    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 642.5k Views 151 Watching
      Rich O Brien Moderator @Gent
      @Gent
      I want to stop working on the Windows 10 operating system and upgrade to version 11. Will the licenses for your plugins that I bought be relevant? Will I be able to use them on the new operating system?
      Yes, they will work. You will need to release seats at https://sketchucation.com/webshop/my-licences.php because if the device is the same but the OS changes then the licensing will see it as a new device.
        Gent
        @Rich-O-Brien Thank you for your quick answer!
          ArqFigueroa
          Hi ! Can somebody help me please, Been working with the free version but after pay the license it stop working
            Rich O Brien Moderator @ArqFigueroa
            @ArqFigueroa Share the file please
              ArqFigueroa
              It happens with any file, even in a new one 😞
                @ArqFigueroa Please enable this edge setting
                  ArqFigueroa
                  Ooh it works ! Thank you so much !!!
                    @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
                      GraceMien Newcomers
                      Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
                      G 1 Reply Last reply Reply Quote 1
                        Click the edge and type the variable offset in the VCB as either a length/radius or %
                          GraceMien Newcomers @GraceMien
                          Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                          1 Reply Last reply πŸ‘ Reply Quote 1
                            talegend
                            this license has a different name , when I click on activate license i can't see the lices
                            license for round corner doesn't have FredoCorner word and that's why I can't see it
                            I can't activate this ,
                            Fredo Push Pull worked fine , but this one is not showing
                              Dave R @talegend
                              @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                              Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                                rv1974
                                  JanSteinman Newcomers
                                  I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                                  Am I doing something wrong?
                                  • TIGT Online
                                    How big is that object ?
                                    Small geometry has issues because points closer than 1/1000" are regarded as coincident by SketchUp's engine.
                                    So tiny edges aren't made and the associated face can't be supported.
                                    Have you tried scaling it up x100 [or more] doing the 'rounding' then scaling it back down.
                                    Tiny geometry can exist within a model, but it can't be created by SketchUp.
                                    • 19
                                    • 20
                                    • 21
                                    • 22
                                    • 23
                                    • 22 / 23
