    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
      ArqFigueroa
      Ooh it works ! Thank you so much !!!
        Rich O Brien Moderator @ArqFigueroa
        @ArqFigueroa It is the edge property filter. You had yours set to not select Hard edges.
        • G
          GraceMien Newcomers
          Hi there! I was curious if it's possible to round a corner with an uneven offset? I'm looking through guides and documentation, but I figured it would probably be easier to just ask the source directly instead of spending a couple hours researching a feature that might not even exist. Thank you for your time!
          G 1 Reply Last reply
            Click the edge and type the variable offset in the VCB as either a length/radius or %
            • G
              GraceMien Newcomers @GraceMien
              Oh awesome! Thank you so much for such a quick and helpful reply. I really appreciate it.
              1 Reply Last reply πŸ‘
              • T
                talegend
                this license has a different name , when I click on activate license i can't see the lices
                license for round corner doesn't have FredoCorner word and that's why I can't see it
                I can't activate this ,
                Fredo Push Pull worked fine , but this one is not showing
                Dave RD 1 Reply Last reply
                  Dave R @talegend
                  @talegend said in [Plugin][$] FredoCorner - v2.7a - 31 Mar 24:
                  Round Corner and FredoCorner are two different extensions and each requires a different license. Which one did you actually purchase the license for? Install that one.
                    rv1974
                      JanSteinman Newcomers
                      I am unable to get FredoCorner to work properly. It often displays ugly artifacts. I even created a new version of this from scratch β€” same artifacts when I use FredoCorner!
                      Am I doing something wrong?
                        How big is that object ?
                        Small geometry has issues because points closer than 1/1000" are regarded as coincident by SketchUp's engine.
                        So tiny edges aren't made and the associated face can't be supported.
                        Have you tried scaling it up x100 [or more] doing the 'rounding' then scaling it back down.
                        Tiny geometry can exist within a model, but it can't be created by SketchUp.
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 23 / 23
