    Rayscaper New Releases
    rayscaperrender
    401 Posts 10 Posters 25.2k Views 11 Watching
    • KrassK Offline
      Krass
      Helo Thomas,
      Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
      https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
      Krass
      • KrassK Offline
        Krass
        Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
        https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
        Krass
          Hey, Rayscaper users!
          Another release!
          Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
          What Changed?
          • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
            shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
            in indoor scenes.
          • Add extra logging to help diagnose failed installations.
          • Cyrillic glyph support: The user interface now supports Cyrillic characters.
          • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
          • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
          Help me build the community πŸ‘
          If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
          Happy Rendering!
          • majidM Offline
            majid
            Those renders are lovely!
            • KrassK Offline
              Krass
              Great!
              Thank you!
              Krass
              • majidM Offline
                majid @pixelcruncher
                @pixelcruncher I DMed you, do you mind checking it please?
                • KrassK Offline
                  Krass
                  I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
                  Krass
                  P 1 Reply Last reply Reply Quote 1
                    @Krass Great to hear that! Still more good stuff coming.
                    • majidM Offline
                      majid
                      How may I share a "carpaint" material pack?
                      If it is easier to make it in another app and share (online or locally) or use the RS?
                      How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                      • Rich O BrienR Online
                        @majid
                        If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
                        If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
                          Back from a holiday, but whatever Rich says makes sense πŸ™‚
                          • KrassK Offline
                            Krass
                            hello,
                            I thought I read above that Rayscaper had become free, exactly I read that there was no longer a limitation on rendering size. Thank you for confirming this.
                            Krass
                              Mike Amos @Krass
                              @Krass
                              Not heard that and frankly it is nonsensical.
                              Rayscaper is being developed by one very hard working human being in his off work hours.
                              You need to be very careful when using the internet for information, spelling and slight word differences can lead you right up the garden path into the manure pile.
                                To clarify, Rayscaper is commercial software. A license costs $99 or $74.99 for SketchUcation users.
                                You can use Rayscaper for free, but then it has a watermark over the render. I removed the limitation on rendering size, as I didn't want to spend my energy on crippling the experience in the free version. I still want you to have a great experience, even with the free version, in the hope that that can convince you to support the work and buy a license (which you both did, so thanks for that!). And if you don't want to buy the license, that's cool too.
                                  Rich O Brien Moderator @pixelcruncher
                                  @pixelcruncher is hard at work crushing bugs and adding quality of life stuff for the next release....
                                  Interior render using Rayscaper for SketchUp no denoising
                                  Above was 5000 samples at 2k resolution on a 4080 card with no denoising in 14.5mins
                                  Below was 500 samples at 2k resolution on a 4080 card with denoising in 1.5mins
                                  Interior render using Rayscaper for SketchUp with denoising
                                  majidM 1 Reply Last reply Reply Quote 6
                                    I think he is doing a great job tbh. No complaints.
                                      The next release is coming soon. I was working on a lot of internal stuff in the engine. In the future, I plan to do more frequent releases, as they give me a tighter feedback cycle and make the process less lonely.
                                        Another release with some bug fixes. Thanks for reporting all those bugs!
                                        Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                                        What Changed?
                                        • Fix weird artifacts in the interactive render viewport.
                                        • Fix the upside-down images when saving.
                                        • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                                        • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp light component again.
                                        • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                                        • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                                        Help Me Build the Community πŸ‘
                                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                                        and helps me showcase its capabilities to new users.
                                        Follow me on Twitter.
                                        Happy Rendering!
                                          Yay! Great update Thomas
                                            sashapepperspray
                                            thank you for the new release.
                                            I noticed two bugs with this release
                                            1. it does not Support SketchUp material inheritance anymore. Faces, or objects that have the default material painted on them, but the group that they are in have a material, show up as unpainted (with the default material).
                                            2. the rendered images have a watermark on the bottom, even though I have a license (and I doublechecked that it is connected)
                                              [as a side note, any idea when you will connect the sketchup pbr materials to the rayscaper material properties, so that I don't need to set up metalness, roughness, etc, twice?]
                                            • 20
                                            • 21
                                            • 2 / 21
