    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • KrassK
      Krass
      with rayscaper denoiser on
      https://jskup.fr/wp-content/uploads/2025/02/filter-box-plus-RSCaper-denoiser.png
      Krass
      • pixelcruncherP
        @Krass I like the result.
        FYI, Rayscaper uses Intel's OpenImageDenoise (link). I think this is the same denoiser that Twilight Render uses in its denoise extension, so you should see comparable results.
        • KrassK
          Krass
          final high res render, reduced in 1080 p and an other render, exterior
          https://jskup.fr/wp-content/uploads/2025/02/rayscaper-1080p.jpg
          https://jskup.fr/wp-content/uploads/2025/02/final2.jpg
          Krass
          KrassK 1 Reply Last reply
          Reply Quote 2
          • KrassK
            Krass @Krass
            I'm getting used to this little program
            https://jskup.fr/wp-content/uploads/2025/02/2denoised.jpg
            https://jskup.fr/wp-content/uploads/2025/02/4denoised.jpg
            Krass
            Reply Quote 2
            • pixelcruncherP
              Nice renders, especially the last one with the dinner plates.Nice use of DOF.
              S 1 Reply Last reply
                sashapepperspray @pixelcruncher
                @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
                  Thomas was is aware of the incompatibility with 2025.
                  • pixelcruncherP
                    Hey, Rayscaper users!
                    Another release!
                    Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                    What Changed?
                    • Added support for SketchUp 2025.
                    • Fixed energy loss in glass materials, which previously caused them to appear too dark.
                    • Made asset thumbnail size configurable via the settings dialog.
                    • Fixed reloading of SketchUp materials in Rayscaper.
                    • Fixed light emission issues with HDRI environments.
                    • Removed the 1000Γ—1000 pixel resolution limit for the free version.
                    The asset thumbnail size is configured via the settings dialog:
                    Help me build the community πŸ‘
                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
                    Happy Rendering!
                    • pixelcruncherP
                      pixelcruncher Extension Creator @sashapepperspray
                      @sashapepperspray said in Rayscaper New Releases:
                      SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
                      I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
                      Cheers,
                      Thomas
                        @pixelcruncher Thanks, it works
                        • KrassK
                          Krass
                          Hello, Pixelcruncher,
                          I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
                          But I didn't uninstall rayscaper before reinstalling,
                          Krass
                          • KrassK
                            Krass
                            that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
                            Krass
                            • KrassK
                              Krass
                              and thank you for removing the pixel resolution limitation
                              Krass
                              • pixelcruncherP
                                @Krass said in Rayscaper New Releases:
                                Hey @Krass ,
                                Can you check the version you are running?
                                If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                                After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                                Regards,
                                Thomas
                                • KrassK
                                  Krass
                                  Hello, thomas,
                                  sorry for the late reply
                                  I will try to answer tonight
                                  Krass
                                  • KrassK
                                    Krass @Krass
                                    rays.png ![@Krass](image url)
                                    I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                                    Krass
                                    pixelcruncherP 2 Replies Last reply
                                    • pixelcruncherP
                                      @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
                                      To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
                                      Cheers,
                                      Thomas
                                      • KrassK
                                        Krass
                                        Helo Thomas,
                                        Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
                                        https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
                                        Krass
                                        • KrassK
                                          Krass
                                          Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
                                          https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
                                          Krass
                                          • pixelcruncherP
                                            Another release!
                                            Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                                            What Changed?
                                            • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
                                              shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
                                              in indoor scenes.
                                            • Add extra logging to help diagnose failed installations.
                                            • Cyrillic glyph support: The user interface now supports Cyrillic characters.
                                            • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
                                            • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
                                            Happy Rendering!
                                            majidM 1 Reply Last reply
                                            • 26
                                            • 27
                                            • 5 / 27
