate license i can't see the lices
                                    license for round corner doesn't have FredoCorner word and that's why I can't see it
                                    I can't activate this ,
                                    Fredo Push Pull worked fine , but this one is not showing
                                      Dave R @talegend
                                      @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                                      Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                                        rv1974
                                          JanSteinman Newcomers
                                          I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                                          Am I doing something wrong?
                                          • TIGT Online
                                            How big is that object ?
                                            Small geometry has issues because points closer than 1/1000" are regarded as coincident by SketchUp's engine.
                                            So tiny edges aren't made and the associated face can't be supported.
                                            Have you tried scaling it up x100 [or more] doing the 'rounding' then scaling it back down.
                                            Tiny geometry can exist within a model, but it can't be created by SketchUp.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
