    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
      @MarcusS If you got to https://sketchucation.com/webshop/my-licences.php can you release any seats?
      M 1 Reply Last reply
        MarcusS @Rich O Brien
        @Rich-O-Brien, yes, that worked. Thanks!
          RASKL
          Hello. I've been using Fredocorner for a number of years but it has recently stopped working.
          I am on SU 25.0.660 64 bit. Windows.
          I hover over the toolbar and i get the label saying "Round corners in 3D" but when i click the buttons nothing happens.
          Please help!
          Dan
            @RASKL
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
            • G
              Gent
              Dear Fredo! I thank you for your work. It means a lot to me as an aspiring designer. I bought some of your products and they are great. But I have a question and I do not know where to ask it to get your answer. Situation: I want to stop working on the Windows 10 operating system and upgrade to version 11. Will the licenses for your plugins that I bought be relevant? Will I be able to use them on the new operating system? Thank you.
                Rich O Brien Moderator @Gent
                @Gent
                Yes, they will work. You will need to release seats at https://sketchucation.com/webshop/my-licences.php because if the device is the same but the OS changes then the licensing will see it as a new device.
                • G
                  Gent
                  @Rich-O-Brien Thank you for your quick answer!
                    ArqFigueroa
                    Hi ! Can somebody help me please, Been working with the free version but after pay the license it stop working
                      Rich O Brien Moderator @ArqFigueroa
                      @ArqFigueroa Share the file please
                        ArqFigueroa
                        It happens with any file, even in a new one 😞
                          @ArqFigueroa Please enable this edge setting
                            ArqFigueroa
                            Ooh it works ! Thank you so much !!!
                              @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
                              • G
                                GraceMien Newcomers
                                Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
                                G 1 Reply Last reply
                                  Click the edge and type the variable offset in the VCB as either a length/radius or %
                                  • G
                                    GraceMien Newcomers @GraceMien
                                    Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                                    1 Reply Last reply πŸ‘
                                    • T
                                      talegend
                                      this license has a different name , when I click on activate license i can't see the lices
                                      license for round corner doesn't have FredoCorner word and that's why I can't see it
                                      I can't activate this ,
                                      Fredo Push Pull worked fine , but this one is not showing
                                      Dave RD 1 Reply Last reply
                                        Dave R @talegend
                                        @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                                        Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                                          rv1974
                                            JanSteinman Newcomers
                                            I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                                            Am I doing something wrong?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
