    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 618.8k Views 151 Watching
      ArqFigueroa
      It happens with any file, even in a new one 😞
      • Rich O BrienR Online
        @ArqFigueroa Please enable this edge setting
          ArqFigueroa
          Ooh it works ! Thank you so much !!!
            Rich O Brien Moderator @ArqFigueroa
            @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
              GraceMien Newcomers
              Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
              G 1 Reply Last reply Reply Quote 1
                Click the edge and type the variable offset in the VCB as either a length/radius or %
                  GraceMien Newcomers @GraceMien
                  Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
                  1 Reply Last reply πŸ‘ Reply Quote 1
                    talegend
                    this license has a different name , when I click on activate license i can't see the lices
                    license for round corner doesn't have FredoCorner word and that's why I can't see it
                    I can't activate this ,
                    Fredo Push Pull worked fine , but this one is not showing
                      Dave R @talegend
                      @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                      Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                        rv1974
                          JanSteinman Newcomers
                          I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                          Am I doing something wrong?
                            How big is that object ?
                            Small geometry has issues because points closer than 1/1000" are regarded as coincident by SketchUp's engine.
                            So tiny edges aren't made and the associated face can't be supported.
                            Have you tried scaling it up x100 [or more] doing the 'rounding' then scaling it back down.
                            Tiny geometry can exist within a model, but it can't be created by SketchUp.
                            • 19
                            • 20
                            • 21
                            • 22
                            • 23
                            • 22 / 23
