    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • KrassK
      Krass
      Hello, thomas,
      sorry for the late reply
      I will try to answer tonight
      Krass
      KrassK 1 Reply Last reply
      • KrassK
        Krass @Krass
        rays.png ![@Krass](image url)
        I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
        Krass
        pixelcruncherP 2 Replies Last reply
        • pixelcruncherP
          @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
          To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
          Cheers,
          Thomas
          • KrassK
            Krass
            Helo Thomas,
            Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
            https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
            Krass
            • KrassK
              Krass
              Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
              https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
              Krass
              • pixelcruncherP
                Hey, Rayscaper users!
                Another release!
                Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                What Changed?
                • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
                  shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
                  in indoor scenes.
                • Add extra logging to help diagnose failed installations.
                • Cyrillic glyph support: The user interface now supports Cyrillic characters.
                • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
                • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
                Help me build the community πŸ‘
                If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
                Happy Rendering!
                majidM 1 Reply Last reply
                • majidM
                  majid
                  Those renders are lovely!
                  • KrassK
                    Krass
                    Great!
                    Thank you!
                    Krass
                    • majidM
                      majid @pixelcruncher
                      @pixelcruncher I DMed you, do you mind checking it please?
                      • KrassK
                        Krass
                        I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
                        Krass
                        • pixelcruncherP
                          @Krass Great to hear that! Still more good stuff coming.
                          • majidM
                            majid
                            How may I share a "carpaint" material pack?
                            If it is easier to make it in another app and share (online or locally) or use the RS?
                            How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                              @majid
                              If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
                              If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
                              Reply Quote 2
                              • pixelcruncherP
                                Back from a holiday, but whatever Rich says makes sense πŸ™‚
                                • KrassK
                                  Krass
                                  hello,
                                  I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
                                  Krass
                                  Mike AmosM 1 Reply Last reply
                                    Mike Amos @Krass
                                    @Krass
                                    Not heard that and frankly it is nonsensical.
                                    Rayscaper is being developed by one very hard working human being in his off work hours.
                                    You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
                                    • pixelcruncherP
                                      To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
                                      You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
                                        Rich O Brien Moderator @pixelcruncher
                                        @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
                                        Interior render using Rayscaper for SketchUp no denoising
                                        Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
                                        Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
                                        Interior render using Rayscaper for SketchUp with denoising
                                        Reply Quote 6
                                          I think he is doing a great job tbh. No complaints.
                                          Reply Quote 2
                                          • pixelcruncherP
                                            The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                                            • 26
                                            • 27
                                            • 6 / 27
