    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.3k Views 15 Watching
      Thomas was is aware of the incompatibility with 2025.
      • pixelcruncherP
        Hey, Rayscaper users!
        Another release!
        Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
        What Changed?
        • Added support for SketchUp 2025.
        • Fixed energy loss in glass materials, which previously caused them to appear too dark.
        • Made asset thumbnail size configurable via the settings dialog.
        • Fixed reloading of SketchUp materials in Rayscaper.
        • Fixed light emission issues with HDRI environments.
        • Removed the 1000Γ—1000 pixel resolution limit for the free version.
        The asset thumbnail size is configured via the settings dialog:
        Help me build the community πŸ‘
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
        Happy Rendering!
        • pixelcruncherP
          pixelcruncher Extension Creator @sashapepperspray
          @sashapepperspray said in Rayscaper New Releases:
          @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
          SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
          I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
          Cheers,
          Thomas
          S 1 Reply Last reply
            sashapepperspray @pixelcruncher
            @pixelcruncher Thanks, it works
            • KrassK
              Krass
              Hello, Pixelcruncher,
              I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
              But I didn't uninstall rayscaper before reinstalling,
              Krass
              • KrassK
                Krass
                that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
                Krass
                • KrassK
                  Krass
                  and thank you for removing the pixel resolution limitation
                  Krass
                  • pixelcruncherP
                    @Krass said in Rayscaper New Releases:
                    Hey @Krass ,
                    Can you check the version you are running?
                    If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                    After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                    Regards,
                    Thomas
                    • KrassK
                      Krass
                      Hello, thomas,
                      sorry for the late reply
                      I will try to answer tonight
                      Krass
                      KrassK 1 Reply Last reply
                      • KrassK
                        Krass @Krass
                        rays.png ![@Krass](image url)
                        I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                        Krass
                        pixelcruncherP 2 Replies Last reply
                        • pixelcruncherP
                          @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
                          To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
                          Cheers,
                          Thomas
                          • KrassK
                            Krass
                            Helo Thomas,
                            Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
                            https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
                            Krass
                            • KrassK
                              Krass
                              Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
                              https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
                              Krass
                              • pixelcruncherP
                                Another release!
                                Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                                What Changed?
                                • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
                                  shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
                                  in indoor scenes.
                                • Add extra logging to help diagnose failed installations.
                                • Cyrillic glyph support: The user interface now supports Cyrillic characters.
                                • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
                                • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
                                Happy Rendering!
                                majidM 1 Reply Last reply
                                • majidM
                                  majid
                                  Those renders are lovely!
                                  • KrassK
                                    Krass
                                    Great!
                                    Thank you!
                                    Krass
                                    • majidM
                                      majid @pixelcruncher
                                      @pixelcruncher I DMed you, do you mind checking it please?
                                      • KrassK
                                        Krass
                                        I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
                                        Krass
                                        • pixelcruncherP
                                          @Krass Great to hear that! Still more good stuff coming.
                                          • majidM
                                            majid
                                            How may I share a "carpaint" material pack?
                                            If it is easier to make it in another app and share (online or locally) or use the RS?
                                            How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                                            • 39
                                            • 40
                                            • 5 / 40
