    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
      RASKL
      Hello. I've been using Fredocorner for a number of years but it has recently stopped working.
      I am on SU 25.0.660 64 bit. Windows.
      I hover over the toolbar and i get the label saying "Round corners in 3D" but when i click the buttons nothing happens.
      Please help!
      Dan
        @RASKL
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        • G
          Gent
          Dear Fredo! I thank you for your work. It means a lot to me as an aspiring designer. I bought some of your products and they are great. But I have a question and I do not know where to ask it to get your answer. Situation: I want to stop working on the Windows 10 operating system and upgrade to version 11. Will the licenses for your plugins that I bought be relevant? Will I be able to use them on the new operating system? Thank you.
            Rich O Brien Moderator @Gent
            @Gent
            Yes, they will work. You will need to release seats at https://sketchucation.com/webshop/my-licences.php because if the device is the same but the OS changes then the licensing will see it as a new device.
            • G
              Gent
              @Rich-O-Brien Thank you for your quick answer!
                ArqFigueroa
                Hi ! Can somebody help me please, Been working with the free version but after pay the license it stop working
                  Rich O Brien Moderator @ArqFigueroa
                  @ArqFigueroa Share the file please
                    ArqFigueroa
                    It happens with any file, even in a new one 😞
                      @ArqFigueroa Please enable this edge setting
                        ArqFigueroa
                        Ooh it works ! Thank you so much !!!
                          @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
                          • G
                            GraceMien Newcomers
                            Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
                            G 1 Reply Last reply
                              Click the edge and type the variable offset in the VCB as either a length/radius or %
                              • G
                                GraceMien Newcomers @GraceMien
                                Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                                1 Reply Last reply πŸ‘
                                • T
                                  talegend
                                  this license has a different name , when I click on activate license i can't see the lices
                                  license for round corner doesn't have FredoCorner word and that's why I can't see it
                                  I can't activate this ,
                                  Fredo Push Pull worked fine , but this one is not showing
                                  Dave RD 1 Reply Last reply
                                    Dave R @talegend
                                    @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                                    Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                                      rv1974
                                        JanSteinman Newcomers
                                        I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                                        Am I doing something wrong?
                                          How big is that object ?
                                          Small geometry has issues because points closer than 1/1000" are regarded as coincident by SketchUp's engine.
                                          So tiny edges aren't made and the associated face can't be supported.
                                          Have you tried scaling it up x100 [or more] doing the 'rounding' then scaling it back down.
                                          Tiny geometry can exist within a model, but it can't be created by SketchUp.
                                          • 19
                                          • 20
                                          • 21
                                          • 22
                                          • 23
                                          • 22 / 23
