    Rayscaper New Releases
    rayscaperrender
    475 Posts 12 Posters 217.6k Views 13 Watching
    • P
      Hey, Rayscaper users!
      Another release!
      Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
      What Changed?
      • Added support for SketchUp 2025.
      • Fixed energy loss in glass materials, which previously caused them to appear too dark.
      • Made asset thumbnail size configurable via the settings dialog.
      • Fixed reloading of SketchUp materials in Rayscaper.
      • Fixed light emission issues with HDRI environments.
      • Removed the 1000Γ—1000 pixel resolution limit for the free version.
      The asset thumbnail size is configured via the settings dialog:
      Help me build the community πŸ‘
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
      Happy Rendering!
      • P
        pixelcruncher Extension Creator @sashapepperspray
        @sashapepperspray said in Rayscaper New Releases:
        @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
        SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
        I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
        Cheers,
        Thomas
        S 1 Reply Last reply
          sashapepperspray @pixelcruncher
          @pixelcruncher Thanks, it works
          • KrassK
            Krass
            Hello, Pixelcruncher,
            I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
            But I didn't uninstall rayscaper before reinstalling,
            Krass
            P 1 Reply Last reply
            • KrassK
              Krass
              that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
              Krass
              • KrassK
                Krass
                and thank you for removing the pixel resolution limitation
                Krass
                • P
                  @Krass said in Rayscaper New Releases:
                  Hey @Krass ,
                  Can you check the version you are running?
                  If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                  After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                  Regards,
                  Thomas
                  • KrassK
                    Krass
                    Hello, thomas,
                    sorry for the late reply
                    I will try to answer tonight
                    Krass
                    KrassK 1 Reply Last reply
                    • KrassK
                      Krass @Krass
                      rays.png ![@Krass](image url)
                      I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                      Krass
                      • P
                        @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
                        To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
                        Cheers,
                        Thomas
                        • KrassK
                          Krass
                          Helo Thomas,
                          Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
                          https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
                          Krass
                          • KrassK
                            Krass
                            Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
                            https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
                            Krass
                            • P
                              Another release!
                              Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                              What Changed?
                              • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
                                shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
                                in indoor scenes.
                              • Add extra logging to help diagnose failed installations.
                              • Cyrillic glyph support: The user interface now supports Cyrillic characters.
                              • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
                              • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
                              Happy Rendering!
                              majidM 1 Reply Last reply
                              • majidM
                                majid
                                Those renders are lovely!
                                • KrassK
                                  Krass
                                  Great!
                                  Thank you!
                                  Krass
                                  • majidM
                                    majid @pixelcruncher
                                    @pixelcruncher I DMed you, do you mind checking it please?
                                    • KrassK
                                      Krass
                                      I notice that your new default HDRI map intensity settings are excellent, almost no adjustments needed, it's a huge improvement
                                      Krass
                                      • P
                                        @Krass Great to hear that! Still more good stuff coming.
                                        • majidM
                                          majid
                                          How may I share a "carpaint" material pack?
                                          If it is easier to make it in another app and share (online or locally) or use the RS?
                                          How may I set a castum "preview" for the materials? If it is possible to change the "internal" material test scene?
                                            @majid
                                            If you go to C:\Users\SomeName\AppData\Roaming\Rayscaper\UserAssets you will find the custom materials you have made zipped.
                                            If you unzipped you will see the preview image. If you change that image and zip it making sure to delete the original zip and name the new one the same you get custom icons.
                                            Reply Quote 2
                                            • 23
                                            • 24
                                            • 5 / 24
