    Rayscaper New Releases
    rayscaperrender
    462 Posts 12 Posters 173.0k Views 13 Watching
    • KrassK Offline
      Krass
      an other render, this time I used Rascaper denoiser option
      https://jskup.fr/wp-content/uploads/2025/02/filter-box-plus-RSCaper-denoiser.png
      Krass
      • KrassK Offline
        Krass
        with rayscaper denoiser on
        Krass
          @Krass I like the result.
          FYI, Rayscaper uses Intel's OpenImageDenoise (link). I think this is the same denoiser that Twilight Render uses in its denoise extension, so you should see comparable results.
          • KrassK Offline
            Krass
            final high res render, reduced in 1080 p and an other render, exterior
            https://jskup.fr/wp-content/uploads/2025/02/rayscaper-1080p.jpg
            https://jskup.fr/wp-content/uploads/2025/02/final2.jpg
            Krass
            KrassK 1 Reply Last reply Reply Quote 2
            • KrassK Offline
              Krass @Krass
              I'm getting used to this little program
              https://jskup.fr/wp-content/uploads/2025/02/2denoised.jpg
              https://jskup.fr/wp-content/uploads/2025/02/4denoised.jpg
              Krass
                Nice renders, especially the last one with the dinner plates.Nice use of DOF.
                S 1 Reply Last reply Reply Quote 0
                  sashapepperspray @pixelcruncher
                  @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
                  P 1 Reply Last reply Reply Quote 1
                  • Rich O BrienR Online
                    Thomas was is aware of the incompatibility with 2025.
                      Hey, Rayscaper users!
                      Another release!
                      Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                      What Changed?
                      • Added support for SketchUp 2025.
                      • Fixed energy loss in glass materials, which previously caused them to appear too dark.
                      • Made asset thumbnail size configurable via the settings dialog.
                      • Fixed reloading of SketchUp materials in Rayscaper.
                      • Fixed light emission issues with HDRI environments.
                      • Removed the 1000Γ—1000 pixel resolution limit for the free version.
                      The asset thumbnail size is configured via the settings dialog:
                      Help me build the community πŸ‘
                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
                      Happy Rendering!
                        pixelcruncher Extension Creator @sashapepperspray
                        @sashapepperspray said in Rayscaper New Releases:
                        SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
                        I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
                        Cheers,
                        Thomas
                        S 1 Reply Last reply Reply Quote 1
                          @pixelcruncher Thanks, it works
                          • KrassK Offline
                            Krass
                            Hello, Pixelcruncher,
                            I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
                            But I didn't uninstall rayscaper before reinstalling,
                            Krass
                            • KrassK Offline
                              Krass
                              that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
                              Krass
                              • KrassK Offline
                                Krass
                                and thank you for removing the pixel resolution limitation
                                Krass
                                  @Krass said in Rayscaper New Releases:
                                  Hey @Krass ,
                                  Can you check the version you are running?
                                  If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                                  After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                                  Regards,
                                  Thomas
                                  • KrassK Offline
                                    Krass
                                    Hello, thomas,
                                    sorry for the late reply
                                    I will try to answer tonight
                                    Krass
                                    KrassK 1 Reply Last reply Reply Quote 0
                                    • KrassK Offline
                                      Krass @Krass
                                      rays.png ![@Krass](image url)
                                      I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                                      Krass
                                        @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
                                        To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
                                        Cheers,
                                        Thomas
                                        • KrassK Offline
                                          Krass
                                          Helo Thomas,
                                          Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
                                          https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
                                          Krass
                                          • KrassK Offline
                                            Krass
                                            Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
                                            https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
                                            Krass
                                            • 23
                                            • 24
                                            • 5 / 24
